    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 97.6k Views 25 Watching
      A Former User
      @nakedrabbit
      thanks for report failed install, i will inspect :)
      if log don’t show mmap error, i think it’s not this.
      It could be a noisy environement or a mismake configuration
      have you read this ?
        A Former User
        @nakedrabbit : can you tell me more about npm install problem ?
        because i execute same commands with npm install
        • N Offline
          nakedrabbit @Guest
          @Bugsounet Sure! When I used the auto installer on my RPi3B+, running Raspbian Stretch (I list all these because maybe it’s OK on Buster, I do not know) the npm install created “node-v64-linux-arm-glibc” in the ~/MagicMirror/modules/MMM-AssistantMk2/node_modules/grpc/src/node/extension_library/ directory
          I know this because I’m running MM with PM2, and the PM2 logs clearly stated that the plugin was looking for “electron-v3.0-linux-arm-glibc” at that location and could not find it.
          This was a well-documented bug with the v2 install process, and the commands that fixed it were
          npm install --save-dev electron-rebuild
          ./node_modules/.bin/electron-rebuild
          These are run from the MMM-AssistantMk2 directory AND the MMM-Hotword directory. Those were easy!
          As to the memory issue, I went back just now to check the pm2 logs for errors, and yes, I see these entries:
          0|mm | mmap() failed: Cannot allocate memory
          0|mm | Failed to create permanent mapping for memfd region with ID = 3774675295
          0|mm | Ignoring received block reference with non-registered memfd ID = 3774675295
          But I was not sure if they were related to the npm install issue or not. I thought they might be leftover from when the proper grpc files were not there, because, frankly, I know nothing about this stuff.
          And thirdly, yes, I did read about the proper config for the v3 version, and everything seems to be fine there. The plugin loads fine, even listens to me, but simply does not process the commands and then kind of locks up. The rest of the mirror runs fine, but the voice command is no longer responsive.
          I set up MMM-Buttons to trigger the Assistant as well, and that also works to set off the listener, with exactly the same result - no parsing of the voice command, the eventual “Can’t understand this” dialogue box, and unresponsive until restart.
            A Former User
            I have open an issue for this for try to correct it but it’s an unstable branch (nightly build / dev)
            If you have it, you can test :)
              A Former User
              Error “mmap () failed: Cannot allocate memory” will be fixed from version 3.1.0
              we have coded a secondary code that does not use HTML5 audio.
              possibly, if you are not using bluetooth.
              it seems that pulseaudio is the source of the problem
              if you don’t use bluetooth try;
              sudo apt-get autoremove --purge pulseaudio
              possibly a restart of the RPI to finish the changes.
              and check the parameters with arecord -l, aplay -l
              this was reported by a user.
              I personally have no mmap error because I uninstall pulseaudio during the installation of raspbian
              OR wait release V3.1.0
                meusprojetoskali @Guest
                @Bugsounet
                Hello Friend! Please include pt-BR (Portuguese Brazil), we Brazilians are always overlooked in translations even though it is the largest country in Latin America with the largest population and major producers and consumers of technologies.
                  A Former User @meusprojetoskali
                  @meusprojetoskali said in MMM-AssistantMk2 (v3):
                  Makes your contribution as PR for Portuguese Brazillian translation. We’ll accept to merge.
                      Excuse me, but in the Portuguese translation the answer was meaningless, can you explain it in other words?
                      What is a RP contribution?
                        @meusprojetoskali
                        This module needs two kinds of translations.
                        1. Basic terms used by the module.
                          https://github.com/eouia/MMM-AssistantMk2/tree/master/translations
                          Error messages or some basic text would be used by the module itself. You can contribute by translating these files.
                          Send us translation direclty.
                          Or make a fork from the original github repository to your own repository. Add your work, then make Pull Request(PR) to the original repository. If the original author( - we) accept it, your working will be merged into the original repository.
                        2. vocal patterns for locale on recipes.
                          Recipe also might needs some translations. For example, with-MMM-Youtube.js recipe (https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js) is written in English. So, stop video as a pattern of transcriptionHook is used. If you could provide with-MMM-Youtube.PT_BR.jswith translation of stop video, send us directly or make a PR as I’ve said above.
                          A Former User
                          MMM-AssistantMk2 v3.1.0-1 is out
                          The AMk2 team
                            @Bugsounet said in MMM-AssistantMk2 (v3):
                            The AMk2 team
                            git pull That’s enough?
                              A Former User
                              From V3.0.x to V3.1.x: npm install is needed
                              check wiki for new features configuration
                              • N Offline
                                nakedrabbit
                                Thanks so much for the new version! I know you guys are working hard on this, I love the plugin, and I appreciate everything that went into making it.
                                Unfortunately I still have some more issues, and they seem memory related this time around as well. To recap: I’m on a Pi 3B with latest MM, but still on Raspbian Stretch.
                                I cleared out the old AssistantMk2 and pulled the new version from scratch. Though I used the autoinstaller, I still had to manually rebuild electron…? That’s OK, though, because it did work fine.
                                I used both recommended config options , namely
                                useHTML5: false,
                                playProgram: “mpg321”,
                                Everything seems OK, and my first test yesterday worked great. I asked a simple question, “What time is it?” and got the answer and all worked great. I left it on overnight, but today Hotword does not summon the plugin. I get these messages from PM2 log:
                                0|mm | [HOTWORD] Detector starts listening.
                                0|mm | [HOTWORD] Detected: SMARTMIRROR
                                0|mm | [HOTWORD] stops.
