Display modules in a carousel
I completely agree, I’ve opened a GitHub issue, but as you can see from the previous conversation, it will take me a while to get around to it. Pull requests welcome :)
Hi, how to install on Mac Book Air (have the mirror installed) just not clued up on the module installs via terminal… many thanks…
Instructions can be found here: https://github.com/barnabycolby/MMM-Carousel
The instructions should work on a Mac. In short, you want to clone the github repository into the modules directory and modify the magic mirror configuration to use the module.
Thanks, tell me can you not just download all the modules and put them in the directory manually rather than using terminal? Thanks!
Ok think i have working as only have one thing showing at a time… how can i define to specific things for specific times?
You need to modify your config.js file, a sample configuration that uses MMM-Carousel can be found here
Many thanks
@barnabycolby will need some help with your module…
How to use it to ONLY rotate 2 modules instead of all of them ?
I have for the moment 10 modules displayed on the screen and would like to rotate only 1 of them with another one…
@PointPubMedia Don’t you need to just put the ones you don’t want to rotate in IgnoreModules? I haven’t installed it, but that looks like the intent…
@PointPubMedia
Once I get home, i can post MY CRUDE hack for that…
I am on pacific time, though. So give me at least 10 hours
