    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 109.4k Views 25 Watching
      dvbit @Guest
      @Sean Just installed.
      Everything seemed to go fine with the new installer (great!).
      However after installing I have no screen feedback.
      I have activated debug and everything seems fine though (no major error message).
      Too late to test voice in home cannot say if the assistnt itself works.
      What could it be due to?
      I have ported/copied from previous install the profile and credentials file.
      [23:40:28.380] [LOG]    [HOTWORD] begins.
      [23:40:28.381] [LOG]    [HOTWORD] Detector starts listening.
      [23:40:28.408] [LOG]    [NEWS] Initialized.
      [23:40:28.417] [LOG]    Transportation fetcher for station with id 'xxx' created.
      [23:40:28.592] [LOG]    [AMK2] MMM-AssistantMk2 Version: 3.0.0
      [23:40:28.594] [LOG]    [AMK2] RECIPE_LOADED: with-MMM-Hotword.js
      [23:40:28.595] [LOG]    [AMK2] NO_ACTION_TO_MANAGE
      [23:40:28.610] [LOG]    [AMK2] AssistantMk2 v3 is initialized.
      [23:40:28.627] [LOG]    [AMK2] tmp directory is now cleaned.
      [23:40:28.639] [LOG]    [RCREPO] Repository scanning...
      [23:40:29.501] [LOG]    [RCREPO] modules.json is updated.
      [23:40:29.611] [LOG]    [NEWS] Articles are aggregated :  20
      ^C[23:42:12.626] [LOG]    [SIGINT] Received. Shutting down server...
      ? 1 Reply Last reply
        A Former User @dvbit
        @dvbit
        Show me your configs. And MMM-Hotword should be updated also.(git pull enough)
        D 1 Reply Last reply
        • ChrisC
          Chris
          First of all, thank you both for this wonderful work.
          I have a question that may seem silly, but is it mandatory to install MMM-Hotword with this module in order to trigger the wizard?
          Regards,
            A Former User @Chris
            @Chris
            If you want to use MMM-Hotword as a trigger to activate this module, MMM-Hotword would be needed.
            However, you can use another module as an activator that can detect your trigger and can emit some notification(customizable or not).
            For example, You can use MMM-Clap instead of MMM-Hotword. In this case, you can activate this MMM-AssistantMk2 with a finger-snap instead of speaking hotword.
            • ChrisC
              Chris
              Thank you for your reply,
              I thought that to trigger it, we could simply say “ok google” if we did not want to customize the keyword (Jarvis, Smartmirror …) using MMM-hotword.
              Regards,
              ? 2 Replies Last reply
                @Chris
                Unfortunately Ok Google(or any other hotword trigger detection) is not included in Google Assistant SDK itself by Google. That is why MMM-Hotword be needed.
                  @Chris
                  Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. That is why trigger be needed.
                  ChrisC J 2 Replies Last reply
                  • ChrisC
                    Chris @Guest
                    I usually use Gassistpi which is not implemented in MagicMirror.
                    This reacted to Ok Google. That is why I thought it worked similarly.
                    Thank you for this additional information,
                    I will take the test this weekend
                    Regards,
                      @Chris
                      GassistPi might use Assistant SDK Library (Python) - Which has been deprecated by Google, so it could not be supported anymore. It had embedded hotword detector in the Library, but not included in SDK itself directly. Anyway, that is deprecated so we cannot use it anymore.
                      ChrisC 1 Reply Last reply
                        dvbit @Guest
                        @Sean sorry was a DUMB mistake from my side.
                        works FLAWLESSLY and it’s incredible the progress made.
                        Thanks !!
                          dvbit
                          About Hotword: have you tried Porcupine? seems to be very good
                            A Former User
                            hi, what is Porcupine ?
                            @bugsounet
                              A Former User @Guest
                              @Bugsounet
                              He said this; https://github.com/Picovoice/porcupine
                              Once I looked inside that. Maybe someday I could try it. Not guarantee. :D
                                dvbit
                                Video
                                  dvbit
                                  @Bugsounet I enabled magicwords.
                                  Since I am Italian I looked under your iftt accounts for Italian but I could not find.
                                  I understand it is WIP.
                                  If you need help with the language (I don’t think but anyway I ask) please get in touch.
                                    A Former User
                                    At this moment, only French and English is enabled. I will update scripts for other supported language very soon !
                                      A Former User
                                      Humm… I will try this week end ;)
                                        A Former User
                                        @dvbit I have updated myMagicWord and post all supported language script
                                        see wiki myMagicWord
                                        M 1 Reply Last reply
                                        • K
                                          Kevinho195
                                          @Sean Thanks for your fantastic Assistant! I tried to install it with your new installer, but I failed to set up the correct speaker. It did not find my 3.5mm Jack speaker. How can I use the Jack output instead of usb?
                                            A Former User @Kevinho195
                                            @Kevinho195
                                            For speaker, frankly said, you don’t need any setup. Just plug the jack in then set it as default sound output of RPI (You can do it on Volume Icon of Raspbian Desktop Menu bar)
                                            If your chromium browser can play some audio (like youtube site), it will work on my module.
                                            • 1 / 7
