    Airplay 'Now Playing' module - help badly needed
    16 Posts 8 Posters 14.0k Views 9 Watching
      darrene
      I’ve really been struggling to write my first module.
      I’ve used Shairport-Sync to allow my mirror to act as an Airplay device - something which works a treat.
      I’ve added Shairport-Sync-Metadata-Reader in order to base64-decode the playing track metadata, which Shairport outputs in xml format to a FiFo file.
      What I’m trying to do is create a module to read the FiFo stream, base64-decode the values and it sees, and display a couple of the fields (Artist/Track)
      I think I’ll need a node-helper to do the watch/decode/filter and then send any Artist & Track fields it sees to the module which then displays it.
      I’ve created this which pops up the decoded result for a hardcoded string
      <script>
      var string = 'RGFycmVu';
      var decodedString = atob(string);
      window.alert(decodedString);
      </script>
      I’ve tried without success though to incoporate this as a function into a .js file, so that I can display my test-decode on the mirror.
      I’ve been looking through all the modules I can find to find something I can use as an example but no luck. I know I need to pass the decodedString variable somehow but have struggled to work out how :(
        darrene
        The first step of my module, which simply displays a base64-decoded string in the mirror reads like this.
        /* global Module */
        /* Magic Mirror
        * Module: base64
        * MIT Licensed.
        Module.register("base64",{
            // Default module config.
            defaults: {
                    text: "Hello World!"
          frombase64: function() {
            return decodedString;
            // Override dom generator.
            getDom: function() {
                    var decstr = this.frombase64
                    var msgstr = document.createTextNode(decstr);
                    wrapper.appendChild(msgstr);
                    return wrapper;
        It seems like it should work, but I get a literal string rather than a value returned…
          alexyak @darrene
          @darrene You’re missing parenthesis in your call to frombase64:
          this.frombase64();
          D 1 Reply Last reply Reply Quote 3
            darrene @alexyak
            Ah! Thanks so much @alexyak - that’s fantastic. I can now move forwards :)
            So parenthesis are needed to call the function and explicitly not pass it a parameter. Is that right?
              darrene
              So step 2, I have made a short javascript file that will read a fifo file and decode what it sees in the buffer.
              var fs = require('fs')
              var fifo = fs.createReadStream('shairport-sync-metadata')
              fifo.on('data', function(fifoHexBuffer) {
                  fifoHexBuffer = fifoHexBuffer.toString();
                  console.log(fifoHexBuffer)
              At the moment, the code runs once and stops once it reads. My next task is to have it continue, then I’ll have to make it into a node-helper script, to interact with my base64 decoder/display
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @darrene
                @darrene checkout the file watcher of the nodejs filesystem https://nodejs.org/docs/latest/api/fs.html#fs_class_fs_fswatcher
                  darrene
                  Luckily there is a fifo-js package available, which makes things super-easy!
                  npm install fifo-js
                  const FIFO = require('fifo-js')
                  let fifo = new FIFO('fifo-testfile')
                  var count = 1
                  while (count == 1)
                      let text = fifo.readSync(fifo)
                      console.log(text)
                  fifo.close()
                  I’m getting there. I have an IN and I have an OUT in javascript. Now the hard work of joining the two together - interpreting and the decoding the appropriate metadata begins!
                    darrene
                    So a bit more testing and things aren’t looking as rosy as I’d first thought. Before trying fifo-js, I’d experimented with the filesystem readStream - If i try looping that I end up with a java out of memory condition.
                    The fifo-js approach works with a fifo file that I echo things into to test, but doesn’t return anything while the Shairport service has it open for some reason?
                    There is a metadata reader script which I could use to read the metadata and parse it. I’ve compiled the executable and it runs fine. I should be able to call that from my javascript module through child process, right?
                      darrene
                      Hmm, using a child process doesn’t return anything either :(
                      The shairport metadata reader is a compiled C program which uses printf to return the metadata to the console:
                      pi@raspberrypi:~/fifo-js $ ~/shairport-sync-metadata-reader/shairport-sync-metadata-reader < /tmp/shairport-sync-metadata
                      Artist: "Sohn".
                      Title: "Tremors".
                      ^C
                      But I dont’ seem to be able to parse what’s being sent to stdout from my javascript
                      If anyone has any examples that work, I’d be grateful.
                      jdfraserJ 1 Reply Last reply Reply Quote 0
                      • jdfraserJ Offline
                        jdfraser @darrene
                        Hi @darrene ,
                        How did you ever make out with your module? I’ve started down the same path, I’m also using shairport-sync but in conjunction with forked-daapd (an airplay server for Raspbian).
                        As forked-daapd can also use mpd commands I’ve been trying to use komponist, which I’ve managed to make return the playing song, album, etc. print out to the console but as I’ve never really done any javascript before am trying to piece together building a module for MM.
                        If you’ve made any progress on your module, I’d love to see it as it may help me finish mine.
