    I can't update my MM version
    10 Posts 2 Posters 1.6k Views 2 Watching
    • I Offline
      iorifly
      I can’t update my MM version. There is a warning on the screen. When trying to use the upgrade script I get the following error message.
      pi@raspberrypi:~/MagicMirror/installers $ ./upgrade-script.sh
      the log will be /home/pi/MagicMirror/installers/upgrade.log
      No LSB modules are available.
      doing test run = true
      saving custom.css
      cp: não foi possível obter estado de 'custom.css': Arquivo ou diretório inexistente
      upgrading from version 2.10.0 to 2.10.1
      fetching latest revisions
      there are 2 local files that are different than the master repo
         installers/pm2_MagicMirror.json
         package-lock.json
      any *-lock.json files do not need to be saved
      do you want to save these files for later   (Y/n)?y
      git: 'git_user_name' is not a git command. See 'git --help'.
      processing for module MMM-DarkSkyForecast please wait
      skipped processing for MMM-DarkSkyForecast, doing test run
      processing complete for module MMM-DarkSkyForecast
      restoring custom.css
      cp: não foi possível obter estado de 'save_custom.css': Arquivo ou diretório inexistente
      rm: não foi possível remover 'save_custom.css': Arquivo ou diretório inexistente
      test run, restoring files stashed
        Please execute the scripts from here
        • I Offline
          iorifly
          • I Offline
            iorifly
            pi@raspberrypi:~/MagicMirror $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)"
               package-lock.json
            do you want to save these files for later   (Y/n)?Y
            unknown option: -c user.name=upgrade_script
            usage: git [--version] [--help] [-C <path>] [-c <name>=<value>]
                       [--exec-path[=<path>]] [--html-path] [--man-path] [--info-path]
                       [-p | --paginate | -P | --no-pager] [--no-replace-objects] [--bare]
                       [--git-dir=<path>] [--work-tree=<path>] [--namespace=<name>]
                       <command> [<args>]
            processing for module MMM-NowPlayingOnSpotify please wait
            skipped processing for MMM-NowPlayingOnSpotify, doing test run
            processing complete for module MMM-NowPlayingOnSpotify
            No stash entries found.
            • I Offline
              iorifly
              upgrade.log
              Upgrade started - qua jan 15 22:57:36 -03 2020
              system is Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              saving custom.css
              not english or locale not set, set git alias
              remote name = origin
              git fetch rc=0
              current branch = master
              On branch master
              Your branch is behind 'origin/master' by 4 commits, and can be fast-forwarded.
                (use "git pull" to update your local branch)
                (use "git add/rm <file>..." to update what will be committed)
                (use "git checkout -- <file>..." to discard changes in working directory)
              	deleted:    config/config.js.sample
              	modified:   installers/pm2_MagicMirror.json
              	modified:   package-lock.json
              Untracked files:
                (use "git add <file>..." to include in what will be committed)
              	mm.sh
              	pm2-MagicMirror.json
              no changes added to commit (use "git add" and/or "git commit -a")
                 package-lock.json
              save/restore files selection = y
              test merge result rc='' , if empty, no conflicts
              skipping merge, only test run
              removing git alias
              Upgrade ended - qua jan 15 22:57:48 -03 2020
              Upgrade started - qua jan 15 23:05:57 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              restoring installers/pm2_MagicMirror.json from repo
              skipping restore for installers/pm2_MagicMirror.json, doing test run
              restoring package-lock.json from repo
              skipping restore for package-lock.json, doing test run
              removing git alias
              Upgrade ended - qua jan 15 23:06:01 -03 2020
              Upgrade started - qua jan 15 23:10:13 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              removing git alias
              Upgrade ended - qua jan 15 23:10:25 -03 2020
              Upgrade started - qua jan 15 23:11:13 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	installers/save_custom.css
              	mm.sh
                 package-lock.json
              removing git alias
              Upgrade ended - qua jan 15 23:11:20 -03 2020
              Upgrade started - qua jan 15 23:11:50 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              removing git alias
              Upgrade ended - qua jan 15 23:12:07 -03 2020
              Upgrade started - qua jan 15 23:13:09 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	custom.css
              	mm.sh
                 package-lock.json
              removing git alias
              Upgrade ended - qua jan 15 23:13:17 -03 2020
              Upgrade started - qui jan 16 00:05:31 -03 2020
              saving custom.css
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              processing for module MMM-Screencast please wait
              skipped processing for MMM-Screencast, doing test run
              processing complete for module MMM-Screencast
              removing git alias
              Upgrade ended - qui jan 16 00:05:43 -03 2020
              Upgrade started - qui jan 16 01:08:13 -03 2020
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              removing git alias
              Upgrade ended - qui jan 16 01:08:19 -03 2020
              Upgrade started - qui jan 16 01:09:30 -03 2020
              git fetch rc=0
              On branch master
              Untracked files:
              	mm.sh
                 package-lock.json
              save/restore files selection = Y
              removing git alias
              Upgrade ended - qui jan 16 01:09:37 -03 2020
                sdetweil @iorifly
                @iorifly ok, those are test runs. U need to add ‘apply’ at the end to DO the update.
                Or ‘force’ if you have already got part way thru
                Neither parm with the quotes
                • I Offline
                  iorifly
                  Still in error
                  https://pastebin.com/raw/zuxLer7U
                    sdetweil @iorifly
                    @iorifly thanks… can u run the update again like this
                    bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
                    I will want to see the log file… thanks…
                    also, can u run this command from the MagicMirror folder
                    git config --global --get user.email
                    my guess is that it should return nothing
                    • I Offline
                      iorifly
                      nothing returned.
                      pi@raspberrypi:~/MagicMirror $ git config --global --get user.email
                        sdetweil @iorifly
                        @iorifly thanks… fixed already
