    fail to update Todoist
    7 Posts 2 Posters 1.4k Views 2 Watching
      bdream
      All, my mirror ask for update Todoist so trying
      cd MagicMirror/modules/MMM-Todoist/
      git pull && npm install
      and I get the failure
      Aktualisiere 0b27f87..f9bedb8
      error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
      überschrieben werden:
              package-lock.json
      Bitte committen oder stashen Sie Ihre Änderungen, bevor Sie mergen.
      Abbruch
      means my local changes in package-lock.json would be overwritten in case of update.
      I can’t remember to change anything :confounded_face:
      How to fix it please?
      cheers, bdream
        bdream
        Thanks that works fine :smiling_face_with_open_mouth_closed_eyes:
        Other strange thing, meanwhile I got asked to update whole MM and I did.
        I had 2.10.0 run and got these output :confounded_face: upgrading from version 2.9.0 to 2.10.1
        bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
        the log will be /home/pi/MagicMirror/installers/upgrade.log
        No LSB modules are available.
        doing test run = false
        saving custom.css
        fetching latest revisions
        there are 4 local files that are different than the master repo
           modules/default/weatherforecast/weatherforecast.js
           package-lock.json
           vendor/package-lock.json
           vendor/vendor.js
        any *-lock.json files do not need to be saved
        do you want to save these files for later   (Y/n)?y
        npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
        > core-js@2.6.11 postinstall /home/pi/MagicMirror/node_modules/core-js
        > node -e "try{require('./postinstall')}catch(e){}"
        Thank you for using core-js ( https://github.com/zloirock/core-js ) for polyfilling JavaScript standard library!
        The project needs your help! Please consider supporting of core-js on Open Collective or Patreon:
        > https://opencollective.com/core-js
        > https://www.patreon.com/zloirock
        Also, the author of core-js ( https://github.com/zloirock ) is looking for a good job -)
        > console-stamp@0.2.9 postinstall /home/pi/MagicMirror/node_modules/console-stamp
        > node ./msg.js
        Attention
            Console-stamp version 3.0.0 Release Candidate is out. Install by using the tag '@next'. NB: Breaking changes.
            For more details goto: https://www.npmjs.com/package/console-stamp/v/next
        > electron@3.1.13 postinstall /home/pi/MagicMirror/node_modules/electron
        > node install.js
        Downloading tmp-13054-1-SHASUMS256.txt-3.1.13
        [============================================>] 100.0% of 4.79 kB (4.79 kB/s)
        > magicmirror@2.10.1 install /home/pi/MagicMirror
        > cd vendor && npm install
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        removed 3 packages and audited 220 packages in 18.516s
        found 5 vulnerabilities (4 low, 1 high)
          run `npm audit fix` to fix them, or `npm audit` for details
        > magicmirror@2.10.1 postinstall /home/pi/MagicMirror
        > sh untrack-css.sh && sh installers/postinstall/postinstall.sh && npm run install-fonts
        MagicMirror installation successful!
        > magicmirror@2.10.1 install-fonts /home/pi/MagicMirror
        > cd fonts && npm install
        audited 1 package in 13.139s
        found 0 vulnerabilities
        npm WARN grunt-stylelint@0.13.0 requires a peer of stylelint@^12.0.0 but none is installed. You must install peer dependencies yourself.
        added 196 packages from 191 contributors, removed 248 packages, updated 268 packages and audited 2766 packages in 1036.068s
        processing for module MMM-Carousel please wait
        audited 859 packages in 28.488s
        found 6 vulnerabilities (1 moderate, 5 high)
        processing complete for module MMM-Carousel
        processing for module MMM-Todoist please wait
        audited 63 packages in 5.206s
        processing complete for module MMM-Todoist
        processing for module MMM-PublicTransportHafas please wait
        audited 41 packages in 3.315s
        processing complete for module MMM-PublicTransportHafas
        audited 41 packages in 3.798s
        audited 41 packages in 3s
        restoring custom.css
        we stashed a set of files that appear changed from the latest repo versions. you should review them
        see installers/stashed_files for the list
        you can use git checkout stash@{0} -- filename to extract one file from the stash
        or git stash pop to restore them all
        WARNING..
        WARNING.. either will overlay the file just installed by the update
        WARNING..
        Over all I can close this thread
        @sdetweil Thanks fpor your fast help
        cheers, bdream
          sdetweil @bdream
          @bdream said in fail to update Todoist:
          package-lock.json
          this file is dynamically updated when u do an npm install.
          so you can delete it, then do the git pull…
            bdream
            saving custom.css
               package-lock.json
               vendor/vendor.js
            > node ./msg.js
            Attention
            > node install.js
            WARNING..
            WARNING..
            cheers, bdream
              bdream
              :smiling_face_with_sunglasses: how to get it makred as solved?
              cheers, bdream
                sdetweil @bdream
                @bdream on the post that u think solves the problem, click the 3 dots to the right
                  sdetweil @bdream
                  all looks good except for that one file…
                  if you modified it for some special purpose, you need to restore it from the stash.
                    bdream
                    @sdetweil you are right - thanks again.
                    That was the workaround cleaning up the header which shows the undefined in front of the city ;)
                    cheers, bdream
