    SimpleLogo auto change logo not working
    21 Posts 3 Posters 7.2k Views 3 Watching
      RoadRunnr1469
      I installed SimpleLogo and have it showing my custom logo, however I can’t seem to figure out what changes need to be done to make the logo auto change.
      I did install the onscreen menu and have it working, what am I missing?
      Thank you for any advise you can give me.
        sdetweil @RoadRunnr1469
        @RoadRunnr1469 what is SimpleLogo?
        can u post that part of your config.js for this module?
        the doc says
        refreshInterval
        Refresh/refetch image file between interval. Only use this if your image url return different image after some interval of time, even the fileUrl is not changed. See this case #2, awesome project by @ElYoM
        Possible values: 1000, 2000, or 10000
        Default value: 0 (disabled)
          RoadRunnr1469 @sdetweil
          @sdetweil I left that as default in the MMM-SimpleLogo.js - it isn’t clear what needs to change in there.
            RoadRunnr1469
            Module.register("MMM-SimpleLogo", {
                // Default module config.
                defaults: {
                    text: "",
                    fileUrl: "modules/MMM-SimpleLogo/public/Amc.JPG",
                    width: "200px",
            	notification: "SIMPLE_LOGO_UPDATE",
                    position: "top_center",
                    refreshInterval: 1000
                start: function() {
                    if (this.config.refreshInterval > 0) {
                        var self = this;
                        var imgsrc = self.config.fileUrl;
                        this.interval = setInterval(function() {
                            img = document.querySelector(".simple-logo__container img[src*='" + imgsrc + "']");
                            if(!imgsrc.includes("?"))
                                    imgsrc += '?' + Date.now();
                            else
                                    imgsrc += '&' + Date.now();
                            img.setAttribute('src', imgsrc);
                        }, this.config.refreshInterval);
                getStyles: function () {
                    return [
                        this.file('css/mmm-simplelogo.css')
                notificationReceived: function(notification, payload) {
                    if (notification == "SIMPLE_LOGO_UPDATE") {
                        // stop auto-refresh (if any)
                            clearInterval(this.interval);
                        // update with new parameters
                        for (var attr in payload) this.config[attr] = payload[attr];
                        // restart auto-refresh (if any)
                        this.start();
                        this.updateDom();
                // Override dom generator.
                getDom: function() {
                    wrapper.className = 'simple-logo__container';
                    wrapper.classList.add(this.config.position);
                    wrapper.style.width = this.config.width;
                    var text = document.createTextNode(this.config.text);
                    wrapper.appendChild(text);
                    var img = document.createElement("img");
                    img.setAttribute('src', this.config.fileUrl);
                    wrapper.appendChild(img);
                    return wrapper;
              @RoadRunnr1469 u don’t edit the SimpleLogo.js file (in general u NEVER edit the module files unless u are making code fixes or enhancements)
              you edit the config.js
              default is NEVER update
              in config.js
                 module: "MMM-SimpleLogo",
                 position: ????,
                    refreshInterval:  5* 60 * 1000   // 5 minutes, times  60 seconds times 1000 milliseconds per second
                    fileUrl: "???????"
              everything in the config: { … }
              overrides the moduleName.js defaults: { …} items of the same names
              • F Offline
                FlameShotBow
                As @sdetweil stated you shouldn’t be editing the modules JavaScript file.
                To ensure that the SimpleLogo module has not been damaged I would reinstall the module and the OnScreenMenu module if you edited the JavaScript of that too.
                Once you have a fresh install of SimpleLogo and OnScreenMenu you need to edit the config file in magic mirror and not any of the module files.
                I’m not sure what you mean about the “auto chance” aspect. If you want the logos to automatically change then I would suggest sending a notification to SimpleLogo using ModuleScheduler. On the other hand, if you want to manually change them. You can use the OnScreenMenu module like so:
                    module: "MMM-OnScreenMenu",
                    position: "top_centre",
                        menuItems: {
                            notify1: {
                                title: "AMC Logo",
                                payload: {
                                    width: "750px"
                            notify2: {
                                title: "Show other logo",
                                payload: {
                                    fileUrl: "modules/MMM-SimpleLogo/public/......",
                                    width: "1050px"
                which should hopefully give you the option to change the logo manually.
                Hope this helps.
                Pretty experienced with programming - Pretty not experienced with magic mirrors
                  RoadRunnr1469
                  I don’t understand why people have to be so confrontational and un helpful. Making changes the the DEFAULT portion of the main file ONLY affects the initial settings.
                  As far as what I mean by auto changing logo, that is what I understood by the documentation for the module.
