    МММ-AssistantMk2 Error
    6 Posts 2 Posters 864 Views 2 Watching
    • K Offline
      Karalica-Kir
      Re: МММ-AssistantMk2
      alt text
      Who can tell you what’s wrong?
        A Former User
        hi, i think, MMM-hotword is not correctly configured for AMK2 v3.
        Give me your configuration and we solve this
        • K Offline
          Karalica-Kir
          /*************** AUTO GENERATED BY REMOTE CONTROL MODULE ***************/
          var config =
            address: '0.0.0.0',
            electronOptions: {},
            ipWhitelist: [],
            language: 'ru',
                module: 'MMM-PushBulletNotifications',
                header: 'Уведомления',
                position: 'bottom_right',
                  accessToken: '****',
                  localesDateTime: 'ru-RU',
                  noNotificationsMessage: 'Пока нет уведомлений',
                  onlyAllowCommandsFromSourceDevices: []
            module: "MMM-AssistantMk2",
              debug: true,
              ui: "Fullscreen", // or "Classic", "Classic2"
              assistantConfig: {
                projectId: "", // Required to use gaction.
                modelId: "", // (OPTIONAL for gaction)
                instanceId: "", // (OPTIONAL for gaction)
                latitude: 55.576620,
                longitude: 39.514338,
              responseConfig: {
                threshold: 0,
                useHTML5: true, // sound render by HTML5
                useScreenOutput: true,
                useAudioOutput: true,
                useChime: true,
                timer: 5000,
                myMagicWord: false,
                //Your prefer sound play program. By example, if you are running this on OSX, `afplay` could be available.
                playProgram: "mpg321", //needed if you don't use HTML5 sound render
                chime: {
                  beep: "beep.mp3",
                  error: "error.mp3",
                  continue: "continue.mp3",
                  open: "Google_beep_open.mp3",
                  close: "Google_beep_close.mp3",
                // false - animated icons, 'standby' - static icons only for standby state, true - all static icons
                useStaticIcons: false
              micConfig: { // put there configuration generated by auto-installer
                recorder: "rec",
                device: "plughw:1",
              customActionConfig: {
                autoMakeAction: false,
                autoUpdateAction: true, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                actionLocale: "en-US", // At this moment, multi-languages are not supported, sorry. Someday I'll work.
          //receripes: [ "with-MMM-Hotword.js", "with-MMM-TelegramBot.js" ],
              profiles: {
                "default": {
                  profileFile: "default.json",
                  lang: "en-US"
              addonsConfig: {}, //describe addons configuration
                module: 'MMM-GoogleFit',
                position: 'top_center',
                  stepGoal: 8000,
                  startOnMonday: 'true',
                  lastSevenDays: 'true',
                  stepCountLabel: 'true',
                  colors: [
                    '#EEEEEE',
                    '#1E88E5',
                    '#9CCC65',
                    '#5E35B1',
                    '#FFB300',
                    '#F4511E'
                module: 'MMM-LocalTemperature',
                header: 'Room Temperature',
                  sensorPin: 22
                module: 'MMM-Hotword',
                position: 'upper_third',
                  chimeOnFinish: null,
                  mic: {
                    recordProgram: 'arecord',
                    device: 'plughw:1'
                  models: [
                      hotwords: [
                        'jarvis',
                        'jarvis'
                      file: 'jarvis.umdl',
                      sensitivity: '0.8,0.8'
                  defaultCommand: {
                    notificationExec: {
                      notification: 'ASSISTANT_ACTIVATE'
                    afterRecordLimit: 0,
                    restart: true
                  recipes: [
                    'with-AMk2v3_Jarvis.js'
                  commands: {},
                  icons: {
                    waiting: 'uil-comment-message',
                    detected: 'uil-comment-exclamation',
                    finished: 'uil-comment-dots'
                  notifications: {
                    PAUSE: 'HOTWORD_PAUSE',
                    RESUME: 'HOTWORD_RESUME',
                    LISTENING: 'HOTWORD_LISTENING',
                    SLEEPING: 'HOTWORD_SLEEPING',
                    ERROR: 'HOTWORD_ERROR',
                    DETECTED: 'HOTWORD_DETECTED'
                module: 'weather',
                position: 'bottom_left',
                  weatherProvider: 'darksky',
                  showIndoorTemperature: 'true',
                  weatherEndpoint: '/forecast',
                  lat: '55.576978',
                  lon: '39.514094',
                  apiBase: 'https://cors-anywhere.herokuapp.com/https://api.darksky.net',
                  apiKey: '****'
                module: 'MMM-NowPlayingOnSpotify',
                position: 'top_right',
                  clientID: '****',
                  clientSecret: '****',
                  refreshToken: '****'
                module: 'MMM-Cursor',
                config: {}
                module: 'updatenotification',
                position: 'top_bar',
                config: {}
                module: 'clock',
                position: 'top_left',
                config: {}
                module: 'MMM-Remote-Control',
                  customCommand: {},
                  customMenu: 'custom_menu.json',
                  showModuleApiMenu: true,
                  apiKey: ''
                module: 'newsfeed',
                position: 'bottom_bar',
                  updateInterval: 15000,
                  lengthDescription: 10,
                  feeds: [
                      title: 'Яндекс.Новости',
                      url: 'https://news.yandex.ru/Russia/index.rss'
                  startTags: [],
                  endTags: [],
                  prohibitedWords: []
            paths: {
              modules: 'modules',
              vendor: 'vendor'
            A Former User
            can you try this config :
            var config =
              address: '0.0.0.0',
              ipWhitelist: [],
              language: 'ru',
                debug: true,
                assistantConfig: {
                responseConfig: {
                  useChime: true
                  recorder: "arecord",
                  device: "plughw:1",
                  autoUpdateAction:false, // in RPI, gaction CLI might have some trouble.(current version should be 2.2.4, but for linux-arm, Google haven't updated) so leave this as false in RPI. I don't know it is solved or not.
                recipes: [ "with-MMM-Hotword.js" ],
                profiles: {
                  "default": {
                    lang: "en-US"
                addons: false
                    stepGoal: 8000,
                    colors: [
                      '#EEEEEE',
                      '#1E88E5',
                      '#9CCC65',
                      '#5E35B1',
                      '#FFB300',
                      '#F4511E'
                    sensorPin: 22
                    mic: {
                      device: 'plughw:1'
                    recipes: [ 'with-AMk2v3_Jarvis.js' ],
                  module: 'weather',
                    lat: '55.576978',
                    lon: '39.514094',
                    apiKey: '****'
                    clientID: '****',
                  config: {}
                  config: {}
                  module: 'clock',
                  config: {}
                    customCommand: {},
                    apiKey: ''
                  module: 'newsfeed',
                    feeds: [
                    startTags: [],
                    endTags: [],
                    prohibitedWords: []
              paths: {
                modules: 'modules',
                vendor: 'vendor'
            little correct of your config match to AMk2 v.3.1.0-3
              A Former User
              @Karalica-Kir said in МММ-AssistantMk2 Error:
              note: if you use this, you assume you could be have somme error of configuration
              and take the default developer configuration.
              please use this wiki for AMk2 and this wiki for MMM-Hotword for complete configuration
              • K Offline
                Karalica-Kir @Guest
                @Bugsounet Thank you very much! It is WORKING!
