    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 93.0k Views 25 Watching
      A Former User @Chris
      @Chris
      Unfortunately Ok Google(or any other hotword trigger detection) is not included in Google Assistant SDK itself by Google. That is why MMM-Hotword be needed.
        @Chris
        Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. That is why trigger be needed.
        ChrisC J 2 Replies Last reply Reply Quote 0
        • ChrisC Offline
          Chris @Guest
          I usually use Gassistpi which is not implemented in MagicMirror.
          This reacted to Ok Google. That is why I thought it worked similarly.
          Thank you for this additional information,
          I will take the test this weekend
          Regards,
            @Chris
            GassistPi might use Assistant SDK Library (Python) - Which has been deprecated by Google, so it could not be supported anymore. It had embedded hotword detector in the Library, but not included in SDK itself directly. Anyway, that is deprecated so we cannot use it anymore.
            ChrisC 1 Reply Last reply Reply Quote 0
              dvbit @Guest
              @Sean sorry was a DUMB mistake from my side.
              works FLAWLESSLY and it’s incredible the progress made.
              Thanks !!
                dvbit
                About Hotword: have you tried Porcupine? seems to be very good
                  A Former User
                  hi, what is Porcupine ?
                  @bugsounet
                    A Former User @Guest
                    @Bugsounet
                    He said this; https://github.com/Picovoice/porcupine
                    Once I looked inside that. Maybe someday I could try it. Not guarantee. :D
                      dvbit
                      Video
                        dvbit
                        @Bugsounet I enabled magicwords.
                        Since I am Italian I looked under your iftt accounts for Italian but I could not find.
                        I understand it is WIP.
                        If you need help with the language (I don’t think but anyway I ask) please get in touch.
                          A Former User
                          At this moment, only French and English is enabled. I will update scripts for other supported language very soon !
                            A Former User
                            Humm… I will try this week end ;)
                              A Former User
                              @dvbit I have updated myMagicWord and post all supported language script
                              see wiki myMagicWord
                              • K Offline
                                Kevinho195
                                @Sean Thanks for your fantastic Assistant! I tried to install it with your new installer, but I failed to set up the correct speaker. It did not find my 3.5mm Jack speaker. How can I use the Jack output instead of usb?
                                  A Former User @Kevinho195
                                  @Kevinho195
                                  For speaker, frankly said, you don’t need any setup. Just plug the jack in then set it as default sound output of RPI (You can do it on Volume Icon of Raspbian Desktop Menu bar)
                                  If your chromium browser can play some audio (like youtube site), it will work on my module.
                                  • ChrisC Offline
                                    Chris @Guest
                                    @Sean
                                    @Chris said in MMM-AssistantMk2 (v3):
                                    Regards,
                                    I just did a complete installation to test this module, I must admit that I really do not regret it.
                                    I like Gassistpi but I must recognize your module is really very accomplished.
                                    It is impressive in terms of reactivity and no longer triggers unexpectedly as Gassitpi did sometimes.
                                    The installation method is really very well designed.
                                    Really nice job.
                                    @Bugsounet
                                    Chapeau bas Messieurs
                                    Regards,
                                      A Former User
                                      @Chris : merci à toi chris (je vois que tu es français), on a mis nos talents ensemble :) et c’est pas fini !
                                      @Chris: thanks to you chris (I see that you are french), we put our talents together :) and it’s not finish !
                                      @bugsounet
                                      • N Offline
                                        nakedrabbit
                                        Congratulations, @Sean on a new build! The installation method went through like a charm, and I’m even happy to report that my build, a Pi3 with Google Hat, responded perfectly, even though v2 would not recognize it.
                                        But I do have one snag trying to implement it.
                                        Raspbian Stretch, Pi3B+, with Google Voice Hat, latest MM. Clean install of AssistantMk2, although I had an assistant.json and profile saved from a previous iteration. Installation went, as I say, beautifully, with the GCC 7 downgrade, proper assignment of the Google Hat input and output and everything. But MM would not load, and my logs showed the same gRPC module error we used to get on v2 from not having the right npm install.
                                        So I followed the old instructions from that build, namely
                                        npm install --save-dev electron-rebuild
                                        ./node_modules/.bin/electron-rebuild
                                        in both the AssistantMk2 and Hotword directories, and that seems to have fixed the issue.
                                        Now I’ve got it working, except it’s not working. The first “smartmirror” command engages the Assistant, the tone sounds, but no matter what I say, the module says it did not understand, goes away, and cannot be invoked again unless I restart MM entirely. Logs end with
                                        [HOTWORD] Final Result: { detected: true,
                                        0|mm | hotword: ‘SMARTMIRROR’,
                                        0|mm | file: ‘temp/afterRecording.wav’ }
                                        …but not a lot more info than that. Could be related to the mmap issue I know you are working on, but what do I know? So I thought I would report it.
                                          A Former User
                                          @nakedrabbit
                                          thanks for report failed install, i will inspect :)
                                          if log don’t show mmap error, i think it’s not this.
                                          It could be a noisy environement or a mismake configuration
                                          have you read this ?
                                            A Former User
                                            @nakedrabbit : can you tell me more about npm install problem ?
                                            because i execute same commands with npm install
                                            • 1 / 7
