    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.4k Views 25 Watching
      A Former User @Kevinho195
      @Kevinho195
      For speaker, frankly said, you don’t need any setup. Just plug the jack in then set it as default sound output of RPI (You can do it on Volume Icon of Raspbian Desktop Menu bar)
      If your chromium browser can play some audio (like youtube site), it will work on my module.
      • ChrisC
        Chris @Guest
        @Sean
        @Chris said in MMM-AssistantMk2 (v3):
        I usually use Gassistpi which is not implemented in MagicMirror.
        This reacted to Ok Google. That is why I thought it worked similarly.
        Thank you for this additional information,
        I will take the test this weekend
        Regards,
        I just did a complete installation to test this module, I must admit that I really do not regret it.
        I like Gassistpi but I must recognize your module is really very accomplished.
        It is impressive in terms of reactivity and no longer triggers unexpectedly as Gassitpi did sometimes.
        The installation method is really very well designed.
        Really nice job.
        @Bugsounet
        Chapeau bas Messieurs
        Regards,
          A Former User
          @Chris : merci à toi chris (je vois que tu es français), on a mis nos talents ensemble :) et c’est pas fini !
          @Chris: thanks to you chris (I see that you are french), we put our talents together :) and it’s not finish !
          @bugsounet
          • N
            nakedrabbit
            Congratulations, @Sean on a new build! The installation method went through like a charm, and I’m even happy to report that my build, a Pi3 with Google Hat, responded perfectly, even though v2 would not recognize it.
            But I do have one snag trying to implement it.
            Raspbian Stretch, Pi3B+, with Google Voice Hat, latest MM. Clean install of AssistantMk2, although I had an assistant.json and profile saved from a previous iteration. Installation went, as I say, beautifully, with the GCC 7 downgrade, proper assignment of the Google Hat input and output and everything. But MM would not load, and my logs showed the same gRPC module error we used to get on v2 from not having the right npm install.
            So I followed the old instructions from that build, namely
            npm install --save-dev electron-rebuild
            ./node_modules/.bin/electron-rebuild
            in both the AssistantMk2 and Hotword directories, and that seems to have fixed the issue.
            Now I’ve got it working, except it’s not working. The first “smartmirror” command engages the Assistant, the tone sounds, but no matter what I say, the module says it did not understand, goes away, and cannot be invoked again unless I restart MM entirely. Logs end with
            [HOTWORD] Final Result: { detected: true,
            0|mm | hotword: ‘SMARTMIRROR’,
            0|mm | file: ‘temp/afterRecording.wav’ }
            …but not a lot more info than that. Could be related to the mmap issue I know you are working on, but what do I know? So I thought I would report it.
              A Former User
              @nakedrabbit
              thanks for report failed install, i will inspect :)
              if log don’t show mmap error, i think it’s not this.
              It could be a noisy environement or a mismake configuration
              have you read this ?
                A Former User
                @nakedrabbit : can you tell me more about npm install problem ?
                because i execute same commands with npm install
                N 1 Reply Last reply
                • N
                  nakedrabbit @Guest
                  @Bugsounet Sure! When I used the auto installer on my RPi3B+, running Raspbian Stretch (I list all these because maybe it’s OK on Buster, I do not know) the npm install created “node-v64-linux-arm-glibc” in the ~/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_library/ directory
                  I know this because I’m running MM with PM2, and the PM2 logs clearly stated that the plugin was looking for “electron-v3.0-linux-arm-glibc” at that location and could not find it.
                  This was a well-documented bug with the v2 install process, and the commands that fixed it were
                  These are run from the MMM-AssistantMk2 directory AND the MMM-Hotword directory. Those were easy!
                  As to the memory issue, I went back just now to check the pm2 logs for errors, and yes, I see these entries:
                  0|mm | mmap() failed: Cannot allocate memory
                  0|mm | Failed to create permanent mapping for memfd region with ID = 3774675295
                  0|mm | Ignoring received block reference with non-registered memfd ID = 3774675295
                  But I was not sure if they were related to the npm install issue or not. I thought they might be leftover from when the proper grpc files were not there, because, frankly, I know nothing about this stuff.
                  And thirdly, yes, I did read about the proper config for the v3 version, and everything seems to be fine there. The plugin loads fine, even listens to me, but simply does not process the commands and then kind of locks up. The rest of the mirror runs fine, but the voice command is no longer responsive.
                  I set up MMM-Buttons to trigger the Assistant as well, and that also works to set off the listener, with exactly the same result - no parsing of the voice command, the eventual “Can’t understand this” dialogue box, and unresponsive until restart.
                    A Former User
                    I have open an issue for this for try to correct it but it’s an unstable branch (nightly build / dev)
                    If you have it, you can test :)
                      A Former User
                      Error “mmap () failed: Cannot allocate memory” will be fixed from version 3.1.0
                      we have coded a secondary code that does not use HTML5 audio.
                      possibly, if you are not using bluetooth.
                      it seems that pulseaudio is the source of the problem
                      if you don’t use bluetooth try;
                      sudo apt-get autoremove --purge pulseaudio
                      possibly a restart of the RPI to finish the changes.
                      and check the parameters with arecord -l, aplay -l
                      this was reported by a user.