                  Dynamic to me means it will change at a given amount of time…
                  ****** Copy/Paste from MMM-SimpleLogo*****
                  The MMM-SimpleLogo module supports the notification event SIMPLE_LOGO_UPDATE which allows the configuration to be dynamically modified. As an example, the MMM-OnScreenMenu module might be used to dynamic adjust the fileURL parameter as follows
                    @sdetweil changing the simplelogo.js back and putting updates in config.js has not made any changes. the logo still stays on the same logo, never changes.
                      @RoadRunnr1469 ok, looking thru the code and doc
                      the code adds a time to the end of the fileurl to force a unique value. You could do this if the URl to the file stayed the same, but the actual file was different (something overwrote the file since last time)
                      so, they planned on the something changing the actual logo file contents
                                  this.interval = setInterval(function() {   // < --- start a recurring timer
                                              imgsrc += '?' + Date.now();  // < ---
                                      else
                                              imgsrc += '&' + Date.now();  // < -----
                                  }, this.config.refreshInterval);  // < ---  refresh time
                      the code also allows some other module to send it a message to change the logo url
                      we are not being ‘un helpful’, the design of the mirror app is to INTENTIONALLY keep people from having to change the module file for different options…
                      so, when we see someone going down that path, we want to get them back on the design
                      I can look at the module code from github, I can’t see what you did locally. (in general)
                      makes it harder to help, and changes made get wiped out if there is a module update…
                      (that tends to make people upset when their stuff is lost!)
                      but your and my initial understanding of what was supposed to happen (as I didn’t know anything about this module), is wrong… update the cycle time but keep the same exact image and nothing will change.
                      you can prove this with 2 logo files.
                      start with one, and then copy the other over the 1st while the module is working.
                      we are all volunteers here…
                        RoadRunnr1469
                        The ReadMe file shows this
                        cat README.md
                        Module: MMM-SimpleLogo
                        The MMM-SimpleLogo module is third party modules of the MagicMirror. This module simply displays logo.
                        Using the module
                                module: 'MMM-SimpleLogo',
                                position: 'top_left',    // This can be any of the regions.
                        Configuration options
                        The following properties can be configured:
                        Option Description
                        fileUrl File url.
                        Possible values: Logo link form internet or path to your local files relative to MagicMirror directory
                        Default value: 'modules/MMM-SimpleLogo/public/logo.png'
                        width Set width of your logo, height is auto.
                        Possible values: '300px' or '50%'
                        Default value: '200px'
                        position Horizontal position on current container
                        Possible values: left, center, or right
                        Default value: left
                        refreshInterval Refresh/refetch image file between interval. Only use this if your image url return different image after some interval of time, even the fileUrl is not changed. See this case #2, awesome project by @ElYoM
                        text Text above the image.
                        Possible values: Any text
                        Default value: Simple Logo
                        Notification Events
                        The MMM-SimpleLogo module supports the notification event SIMPLE_LOGO_UPDATE which allows the configuration to be dynamically modified. As an example, the MMM-OnScreenMenu module might be used to dynamic adjust the fileURL parameter as follows:
                                menuItems: {
                                    notify1: {
                                        title: "Show Cat",
                                        payload: {
                                            fileUrl: "cat.jpg",
                                            width: "750px"
                                    notify2: {
                                        title: "Show Dog",
                                        payload: {
                                            fileUrl: "dog.jpg",
                                            width: "1050px"
                          @RoadRunnr1469 right. Some external module sends a message.
                          I didn’t look at that code
                          R 3 Replies Last reply Reply Quote 0
                            Based on the section “Notification Events” I added a section as called out.
                            this isn’t letting me paste it in here, says it is spam.
                              I added this to the config.js file
                                                  position: "bottom_right",
                                                          menuItems: {
                                                          notify1: {
        title: "Patch",
        payload: {
        width: "200px"
        notify2: {
        title: "Support",
        payload: {
        fileUrl: "modules/MMM-SimpleLogo/public/RedSupport.jpg",
        width: "150px"
                                  @RoadRunnr1469 I won’t be able to look at this til tomorrow or Sunday.
                                  Open the developers window ctrl-shift-i select the console tab and scroll up to see any messages sent from the on screen module
                                    @RoadRunnr1469 I installed the module, and modified one of mine to send the notification, and it worked as expected.
                                      @RoadRunnr1469 and you installed the “MMM-OnScreenMenu” module too, right?
                                        @sdetweil yes, and the on screen option works fine changes the logo as expected.
                                          @RoadRunnr1469 cool… can u mark this as resolved now?
                                            RoadRunnr1469
                                            no, the SimpleLogo auto changer part still is not working.
