    MMM-GooglePhotos
    294 Posts 56 Posters 415.9k Views 59 Watching
    • G
      guythnick
      I would have thought this had been asked, but I could not find it in this thread:
      Is there any way to set the length of time (speed) the pictures will show for? I am using basically default settings in an album with 217 pictures, and the rate they display is very quick. Sometimes they will pop up several times a second, and then slow back down to around 10 seconds per picture. I would rather set it for 30 or even 60 seconds before it rotates. Is this possible?
      M 1 Reply Last reply
        mrdenmark @guythnick
        @guythnick
        Try changing scaninterval and refreshinterval in the config
        G 1 Reply Last reply
        • G
          guythnick @mrdenmark
          @mrdenmark
          My settings are as follows:
          refreshInterval: 1000*60,
          scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
          So, that should be 1 minute and 10 minutes for refresh and scan intervals, respectively. I have tried changing this, and it does not affect the speed at which the individual pictures themselves transition.
            MisterT
            Hi @Sean, i have a question about MMM-GooglePhotos. It(s possible to display a lot of google photos locations ?
            that’s to say i want to display like a mosaic of six google photos on a same page.
            I try to add for exemple two MMM-google photos on my config.js with differents album paths but only one photo is shown.
            Have you an idea ?
            ? 1 Reply Last reply
              A Former User @MisterT
              @MisterT
              No, impossible, sorry. It is not designed for that purpose.
                rogogu
                Hey, first thank you for this great module!
                Currently i have about 50 pictures in my google album and set the sorting to random. I think it all works as intendet but it would be nice if the pictures are only shown once until every picture in the album was displayed.
                Do you think this is possible? Like assigning a specific number to each photo, putting it in an array when it was displayed and before the next one is shown it checks the array if the next photo was already displayed.
                Greetings from Germany
                Robert
                  sdetweil @rogogu
                  @rogogu I would do it a different way, saves work…
                  the list is already ramdomized, so the code just walks thru the list.
                  I would add another parm, refreshAtEnd = true/false(default)
                  if the parm is true, then do NOT start the timer in node_helper
                  at refresh on end of list in true, then this.scanPhotos()
                  R 1 Reply Last reply
                    rogogu @sdetweil
                    @sdetweil okay this seems to do the job. but couldn´t this cause problems with the api limit or base url expiring when there are to many/less photos in the album? let´s say there are 100 photos and the refreshInterval is set to 1min. so it takes 100min before it scans the photos again…
                      sdetweil @rogogu
                      @rogogu maybe… could be why it refreshes even tho not done
                      my code gets next image, and if not connected redoes the authentication…
                      I get the list and then walk the list
                      but it looks like code tries to handle that
                        scanPhotos: function() {
                          this.tempItems = []
                          var auth = new Auth(this.authConfig)
                          auth.on('ready', (client) => {
                            this.accessToken = client.credentials.access_token
                            this.getPhotos()
                      • Alex2020A
                        Alex2020
                        Mi è comparsa una scritta sul Mirror che è disponibile un aggiornamento del modulo MMM-GooglePhoto come si fa l’aggiornamento?Grazie.
                          sdetweil @Alex2020
                          @Alex2020 vai alla cartella del modulo nella finestra del terminale ed emetti, git pull. se il modulo ha un file package.json, eseguire anche ‘npm install’
                          • Alex2020A
                            Alex2020
                            Salve mi compare un messaggio sul Mirror che ce una versione più recente come si aggiorna il modulo MMM-GooglePhotos ,come si fa l’aggiornamento?Grazie.
                              Samwise
                              my auth_and_test is not working. it worked like a year ago, but I haven’t used it since. I’m really new and don’t really know what I’m doing. this is what i get:
                              pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ node auth_and_test.js
                              (node:698) UnhandledPromiseRejectionWarning: Error: invalid_grant
                              at createError (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/createError.js:16:15)
                              at settle (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/core/settle.js:18:12)
                              at IncomingMessage.handleStreamEnd (/home/pi/MagicMirror/modules/MMM-GooglePhotos/node_modules/axios/lib/adapters/http.js:201:11)
                              at IncomingMessage.emit (events.js:198:15)
                              at endReadableNT (_stream_readable.js:1139:12)
                              at processTicksAndRejections (internal/process/task_queues.js:81:17)
                              (node:698) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
                              (node:698) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
                              Any suggestions?
                              S ? 2 Replies Last reply
                                sdetweil @Samwise
                                @Samwise usually means the authentication code has expired.
                                  A Former User @Samwise
                                  @Samwise
                                  remove your current token.json and try again.
                                  • L
                                    lucBtrl
                                    Dear Sean,
                                    It seems the node auth_and_test.js command throws an error on my side :
                                    /home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32
                                      const oauthClient = new OAuth2Client(key.client_id, key.client_secret, key.redirect_uris[0]);
                                    TypeError: Cannot read property 'client_id' of undefined
                                        at new Auth (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth.js:32:44)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-GooglePhotos/auth_and_test.js:16:14)
                                        at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                                        at startup (internal/bootstrap/node.js:283:19)
                                        at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                                    It seems it cannot read my client_id from credentials.json file… do you have an idea ?
                                    Thanks a lot for your help !
                                      A Former User @lucBtrl
                                      @lucBtrl first, remove your credentials and create it again.
                                      L 1 Reply Last reply
                                        Samwise
                                        ok, so it worked, but then when i tried to set which album i wanted, it said this:
                                        pi@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ nano MMM-GooglePhotos.js
                                        nano: error while loading shared libraries: libncursesw.so.5: cannot open shared object file: No such file or directory
                                          @Samwise
                                          I can’t understand why you did this;
                                          You don’t need to (and shouldn’t) modify source code. use your config/config.js.
                                          And, the error
                                          comes from your system, not my module. Maybe your system has been missing something.
                                            Samwise
                                            ok i think everything is in order, but the pictures don’t actually show up…
                                            • 10
                                            • 11
                                            • 14
                                            • 15
                                            • 9 / 15
