    monitor turns on and off when activiting MM2
    5 Posts 2 Posters 664 Views 2 Watching
      payno4
      Hallo community,
      first I’m really sry for my bad english but I don’t know what to do. I’m using the Raspberry Pi 3 Model A+. The RaPi is connected to a Acer B193 monitor. Actually there is no problem when mm2 is not started, but as soon as I start mm2 in desktop modus my monitor goes crazy. It turns off and one second later on and this every 10 seconds or something. Maybe it’s important to know that not the hole monitor turns off but rather the background light. I really don’t know what the problem is :expressionless_face: I already turned the RaPi into the VGA modus with the appropriate screen resolution. I also installed auto starting (pm2). There are no troubleshooting shown in log.
      I do not know what informations you exactly need, maybe if there are any further questions just let me know.
      I hope you can help me.
      sincerely Julian
        sdetweil @payno4
        @payno4 that typically means there is some config problem for a module, that causes MM to fail, and then pm2 starts it back up again…
        we need to see the output of
        pm2 logs --lines=100
          payno4
          • The last 100 lines
          PM2        | 2020-01-26T11:47:52: PM2 log: PM2 successfully stopped
          PM2        | 2020-01-26T11:48:19: PM2 log: ===============================================================================
          PM2        | 2020-01-26T11:48:19: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
          PM2        | 2020-01-26T11:48:19: PM2 log: Time                 : Sun Jan 26 2020 11:48:19 GMT+0100 (GMT+01:00)
          PM2        | 2020-01-26T11:48:19: PM2 log: PM2 version          : 4.2.1
          PM2        | 2020-01-26T11:48:19: PM2 log: Node.js version      : 10.18.0
          PM2        | 2020-01-26T11:48:19: PM2 log: Current arch         : arm
          PM2        | 2020-01-26T11:48:19: PM2 log: PM2 home             : /home/pi/.pm2
          PM2        | 2020-01-26T11:48:19: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
          PM2        | 2020-01-26T11:48:19: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
          PM2        | 2020-01-26T11:48:19: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
          PM2        | 2020-01-26T11:48:19: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2        | 2020-01-26T11:48:19: PM2 log: Worker Interval      : 30000
          PM2        | 2020-01-26T11:48:19: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
          PM2        | 2020-01-26T11:48:19: PM2 log: Concurrent actions   : 2
          PM2        | 2020-01-26T11:48:19: PM2 log: SIGTERM timeout      : 1600
          PM2        | 2020-01-26T11:48:20: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2020-01-26T11:48:20: PM2 log: App [mm:0] online
          PM2        | 2020-01-26T12:06:56: PM2 log: Stopping app:mm id:0
          PM2        | 2020-01-26T12:06:56: PM2 log: pid=822 msg=failed to kill - retrying in 100ms
          PM2        | 2020-01-26T12:06:57: PM2 log: pid=822 msg=failed to kill - retrying in 100ms
          PM2        | 2020-01-26T12:07:00: PM2 log: pid=822 msg=failed to kill - retrying in 100ms
          PM2        | 2020-01-26T12:07:00: PM2 log: Process with pid 822 still alive after 1600ms, sending it SIGKILL now...