                                0|mm | [HOTWORD] After Recording is too short
                                0|mm | [HOTWORD] Final Result: { detected: true, hotword: ‘SMARTMIRROR’, file: null }
                                And the corresponding error messages:
                                0|mm | at Module._compile (internal/modules/cjs/loader.js:678:28)
                                0|mm | at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10)
                                0|mm | at Module.load (internal/modules/cjs/loader.js:620:32)
                                0|mm | at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
                                0|mm | at Function.Module._load (internal/modules/cjs/loader.js:551:3)
                                0|mm | at Module.require (internal/modules/cjs/loader.js:658:17)
                                0|mm | at require (internal/modules/cjs/helpers.js:20:18)
                                0|mm | Failed to create permanent mapping for memfd region with ID = 775865347
                                0|mm | Failed to regester memfd mempool. Reason: could not attach memfd SHM ID to pipe
                                0|mm | Failed to create permanent mapping for memfd region with ID = 3943571786
                                0|mm | Failed to create permanent mapping for memfd region with ID = 2623177707
                                0|mm | Ignoring received block reference with non-registered memfd ID = 2623177707
                                I gave you all 15 lines in case there’s something there.
                                So I stopped MM entirely, started again. Hotword brought up AssistantMk2, but only once, with identical error messages. Once the plugin told me it did not understand, it was unresponsive to my voice.
                                  pnobrega
                                  @Sean what files need to be translated?
                                  I can do a Pt-pt translation ;)
                                    A Former User @pnobrega
                                    @pnobrega
                                    Recipe also might needs some translations. For example, with-MMM-Youtube.js recipe (https://github.com/eouia/MMM-AssistantMk2/blob/master/recipes/with-MMM-Youtube.js) is written in English. So, stop video as a pattern of transcriptionHook is used. If you could provide with-MMM-Youtube.PT_BR.js with translation of stop video, send us directly or make a PR as I’ve said above.
                                      pnobrega @Guest
                                      @Sean i’m gonna install now the module. After installed I’ll translate it.
                                      Wanna see context for better translate.
                                      I’ll send you the files after
                                        pnobrega
                                        hi.
                                        What am i missing here?
                                        https://ibb.co/TcH3MHF
                                        current config never works. I’m shown 2 devices
                                        card 0: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
                                        card 1: SB [HDA ATI SB], device 0: ALC269VB Analog [ALC269VB Analog]
                                        i’ve choosen different settings but never works.
                                        Sound it working good cause i hear it from youtube. Speakers are from the monitor through hdmi
                                          A Former User
                                          Hi, I wrote audio script with play plughw. If don’t work try manually to find your configuration
                                          • K Offline
                                            Kevinho195
                                            Hi @Sean
                                            I just updated from 3.0 to the latest version. I did git pull and npm install and did create the token.json again and store it as decribed in your manual. Version 3.0 did work great, but now I get this error: What am I doing wrong?
                                            0|MagicMirror  | [21:35:32.002] [LOG]
                                            0|MagicMirror  | Starting MagicMirror: v2.10.0
                                            0|MagicMirror  | [21:35:32.032] [LOG]
                                            0|MagicMirror  | Loading config ...
                                            0|MagicMirror  | [21:35:32.071] [LOG]
                                            0|MagicMirror  | Loading module helpers ...
                                            0|MagicMirror  | [21:35:32.078] [LOG]
                                            0|MagicMirror  | No helper found for module: MMM-pages.
                                            0|MagicMirror  | [21:35:36.901] [ERROR]
                                            0|MagicMirror  | WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'play-sound'
                                            0|MagicMirror  | [21:35:36.903] [LOG]    Loading module helpers ...
                                            0|MagicMirror  | [21:35:36.906] [LOG]    No helper found for module: MMM-pages.
                                            0|MagicMirror  | [21:35:36.913] [ERROR]  App threw an error during load
                                            0|MagicMirror  | [21:35:36.919] [ERROR]  Error: Cannot find module 'play-sound'
                                            0|MagicMirror  |     at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
                                            0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                            0|MagicMirror  |     at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                            0|MagicMirror  |     at Function.Module._load (internal/modules/cjs/loader.js:528:25)
                                            0|MagicMirror  |     at Module.require (internal/modules/cjs/loader.js:658:17)
                                            0|MagicMirror  |     at require (internal/modules/cjs/helpers.js:20:18)
                                            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:12:19)
                                            0|MagicMirror  |     at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-AssistantMk2/node_helper.js:201:3)
                                            0|MagicMirror  |     at Module._compile (internal/modules/cjs/loader.js:711:30)
                                            0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
                                            0|MagicMirror  | [21:35:36.939] [LOG]
                                            0|MagicMirror  | Whoops! There was an uncaught exception...
                                            0|MagicMirror  | [21:35:36.941] [ERROR]
                                            0|MagicMirror  | { Error: Cannot find module 'play-sound'
                                            0|MagicMirror  |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10) code: 'MODULE_NOT_FOUND' }
                                            0|MagicMirror  | [21:35:36.975] [LOG]    MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                            0|MagicMirror  | [21:35:36.977] [LOG]    If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                            0|MagicMirror  | Fontconfig error: "/home/pi/.config/fontconfig/fonts.conf", line 10: junk after document element
                                            0|MagicMirror  | [21:35:37.852] [LOG]
                                            0|MagicMirror  | Launching application.
                                            • 2 / 7
