    Acrylic Sheet
    6 Posts 2 Posters 1.8k Views 2 Watching
      Peter Leemon
      Hi all just wondering would this be ok to use for a MM as its available here in australia?
      https://www.bunnings.com.au/suntuf-900-x-600-x-3mm-silver-flat-acrylic-mirror-sheet_p1011177
      • 4 Offline
        404ryannotfound
        Hey Peter, good find, I’ll go down and look, pretty expensive though for what it is.
        If you can peel back the tape to preview, get your Mobile phone, change settings to dark and display something simple like a notepad file.
        I’ll try to get down to my local and do the same.
          Peter Leemon
          Yes I know what you mean as like everyone in Australia trying to find local suppliers that don’t break the bank a;pmg with suitability and durability.
          4 1 Reply Last reply Reply Quote 0
          • 4 Offline
            404ryannotfound @Peter Leemon
            @Peter-Leemon
            Hey, I just got an online quote from here: https://www.plasticwholesale.com.au/
            I’m in Perth, but they have a few other places.
            The quote for cut (550mm x 320mm) is $34.72, so a bit cheaper, AND you can get the exact cut you want.\Worth a thought, plus you could probably go in there and test an offcut (or even see if they have offcuts for sale).
            I looked on Evilbay for two way tinting, so that’s possibly an option if you just put onto standard cheap perspex.
            UPDATE… They have minimum charge for Bulk… DOH… She mentioned to contact Mulford
            https://www.mulfordplastics.com.au/
              Peter Leemon
              Hi, just looked on the plastic wholesale website and noticed this under the quotation,
              Kindly note that there is an overall product value minimum charge for this particular selection of $305.00 + GST. Freight and transit warranty (if applicable) are in addition to this minimum. If your aggregated total order for this product colour and thickness combination is above this minimum, then your calculated values will apply instead of the minimum. so may ring them tomorrow and see what the price really would be.
              • 4 Offline
                @Peter-Leemon
                heya,
                I just got off the phone from Mulfords, he has a 1200 occut here in perth, will sell a 550 x 320 for $10
                looks like they have places in each state: https://www.mulfordplastics.com.au/contact-us/
                Worth a call…