          PM2        | 2020-01-26T12:07:00: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
          PM2        | 2020-01-26T12:07:00: PM2 log: pid=822 msg=process killed
          PM2        | 2020-01-26T12:22:36: PM2 log: ===============================================================================
          PM2        | 2020-01-26T12:22:36: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
          PM2        | 2020-01-26T12:22:36: PM2 log: Time                 : Sun Jan 26 2020 12:22:36 GMT+0100 (GMT+01:00)
          PM2        | 2020-01-26T12:22:36: PM2 log: PM2 version          : 4.2.1
          PM2        | 2020-01-26T12:22:36: PM2 log: Node.js version      : 10.18.0
          PM2        | 2020-01-26T12:22:36: PM2 log: Current arch         : arm
          PM2        | 2020-01-26T12:22:36: PM2 log: PM2 home             : /home/pi/.pm2
          PM2        | 2020-01-26T12:22:36: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
          PM2        | 2020-01-26T12:22:36: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
          PM2        | 2020-01-26T12:22:36: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
          PM2        | 2020-01-26T12:22:36: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2        | 2020-01-26T12:22:36: PM2 log: Worker Interval      : 30000
          PM2        | 2020-01-26T12:22:36: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
          PM2        | 2020-01-26T12:22:37: PM2 log: Concurrent actions   : 2
          PM2        | 2020-01-26T12:22:37: PM2 log: SIGTERM timeout      : 1600
          PM2        | 2020-01-26T12:22:37: PM2 log: ===============================================================================
          PM2        | 2020-01-26T12:22:37: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2020-01-26T12:22:37: PM2 log: App [mm:0] online
          PM2        | 2020-01-26T14:51:00: PM2 log: ===============================================================================
          PM2        | 2020-01-26T14:51:00: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
          PM2        | 2020-01-26T14:51:00: PM2 log: Time                 : Sun Jan 26 2020 14:51:00 GMT+0100 (GMT+01:00)
          PM2        | 2020-01-26T14:51:00: PM2 log: PM2 version          : 4.2.1
          PM2        | 2020-01-26T14:51:00: PM2 log: Node.js version      : 10.18.0
          PM2        | 2020-01-26T14:51:00: PM2 log: Current arch         : arm
          PM2        | 2020-01-26T14:51:00: PM2 log: PM2 home             : /home/pi/.pm2
          PM2        | 2020-01-26T14:51:00: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
          PM2        | 2020-01-26T14:51:00: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
          PM2        | 2020-01-26T14:51:00: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
          PM2        | 2020-01-26T14:51:00: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2        | 2020-01-26T14:51:00: PM2 log: Worker Interval      : 30000
          PM2        | 2020-01-26T14:51:00: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
          PM2        | 2020-01-26T14:51:00: PM2 log: Concurrent actions   : 2
          PM2        | 2020-01-26T14:51:00: PM2 log: SIGTERM timeout      : 1600
          PM2        | 2020-01-26T14:51:01: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2020-01-26T14:51:02: PM2 log: App [mm:0] online
          PM2        | 2020-01-26T15:02:19: PM2 log: Stopping app:mm id:0
          PM2        | 2020-01-26T15:02:19: PM2 log: pid=747 msg=failed to kill - retrying in 100ms
          PM2        | 2020-01-26T15:02:20: PM2 log: pid=747 msg=failed to kill - retrying in 100ms
          PM2        | 2020-01-26T15:02:21: PM2 log: Process with pid 747 still alive after 1600ms, sending it SIGKILL now...
          PM2        | 2020-01-26T15:02:21: PM2 log: App [mm:0] exited with code [0] via signal [SIGKILL]
          PM2        | 2020-01-26T15:02:21: PM2 log: pid=747 msg=process killed
          PM2        | 2020-01-26T18:30:08: PM2 log: ===============================================================================
          PM2        | 2020-01-26T18:30:08: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
          PM2        | 2020-01-26T18:30:08: PM2 log: Time                 : Sun Jan 26 2020 18:30:08 GMT+0100 (GMT+01:00)
          PM2        | 2020-01-26T18:30:08: PM2 log: PM2 version          : 4.2.1
          PM2        | 2020-01-26T18:30:08: PM2 log: Node.js version      : 10.18.0
          PM2        | 2020-01-26T18:30:08: PM2 log: Current arch         : arm
          PM2        | 2020-01-26T18:30:08: PM2 log: PM2 home             : /home/pi/.pm2
          PM2        | 2020-01-26T18:30:08: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
          PM2        | 2020-01-26T18:30:08: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
          PM2        | 2020-01-26T18:30:08: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
          PM2        | 2020-01-26T18:30:08: PM2 log: Application log path : /home/pi/.pm2/logs
          PM2        | 2020-01-26T18:30:08: PM2 log: Worker Interval      : 30000
          PM2        | 2020-01-26T18:30:08: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
          PM2        | 2020-01-26T18:30:08: PM2 log: Concurrent actions   : 2
          PM2        | 2020-01-26T18:30:08: PM2 log: SIGTERM timeout      : 1600
