    MMM-AssistantMk2 (v3)
    135 Posts 27 Posters 102.5k Views 25 Watching
      [[global:former-user]] @dvbit
      @dvbit
      Show me your configs. And MMM-Hotword should be updated also.(git pull enough)
      • ChrisC Offline
        Chris
        First of all, thank you both for this wonderful work.
        I have a question that may seem silly, but is it mandatory to install MMM-Hotword with this module in order to trigger the wizard?
        Regards,
          [[global:former-user]] @Chris
          @Chris
          If you want to use MMM-Hotword as a trigger to activate this module, MMM-Hotword would be needed.
          However, you can use another module as an activator that can detect your trigger and can emit some notification(customizable or not).
          For example, You can use MMM-Clap instead of MMM-Hotword. In this case, you can activate this MMM-AssistantMk2 with a finger-snap instead of speaking hotword.
          • ChrisC Offline
            Chris
            Thank you for your reply,
            I thought that to trigger it, we could simply say “ok google” if we did not want to customize the keyword (Jarvis, Smartmirror …) using MMM-hotword.
            Regards,
              @Chris
              Unfortunately Ok Google(or any other hotword trigger detection) is not included in Google Assistant SDK itself by Google. That is why MMM-Hotword be needed.
                @Chris
                Or you can make a version of ALWAYS LISTENING & ALWAYS REACTING FOR ANY VOICE, but I can bet nobody wants it. That is why trigger be needed.
                ChrisC J 2 Replies Last reply Reply Quote 0
                • ChrisC Offline
                  Chris @Guest
                  I usually use Gassistpi which is not implemented in MagicMirror.
                  This reacted to Ok Google. That is why I thought it worked similarly.
                  Thank you for this additional information,
                  I will take the test this weekend
                  Regards,
                    @Chris
                    GassistPi might use Assistant SDK Library (Python) - Which has been deprecated by Google, so it could not be supported anymore. It had embedded hotword detector in the Library, but not included in SDK itself directly. Anyway, that is deprecated so we cannot use it anymore.
                    ChrisC 1 Reply Last reply Reply Quote 0
                      dvbit @Guest
                      @Sean sorry was a DUMB mistake from my side.
                      works FLAWLESSLY and it’s incredible the progress made.
                      Thanks !!
                        dvbit
                        About Hotword: have you tried Porcupine? seems to be very good
                          hi, what is Porcupine ?
                          @bugsounet
                            [[global:former-user]] @Guest
                            @Bugsounet
                            He said this; https://github.com/Picovoice/porcupine
                            Once I looked inside that. Maybe someday I could try it. Not guarantee. :D
                              dvbit
                              Video
                                dvbit
                                @Bugsounet I enabled magicwords.
                                Since I am Italian I looked under your iftt accounts for Italian but I could not find.
                                I understand it is WIP.
                                If you need help with the language (I don’t think but anyway I ask) please get in touch.
                                  At this moment, only French and English is enabled. I will update scripts for other supported language very soon !
                                    Humm… I will try this week end ;)
                                      @dvbit I have updated myMagicWord and post all supported language script
                                      see wiki myMagicWord
                                      • K Offline
                                        Kevinho195
                                        @Sean Thanks for your fantastic Assistant! I tried to install it with your new installer, but I failed to set up the correct speaker. It did not find my 3.5mm Jack speaker. How can I use the Jack output instead of usb?
                                          [[global:former-user]] @Kevinho195
                                          @Kevinho195
                                          For speaker, frankly said, you don’t need any setup. Just plug the jack in then set it as default sound output of RPI (You can do it on Volume Icon of Raspbian Desktop Menu bar)
                                          If your chromium browser can play some audio (like youtube site), it will work on my module.
                                          • ChrisC Offline
                                            Chris @Guest
                                            @Sean
                                            @Chris said in MMM-AssistantMk2 (v3):
                                            Regards,
                                            I just did a complete installation to test this module, I must admit that I really do not regret it.
                                            I like Gassistpi but I must recognize your module is really very accomplished.
                                            It is impressive in terms of reactivity and no longer triggers unexpectedly as Gassitpi did sometimes.
                                            The installation method is really very well designed.
                                            Really nice job.
                                            @Bugsounet
                                            Chapeau bas Messieurs
                                            Regards,
                                            • 1 / 7
