    MMM-Hotword,MMM-AssistanMk2 Hotword no Funktion
    50 Posts 5 Posters 19.3k Views 5 Watching
      [[global:former-user]] @guongthongminh
      @guongthongminh
      Let’s check. See the backend logs and the frontend logs.
      1. Hotword tin_tuc was caught normally? (You can check the result on backend log)
        1. If so, notification was emitted normally? (You can check it on frontend log)
          1. if so, well, that’s not my business. Maybe MMM-PageReader has some issue about using notification.
          2. If not, you probably have some error(s) on frontend to prevent working of module. Solve them first.
        2. If not, you should solve the hotword issue first. maybe your tin_tuc.pmdl was not catchable.
      • G Offline
        guongthongminh @Guest
        @Sean The mirror receives and answers like this: “This feature is not yet supported on this device”. I cannot determine the cause.
          @guongthongminh ??? where did you see that message?
          • G Offline
            @Sean google assistant said
              @guongthongminh
              ??? You are working about MMM-Hotword, not MMM-AssistantMk2 right?
              If Google says something, you’ve activated MMM-AssistantMk2. It means…
              You played like this? "smart mirror, tin tuc!"? This is not the usage you are doing.
              I answered How to use hotword to control other modules until now, and your current approach is totally wrong.
              So what you want exactly? Using Google Assistant to tin tuc? (I think its not needed because you’ve already your .pmdl made)
              • G Offline
                @Sean Sorry for my mistake. I want the result to be the same as the video: https://www.youtube.com/watch?v=xdLz0bdxO58
                  @guongthongminh
                  It’s better to ask author of clip how to do it.
                  G 2 Replies Last reply Reply Quote 0
                  • G Offline
                    • G Offline
                      @Sean OK, right now, the hotword is fine for calling the module.
                      But I still can’t get the url from newsfeed and send the PAGE_READER_LOAD notification with that url as a payload.
                      Can you help me with the rest?
                        sdetweil @guongthongminh
                        @guongthongminh the newsfeed module is looking for a notification event with type
                        “ARTICLE_INFO_REQUEST”
                        • G Offline
                          guongthongminh @sdetweil
                          @sdetweil oh great, but how to put it in the config file to use.
                            @guongthongminh
                            hotword???:                  // when I hear this hotword
                            notificationExec: {          // do this, send notification
                                                               with this code           and this payload
                                                 notification:  “ARTICLE_INFO_REQUEST”, payload: null,
                            • G Offline
                              @sdetweil I understand this but what I need to do is call PAGE_READER_LOAD get the url from ARTICLE_INFO_REQUEST to display on MagicMirror.
                              Can this idea be implemented or not possible but I have to use other methods to get url from newfeeds?
                                  @guongthongminh I do not know. I have never seen a request to get info and then use that info to send another request
                                  • G Offline
                                    @sdetweil My ideas have been implemented.
                                    Can you help me how to instruct the hotword to return to the mirror screen after full screen display?
                                      @guongthongminh no, sorry, i have about 1% skill in those modules…
                                      • G Offline
                                        How to run a python file at the same time with MM
                                        • cowboysdudeC Offline
                                          cowboysdude Module Developer @guongthongminh
                                          @guongthongminh I run my PIR py script first then I load the Mirror…if that helps… so basically I have 2 terminal windows open…
                                          • G Offline
                                            guongthongminh @cowboysdude
                                            @cowboysdude
                                            If the mirror opens automatically with pm2, how can I make the python file run at the same time as it?
                                            Is there a way for a python file to run after the operating system boots up?
                                            cowboysdudeC S 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