          PM2        | 2020-01-26T18:30:08: PM2 log: App [mm:0] starting in -fork mode-
          PM2        | 2020-01-26T18:30:08: PM2 log: App [mm:0] online
          0|mm       |      headers:
          0|mm       |       { Authorization:
          0|mm       |          'Basic OGQwYjVjMDhhMzM0NDVjMTgyZDZjOTAxYjcyNjc1MDM6YjYwNzBkYWM1MWI1NDhjMGE2M2E2NWE2ZjViNzJiN2Q=' },
          0|mm       |      form:
          0|mm       |       { grant_type: 'refresh_token',
          0|mm       |         refresh_token:
          0|mm       |          'AQA4iFw6XtIIqLbbHF8GUhTgYUvC-ZaSJxeavOWq7P67-aV8qSbXt8MLjYmVOv1NSONGNK0L-EuzZ5FvEfZo48fRd-tMX2ew9n6UDKF_cCSNNIxQUFBHzbDiQBwewYNq1PQ' },
          0|mm       |      json: true,
          0|mm       |      method: 'POST',
          0|mm       |      callback: [Function: RP$callback],
          0|mm       |      transform: undefined,
          0|mm       |      simple: true,
          0|mm       |      resolveWithFullResponse: false,
          0|mm       |      transform2xxOnly: false },
          0|mm       |   response: undefined }
          0|mm       | [21:59:38.878] [ERROR]  (node:7083) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [22:03:50.460] [ERROR]  (node:7812) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [22:27:30.468] [ERROR]  (node:11722) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [22:28:49.453] [ERROR]  WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:159
          0|mm       |                     			  ],
          0|mm       |                     			  ^
          0|mm       |
          0|mm       | SyntaxError: Unexpected token ]
          0|mm       |     at new Script (vm.js:74:7)
          0|mm       |     at createScript (vm.js:246:10)
          0|mm       |     at Object.runInThisContext (vm.js:298:10)
          0|mm       |     at Module._compile (internal/modules/cjs/loader.js:678:28)
          0|mm       |     at Object.Module._extensions..js (internal/modules/cjs/loader.js:722:10)
          0|mm       |     at Module.load (internal/modules/cjs/loader.js:620:32)
          0|mm       |     at tryModuleLoad (internal/modules/cjs/loader.js:559:12)
          0|mm       |     at Function.Module._load (internal/modules/cjs/loader.js:551:3)
          0|mm       |     at Module.require (internal/modules/cjs/loader.js:658:17)
          0|mm       |     at require (internal/modules/cjs/helpers.js:20:18)
          0|mm       | [22:30:26.812] [ERROR]  (node:12267) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [14:32:02.133] [ERROR]  (node:838) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [18:06:31.724] [ERROR]  (node:839) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | npm ERR! code ELIFECYCLE
          0|mm       | npm ERR! errno 1
          0|mm       | npm ERR! magicmirror@2.10.1 start: `./run-start.sh`
          0|mm       | npm ERR! Exit status 1
          0|mm       | npm ERR!
          0|mm       | npm ERR! Failed at the magicmirror@2.10.1 start script.
          0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          0|mm       |
          0|mm       | npm ERR! A complete log of this run can be found in:
          0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-25T17_12_34_594Z-debug.log
          0|mm       | [18:14:01.717] [ERROR]  (node:873) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | npm ERR!
          0|mm       |
          0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-25T17_14_35_178Z-debug.log
          0|mm       | [18:15:53.465] [ERROR]  (node:845) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:01:20.921] [ERROR]  (node:838) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:08:32.338] [ERROR]  (node:881) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:18:04.788] [ERROR]  (node:835) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:20:46.021] [ERROR]  (node:832) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:25:57.186] [ERROR]  (node:843) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | npm ERR!
          0|mm       |
          0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-25T19_43_35_693Z-debug.log
          0|mm       | [20:45:04.163] [ERROR]  (node:847) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | npm ERR!
          0|mm       |
          0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-25T20_04_37_922Z-debug.log
          0|mm       | [11:24:15.592] [ERROR]  (node:835) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [11:42:11.259] [ERROR]  (node:3798) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [11:44:27.449] [ERROR]  (node:4238) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | npm ERR!
          0|mm       |
          0|mm       | npm ERR!     /home/pi/.npm/_logs/2020-01-26T10_47_47_931Z-debug.log
          0|mm       | [11:49:10.926] [ERROR]  (node:887) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [14:34:38.124] [ERROR]  (node:839) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [20:24:31.753] [ERROR]  (node:847) [DEP0005] DeprecationWarning: Buffer() is deprecated due to security and usability issues. Please use the Buffer.alloc(), Buffer.allocUnsafe(), or Buffer.from() methods instead.
          0|mm       | [11:48:59.411] [LOG]    email helper started ...
          0|mm       | [11:48:59.412] [LOG]    Connecting socket for: MMM-SystemStats
          0|mm       | [11:48:59.414] [LOG]    Sockets connected & modules started ...
