    MMM-BackgroundSlideshow Problems
    4 Posts 2 Posters 1.9k Views 2 Watching
      carltonb
      I am attempting to use this module but am having a probably basic problem.
      The module works for about 10 minutes before the screen goes blank with my cursor arrow showing.
      I am using this as a clock on a refurbished laptop screen. On the left I have a date/clock heavily modded with css. On the right I have the darksky weather module. All works for days without activating the background module.
      Using the background module in which the jpg files are loaded in a separate directory and the script looks like this…
          module: 'MMM-BackgroundSlideshow',
          position: 'fullscreen_below',
            imagePaths: ['modules/images/'],
            transitionImages: true,
            randomizeImageOrder: true,
            backgroundSize: 'cover',
            slideshowSpeed: 60000
      After about 10 minutes the images stop and I have a blank screen with the cursor. I either have to do a reboot or an npm restart to get it going again, and then after another 10 minutes it stops. I have tried various pictures with the same problem happening.
      Does anyone have a possible solution.
      Carltonb
        sdetweil @carltonb
        @carltonb i just installed this and don’t see that problem at all.
        you are updating images once every 60 seconds
        how many images are in the folder?
        modules/images/
        try this
        on the mirror, using keyboard, ctrl-shift-i, to open the deverlopers window,
        select the console tab, and scroll up to see any errors…
        also look at the log from where u started MM…
        if pm2, then pm2 logs
        otherwise on the terminal window itself
          carltonb
          Thank you for the reply.
          Can you tell me what I MIGHT BE LOOKING FOR.
          There is a lot of code with errors and warnings both in the developers window and the pm2 logs.
          I do not know what is a valid error and not.
          Again thank you.
            sdetweil @carltonb
            @carltonb in the dev window (described two posts back), add ‘back’ (no quotes) to the filter field, to remove other module messages
