    Can't log in using default password...
    13 Posts 2 Posters 9.5k Views 2 Watching
    • T
      Turtle
      Anyone understand what I’m talking about or need more information? Please feel free to ask.
        sdetweil @Turtle
        @Turtle i understand, but don’t have any ideas for you…
        maybe edit the /boot/config.txt on another machine and set to autologon for user pi…
        then u can change the password
        • T
          Turtle
          Thank you @sdetweil, I’m just frustrating! I’m very new but I normally understand this stuff. I was working on this years ago but then stopped and just a few days ago decided to give it another shot and was updating everything which worked but couldn’t get Magic Mirror to work. So, I tried something someone posted on here and now I’m stuck. It’s looking like I have to reformat and do everything over again? Just frustrating and stuff.
          • T
            Turtle
            My common sense side actually won out. Decided to just reformat everything and start over. The last time I used this Raspberry Pi was literally like 1.5 years or so ago. So, I originally downloaded the Raspbian Sketch and saw that the latest was Buster. Plus, the same thing for MagicMirror. Better to just start fresh.
              sdetweil @Turtle
              @Turtle use my install script
              See https://github.com/sdetweil/MagicMirror_scripts/blob/master/README.md
              • T
                Turtle
                Thank you, @sdetweil for your script…do you have any other instructions on your script or PM2? I wasn’t really understanding PM2 but now I do but I don’t want it to start automatically right now until I get it ready. I’ll continue my search. Again, thank you.
                  sdetweil @Turtle
                  @Turtle no more info… pm2 will allow you to setup restart on boot when u want… here is the doc
                  https://www.npmjs.com/package/pm2
                  to add it later, use the fixuppm2 script
                  • T
                    Turtle
                    @sdetweil Thank you again!
                    • T
                      Turtle
                      @sdetweil - What do you mean by “to add it later”? When I ran your first script, it added the pm2. Does the fixuppm2 script update pm2 or just installs it? If I already have it, I don’t need to run the script, correct?
                        sdetweil @Turtle
                        @Turtle correct, if you have it already, don’t need to do it again
                        add it later… you said N during install and now changed your mind…
                        run the fixup script to add it and make it work…
                        same for the screen saver script… you said N during install and changed your mind…
                        • T
                          Turtle
                          @sdetweil, Thank you! I ran the scripts during the original install.
                            sdetweil @Turtle
                            @Turtle during install, the main script handles everything