          0|mm       | [11:49:00.551] [LOG]    Launching application.
          0|mm       | [11:49:11.172] [LOG]    listening for emails...
          0|mm       | [11:49:15.096] [LOG]    Refreshed access token because it has expired. Expired at: 11:49:10 now is: 11:49:15
          0|mm       | [11:49:15.121] [LOG]    Refreshed access token because it has expired. Expired at: 12:49:15 now is: 11:49:15
          0|mm       | [11:49:15.245] [LOG]    Refreshed access token because it has expired. Expired at: 12:49:15 now is: 11:49:15
          0|mm       | [12:06:56.699] [LOG]    Shutting down server...
          0|mm       | [12:06:56.702] [LOG]    Stopping module helper: updatenotification
          0|mm       | [12:06:56.704] [LOG]    Stopping module helper: MMM-NowPlayingOnSpotify
          0|mm       | [12:06:56.706] [LOG]    Stopping module helper: MMM-Xbox
          0|mm       | [12:06:56.707] [LOG]    Stopping module helper: email
          0|mm       | [12:06:56.707] [LOG]    Stopping module helper: MMM-SystemStats
          0|mm       |
          0|mm       | > magicmirror@2.10.1 start /home/pi/MagicMirror
          0|mm       | > ./run-start.sh
          0|mm       |
          0|mm       | [14:34:17.324] [LOG]    Starting MagicMirror: v2.10.1
          0|mm       | [14:34:17.375] [LOG]    Loading config ...
          0|mm       | [14:34:17.398] [LOG]    Loading module helpers ...
          0|mm       | [14:34:17.403] [LOG]    No helper found for module: alert.
          0|mm       | [14:34:17.611] [LOG]    Initializing new module helper ...
          0|mm       | [14:34:17.614] [LOG]    Module helper loaded: updatenotification
          0|mm       | [14:34:17.617] [LOG]    No helper found for module: clock.
          0|mm       | [14:34:19.640] [LOG]    Initializing new module helper ...
          0|mm       | [14:34:19.641] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
          0|mm       | [14:34:19.643] [LOG]    No helper found for module: MMM-OpenmapWeather.
          0|mm       | [14:34:19.645] [LOG]    No helper found for module: weatherforecast.
          0|mm       | [14:34:23.595] [LOG]    Initializing new module helper ...
          0|mm       | [14:34:23.596] [LOG]    Module helper loaded: MMM-Xbox
          0|mm       | [14:34:24.092] [LOG]    Initializing new module helper ...
          0|mm       | [14:34:24.093] [LOG]    Module helper loaded: email
          0|mm       | [14:34:25.807] [LOG]    Initializing new module helper ...
          0|mm       | [14:34:25.808] [LOG]    Module helper loaded: MMM-SystemStats
          0|mm       | [14:34:25.809] [LOG]    All module helpers loaded.
          0|mm       | [14:34:25.812] [LOG]    Starting server on port 8080 ...
          0|mm       | [14:34:25.861] [LOG]    Server started ...
          0|mm       | [14:34:25.864] [LOG]    Connecting socket for: updatenotification
          0|mm       | [14:34:25.867] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
          0|mm       | [14:34:25.869] [LOG]    Connecting socket for: MMM-Xbox
          0|mm       | [14:34:25.872] [LOG]    Connecting socket for: email
          0|mm       | [14:34:25.874] [LOG]    email helper started ...
          0|mm       | [14:34:25.876] [LOG]    Connecting socket for: MMM-SystemStats
          0|mm       | [14:34:25.878] [LOG]    Sockets connected & modules started ...
          0|mm       | [14:34:26.844] [LOG]    Launching application.
          0|mm       | [14:34:38.307] [LOG]    listening for emails...
          0|mm       | [14:34:39.682] [LOG]    Refreshed access token because it has expired. Expired at: 14:34:38 now is: 14:34:39
          0|mm       | [14:34:39.822] [LOG]    Refreshed access token because it has expired. Expired at: 15:34:39 now is: 14:34:39
          0|mm       |
          0|mm       |
          0|mm       | [15:02:17.720] [LOG]    Starting MagicMirror: v2.10.1
          0|mm       | [15:02:17.766] [LOG]    Loading config ...
          0|mm       | [15:02:17.796] [LOG]    Loading module helpers ...
          0|mm       | [15:02:17.802] [LOG]    No helper found for module: alert.
