    Help with MMM-ModuleSchedule to turn off monitor
    4 Posts 3 Posters 1.7k Views 3 Watching
      mlm198
      Hi All,
      I want to use MMM-ModuleSchedule and MMM-Remote switch off the monitor. I know remote is working as I can connect to it using my phone but when I get an error message when I start to use the schedule which is just a cut and paste job. Not sure what I am doing wrong but below is the code for the two modules along with the error message when starting MM.
      Thanks for any help.
      Matthew
              module: 'MMM-ModuleScheduler',
                  notification_schedule: [
                      // TURN THE MONITOR/SCREEN ON AT 07:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '30 6 * * *', payload: {action: "MONITORON"}},
                      // TURN THE MONITOR/SCREEN OFF AT 22:30 EVERY DAY
                      {notification: 'REMOTE_ACTION', schedule: '30 8 * * *', payload: {action: "MONITOROFF"}},
                      {notification: 'REMOTE_ACTION', schedule: '00 16 * * *', payload: {action: "MONITORON"}},
      				{notification: 'REMOTE_ACTION', schedule: '00 21 * * *', payload: {action: "MONITOROFF"}},
                      // RESTART THE MAGICMIRROR PROCESS AT 2am EVERY SUNDAY
                      {notification: 'REMOTE_ACTION', schedule: '0 2 * * SUN', payload: {action: "RESTART"}}
              module: 'MMM-Remote-Control',
              // position: 'top_right',
                  apiKey: ''
      This is the error message:
      16:43:32.896] [ERROR] { Error: Cannot find module ‘cron’
      at Module._resolveFilename (internal/modules/cjs/loader.js:602:15)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
      at Function.Module._load (internal/modules/cjs/loader.js:528:25)
      at Module.require (internal/modules/cjs/loader.js:658:17)
      at require (internal/modules/cjs/helpers.js:20:18)
      at Object. (/home/pi/MagicMirror/modules/MMM-ModuleScheduler/node_helper.js:11:15)
      at Object. (/home/pi/MagicMirror/modules/MMM-ModuleScheduler/node_helper.js:327:3)
      at Module._compile (internal/modules/cjs/loader.js:711:30)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:722:10) code: ‘MODULE_NOT_FOUND’ }
        sdetweil @mlm198
        @mlm198 cd to that module folder, and do
        npm install -save cron
        Looks like the module package.json doesn’t list that drpendency
          mlm198 @sdetweil
          @sdetweil thanks for the response and forgive my lack of knowledge but which of the folders listed?
          Matthew
          • F Offline
            fribse
            go to you ‘magicmirror’ folder, then to modules, and then to the MMM-Remote-Control folder and run ‘npm install’, I think you forgot that.
