    Magic Mirror updated now doesnt work
    36 Posts 2 Posters 16.1k Views 2 Watching
      bachoo786 @sdetweil
      @sdetweil ok I can conclude one thing is that I cannot access my mirror from another device at home. My mirror is working but it’s not accessible from a different device. Something is blocking it or stopping it within the mirror.
      My config hasn’t changed and its after the update that I cannot access it from another device.
        bachoo786 @sdetweil
        @sdetweil any idea?
          sdetweil @bachoo786
          @bachoo786 said in Magic Mirror updated now doesnt work:
          i’m not sure I understand what you said…
          access is a vague term
          ssh is part of access
          load mirror on browser is part of access
          ftp files is part of access
          I THINK what you meant was
          the mirror app is running, and u can see it.
          but you cannot use a browser on another machine to pull up the the same view…
          so, can we see your config.js.
          I ‘think’ this is the change to address: “”,
          which is supposed to default to “localhost”,
          but DID default to 0.0.0.0
            bachoo786 @sdetweil
            @sdetweil there you go:
            var config = {
                    address: "", // Address to listen on, can be:
                    port: 8181,
                    ipWhitelist: [], // Set [] to allow all IP addresses
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"$
        // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format$
        // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/$
                    language: "en",
                    timeFormat: 24,
                    units: "metric",
            //        customCss: 'css/custom.css',
            //                      module: "alert",
              sdetweil @bachoo786
              address: “”, < — means ONLY the local system can connect
              change to
              address: “0.0.0.0”,
              means whitelist controls who can connect
                bachoo786 @sdetweil
                @sdetweil omg that worked !!! I remember before there was no need to put any thing. How come its changed?
                Anyway I have another problem, my home assistant module keeps on turning on and off like rapidly. It never used to do that before.
                  sdetweil @bachoo786
                  @bachoo786 we found a security gap. The doc says, if not specified, it is localhost. But we allowed anyone.
                  Home assistant on/off what does that mean? Show me the two logs.
                  I will be away for a few hours
                    bachoo786 @sdetweil
                    @sdetweil sorry which 2 logs?
                      bachoo786 @sdetweil
                      @sdetweil here is a link of a little video in gif format showing you what I mean by homeassistant module turning on and off.
                      https://ibb.co/hLx6KJr
                        sdetweil @bachoo786
                        @bachoo786 which Home Assistant module are u using?
                          bachoo786 @sdetweil
                          @sdetweil it seems to be working fine now after few reboots to the pi.
                            sdetweil @bachoo786
                            @bachoo786 cool. Thx for the update!