          0|mm       | [15:02:18.037] [LOG]    Initializing new module helper ...
          0|mm       | [15:02:18.039] [LOG]    Module helper loaded: updatenotification
          0|mm       | [15:02:18.043] [LOG]    No helper found for module: clock.
          0|mm       | [15:02:19.854] [LOG]    Initializing new module helper ...
          0|mm       | [15:02:19.855] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
          0|mm       | [15:02:19.914] [LOG]    No helper found for module: MMM-OpenmapWeather.
          0|mm       | [15:02:20.036] [LOG]    No helper found for module: weatherforecast.
          0|mm       |
          0|mm       |
          0|mm       | [20:24:12.679] [LOG]    Starting MagicMirror: v2.10.1
          0|mm       | [20:24:12.711] [LOG]    Loading config ...
          0|mm       | [20:24:12.732] [LOG]    Loading module helpers ...
          0|mm       | [20:24:12.742] [LOG]    No helper found for module: alert.
          0|mm       | [20:24:15.688] [LOG]    Initializing new module helper ...
          0|mm       | [20:24:15.689] [LOG]    Module helper loaded: updatenotification
          0|mm       | [20:24:15.692] [LOG]    No helper found for module: clock.
          0|mm       | [20:24:16.909] [LOG]    Initializing new module helper ...
          0|mm       | [20:24:16.910] [LOG]    Module helper loaded: MMM-NowPlayingOnSpotify
          0|mm       | [20:24:16.912] [LOG]    No helper found for module: MMM-OpenmapWeather.
          0|mm       | [20:24:17.354] [LOG]    No helper found for module: weatherforecast.
          0|mm       | [20:24:18.833] [LOG]    Initializing new module helper ...
          0|mm       | [20:24:18.834] [LOG]    Module helper loaded: MMM-Xbox
          0|mm       | [20:24:19.312] [LOG]    Initializing new module helper ...
          0|mm       | [20:24:19.313] [LOG]    Module helper loaded: email
          0|mm       | [20:24:20.951] [LOG]    Initializing new module helper ...
          0|mm       | [20:24:20.952] [LOG]    Module helper loaded: MMM-SystemStats
          0|mm       | [20:24:20.953] [LOG]    All module helpers loaded.
          0|mm       | [20:24:20.956] [LOG]    Starting server on port 8080 ...
          0|mm       | [20:24:21.001] [LOG]    Server started ...
          0|mm       | [20:24:21.003] [LOG]    Connecting socket for: updatenotification
          0|mm       | [20:24:21.006] [LOG]    Connecting socket for: MMM-NowPlayingOnSpotify
          0|mm       | [20:24:21.009] [LOG]    Connecting socket for: MMM-Xbox
          0|mm       | [20:24:21.012] [LOG]    Connecting socket for: email
          0|mm       | [20:24:21.014] [LOG]    email helper started ...
          0|mm       | [20:24:21.016] [LOG]    Connecting socket for: MMM-SystemStats
          0|mm       | [20:24:21.017] [LOG]    Sockets connected & modules started ...
          0|mm       | [20:24:23.535] [LOG]    Launching application.
          0|mm       | [20:24:32.611] [LOG]    listening for emails...
          0|mm       | [20:24:34.134] [LOG]    Refreshed access token because it has expired. Expired at: 20:24:31 now is: 20:24:34
          0|mm       | [20:24:34.157] [LOG]    Refreshed access token because it has expired. Expired at: 21:24:34 now is: 20:24:34
          0|mm       | [20:24:34.285] [LOG]    Refreshed access token because it has expired. Expired at: 21:24:34 now is: 20:24:34
            hm… don’t see anything obvious
            tell us more about what happened right before this weird monitor stuff started happening
            as an example, my pi4 has been running great the last few months.
            i approved a system software update, and now the screen goes blank after some minutes…
            I have done all the screensaver things I can think of… nothing fixes it…
            (three other devices on TV continue to work great)…
            so, I made a new memory card for the same OS… and IT behaves properly… so hardware problem.
            something in the software update… still investigating 5 days of work so far…
            P 1 Reply Last reply
              payno4 @sdetweil
              So I think my problem is solved. I really don’t know what happened, but I wanted to make a video how the monitor goes on and off and suddenly there is no problem anymore. Maybe it’s because I removed the tape which festend the circuit board or because I straightened up the mirror, I don’t know. But nevertheless thank you very much for your help. :)