                      I personally have no mmap error because I uninstall pulseaudio during the installation of raspbian
                      OR wait release V3.1.0
                        meusprojetoskali @Guest
                        @Bugsounet
                        Hello Friend! Please include pt-BR (Portuguese Brazil), we Brazilians are always overlooked in translations even though it is the largest country in Latin America with the largest population and major producers and consumers of technologies.
                        ? 1 Reply Last reply
                          A Former User @meusprojetoskali
                          @meusprojetoskali said in MMM-AssistantMk2 (v3):
                          Makes your contribution as PR for Portuguese Brazillian translation. We’ll accept to merge.
                          M 1 Reply Last reply
                              Excuse me, but in the Portuguese translation the answer was meaningless, can you explain it in other words?
                              What is a RP contribution?
                                @meusprojetoskali
                                This module needs two kinds of translations.
                                1. Basic terms used by the module.
                                  https://github.com/eouia/MMM-AssistantMk2/tree/master/translations
                                  Error messages or some basic text would be used by the module itself. You can contribute by translating these files.
                                  Send us translation direclty.
                                  Or make a fork from the original github repository to your own repository. Add your work, then make Pull Request(PR) to the original repository. If the original author( - we) accept it, your working will be merged into the original repository.
                                2. vocal patterns for locale on recipes.
                                  Recipe also might needs some translations. For example, with-MMM-Youtube.js recipe (https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js) is written in English. So, stop video as a pattern of transcriptionHook is used. If you could provide with-MMM-Youtube.PT_BR.jswith translation of stop video, send us directly or make a PR as I’ve said above.
                                  A Former User
                                  MMM-AssistantMk2 v3.1.0-1 is out
                                  The AMk2 team
                                    @Bugsounet said in MMM-AssistantMk2 (v3):
                                    The AMk2 team
                                    git pull That’s enough?
                                      A Former User
                                      From V3.0.x to V3.1.x: npm install is needed
                                      check wiki for new features configuration
                                      • N
                                        nakedrabbit
                                        Thanks so much for the new version! I know you guys are working hard on this, I love the plugin, and I appreciate everything that went into making it.
                                        Unfortunately I still have some more issues, and they seem memory related this time around as well. To recap: I’m on a Pi 3B with latest MM, but still on Raspbian Stretch.
                                        I cleared out the old AssistantMk2 and pulled the new version from scratch. Though I used the autoinstaller, I still had to manually rebuild electron…? That’s OK, though, because it did work fine.
                                        I used both recommended config options , namely
                                        useHTML5: false,
                                        playProgram: “mpg321”,
                                        Everything seems OK, and my first test yesterday worked great. I asked a simple question, “What time is it?” and got the answer and all worked great. I left it on overnight, but today Hotword does not summon the plugin. I get these messages from PM2 log:
                                        0|mm | [HOTWORD] Detector starts listening.
                                        0|mm | [HOTWORD] Detected: SMARTMIRROR
                                        0|mm | [HOTWORD] stops.
                                        0|mm | [HOTWORD] After Recording is too short
                                        0|mm | [HOTWORD] Final Result: { detected: true, hotword: ‘SMARTMIRROR’, file: null }
                                        And the corresponding error messages:
                                        0|mm | at Module._compile (internal/modules/cjs/loader.js:678:28)
                                        0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                                        0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                                        0|mm | at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                        0|mm | at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                        0|mm | at Module.require (internal/modules/cjs/loader.js:658:17)
                                        0|mm | at require (internal/modules/cjs/helpers.js:20:18)
                                        0|mm | Failed to create permanent mapping for memfd region with ID = 775865347
                                        0|mm | Failed to regester memfd mempool. Reason: could not attach memfd SHM ID to pipe
                                        0|mm | Failed to create permanent mapping for memfd region with ID = 3943571786
                                        0|mm | Failed to create permanent mapping for memfd region with ID = 2623177707
                                        0|mm | Ignoring received block reference with non-registered memfd ID = 2623177707
                                        I gave you all 15 lines in case there’s something there.
                                        So I stopped MM entirely, started again. Hotword brought up AssistantMk2, but only once, with identical error messages. Once the plugin told me it did not understand, it was unresponsive to my voice.
                                          pnobrega
                                          @Sean what files need to be translated?
                                          I can do a Pt-pt translation ;)
                                            A Former User @pnobrega
                                            @pnobrega
                                            Recipe also might needs some translations. For example, with-MMM-Youtube.js recipe (https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js) is written in English. So, stop video as a pattern of transcriptionHook is used. If you could provide with-MMM-Youtube.PT_BR.js with translation of stop video, send us directly or make a PR as I’ve said above.
                                            P 1 Reply Last reply
                                            • 2 / 7
