    MMM-NowPlayingOnSpotify With erro
    7 Posts 2 Posters 1.2k Views 2 Watching
    • I Offline
      iorifly
      With that out. Does not display what I am playing.
      > magicmirror@2.10.0 start /home/pi/MagicMirror
      > ./run-start.sh
      [02:08:45.316] [LOG] Starting MagicMirror: v2.10.0
      [02:08:45.349] [LOG] Loading config ...
      [02:08:45.368] [LOG] Loading module helpers ...
      [02:08:45.377] [LOG] No helper found for module: alert.
      [02:08:45.563] [LOG] Initializing new module helper ...
      [02:08:45.570] [LOG] Module helper loaded: updatenotification
      [02:08:45.573] [LOG] No helper found for module: clock.
      [02:08:47.019] [LOG] Initializing new module helper ...
      [02:08:47.022] [LOG] Module helper loaded: calendar
      [02:08:47.025] [LOG] No helper found for module: compliments.
      [02:08:48.211] [LOG] Initializing new module helper ...
      [02:08:48.214] [LOG] Module helper loaded: MMM-DarkSkyForecast
      [02:08:49.639] [LOG] Initializing new module helper ...
      [02:08:49.642] [LOG] Module helper loaded: MMM-NowPlayingOnSpotify
      [02:08:49.752] [LOG] Initializing new module helper ...
      [02:08:49.755] [LOG] Module helper loaded: newsfeed
      [02:08:49.759] [LOG] All module helpers loaded.
      [02:08:49.766] [LOG] Starting server on port 8080 ...
      [02:08:49.846] [LOG] Server started ...
      [02:08:49.855] [LOG] Connecting socket for: updatenotification
      [02:08:49.866] [LOG] Connecting socket for: calendar
      [02:08:49.873] [LOG] Starting node helper for: calendar
      [02:08:49.878] [LOG] Connecting socket for: MMM-DarkSkyForecast
      [02:08:49.882] [LOG] ====================== Starting node_helper for module [MMM-DarkSkyForecast]
      [02:08:49.886] [LOG] Connecting socket for: MMM-NowPlayingOnSpotify
      [02:08:49.890] [LOG] Connecting socket for: newsfeed
      [02:08:49.894] [LOG] Starting module: newsfeed
      [02:08:49.896] [LOG] Sockets connected & modules started ...
      [02:08:49.900] [LOG]
      Ready to go! Please point your browser to: http://localhost:8080
      Starting chromium browser now, have patience, it takes a minute
       --disable-quic --enable-tcp-fast-open --ppapi-flash-path=/usr/lib/chromium-browser/libpepflashplayer.so --ppapi-flash-args=enable_stagevideo_auto=0 --ppapi-flash-version=
      [02:09:02.796] [ERROR]  (node:8894) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
      [02:09:03.877] [ERROR]  Error while refreshing:
      [02:09:03.880] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
          at doWrite (_stream_writable.js:411:19)
          at writeOrBuffer (_stream_writable.js:399:5)
          at Socket.Writable.write (_stream_writable.js:299:11)
          at Console.con.(anonymous function) [as log] (/home/pi/MagicMirror/node_modules/console-stamp/main.js:150:46)
          at refreshAccessToken.then (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/core/SpotifyConnector.js:24:19)
          at process._tickCallback (internal/process/next_tick.js:68:7)
      [02:09:03.952] [ERROR]  Error while refreshing:
      [02:09:03.968] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      [02:09:04.036] [ERROR]  Error while refreshing:
      [02:09:04.041] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      [02:09:04.745] [ERROR]  Error while refreshing:
      [02:09:04.748] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
      [02:09:05.293] [ERROR]  Error while refreshing:
      [02:09:05.297] [ERROR]  Error [ERR_STREAM_DESTROYED]: Cannot call write after a stream was destroyed
        sdetweil @iorifly
        @iorifly this is the same problem as the Hass stuff
        • I Offline
          iorifly
          boy, what can i do? I am getting crazy !
          you think you better reinstall everything! ???
          Thank you for your tireless help.
            sdetweil @iorifly
            @iorifly >what can I do?
            Wait!
            This is a volunteer effort.
              sdetweil @iorifly
              @iorifly fix reported in HASS topic
              • I Offline
                iorifly
                My module is forever loading. Does not display the data.
                • I Offline
                  iorifly
                  reboot. The module is ok.
