    USB Camera use as wake up sensor
    wakeupusb camera
    7 Posts 3 Posters 3.0k Views 3 Watching
      Miked180
      at first my english is not the best :D
      Can i use a usb Camera to wake up the mirror and after x Time if nobody in front of camera go in standby,
      who can i make this if its possible code; module ??
      At second can i use the camera image on the mirror too.
        A Former User @Miked180
        @Miked180
        There be already.
        https://github.com/rejas/MMM-MotionDetector
        https://github.com/alexyak/motiondetector
        Hmmm years ago I tested these 2 modules and at that time both worked. But I’m not sure they still be valid with current MM.
          Miked180
          Thanks,
          1. why i need the proxyserver here ? --> forget it, who can red exactly the readme i see the solution for this :D
          2. mus i config the webcam in raspberry , usb port or other ?
          So i install motion detector and all config in the tutorial, plug in camera on usb and it works ??
            Miked180
            It works, fine , thanks
              @Miked180
              Which module works?
                Miked180
                https://github.com/rejas/MMM-MotionDetector.
                But now i have seen if its longer time off (over 30 mins) , i cant wake up . I must restart
                Is there any Standby mode on raspberry i should deactivate ( but i cant activate wil keyboard too )
                i see that i dont have disable the screensaver.
                My Problem is that i have not the folder / etc/ kbd /
                Where can i get this folder ??
                  sdetweil @Miked180
                  @Miked180 see my response in the other topic…
                  i wrote a module for using a webcam to control screen…
                  https://github.com/sdetweil/MMM-SleepWake
                  it uses a linux module to detect camera motion
                  sudo apt-get install motion
                  I didn’t want to write and maintain code to interface to an unlimited list of potential cameras…
                  you can also screen capture on movement, or movie record on movement
                  MMM-SleepWake supports tvservice/dpms and module hiding as ways to blank the screen
                  (none of my TVs support dpms, and most of my MM systems are not PIs (which is only where tvservice works)
