    Display modules in a carousel
    29 Posts 8 Posters 28.5k Views 8 Watching
      barnabycolby
      I completely agree, I’ve opened a GitHub issue, but as you can see from the previous conversation, it will take me a while to get around to it. Pull requests welcome :)
        A Former User
        Hi, how to install on Mac Book Air (have the mirror installed) just not clued up on the module installs via terminal… many thanks…
          barnabycolby
          Instructions can be found here: https://github.com/barnabycolby/MMM-Carousel
          The instructions should work on a Mac. In short, you want to clone the github repository into the modules directory and modify the magic mirror configuration to use the module.
            A Former User
            Thanks, tell me can you not just download all the modules and put them in the directory manually rather than using terminal? Thanks!
              A Former User
              Ok think i have working as only have one thing showing at a time… how can i define to specific things for specific times?
                barnabycolby
                You need to modify your config.js file, a sample configuration that uses MMM-Carousel can be found here
                  A Former User
                  Many thanks
                  • PointPubMediaP Offline
                    PointPubMedia
                    @barnabycolby will need some help with your module…
                    How to use it to ONLY rotate 2 modules instead of all of them ?
                    I have for the moment 10 modules displayed on the screen and would like to rotate only 1 of them with another one…
                    F A 2 Replies Last reply Reply Quote 0
                    • F Offline
                      frog @PointPubMedia
                      @PointPubMedia Don’t you need to just put the ones you don’t want to rotate in IgnoreModules? I haven’t installed it, but that looks like the intent…
                        amanzimdwini @PointPubMedia
                        @PointPubMedia
                        Once I get home, i can post MY CRUDE hack for that…
                        I am on pacific time, though. So give me at least 10 hours
