Solved no /etc/kbd/config Folder/File
now i see the mirror, i wait few minutes
Now i got a black screen.
/home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
0|MagicMir | npm ERR! code ELIFECYCLE
0|MagicMir | npm ERR! errno 1
0|MagicMir | npm ERR! magicmirror@2.10.1 start:./run-start.sh
0|MagicMir | npm ERR! Exit status 1
0|MagicMir | npm ERR! Failed at the magicmirror@2.10.1 start script.
0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
0|MagicMir |
0|MagicMir | npm ERR! A complete log of this run can be found in:
0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.logfrom 283Z-debug.log :
0|MagicMir |
0|MagicMir | npm ERR! /home/pi/.npm/_logs/2020-03-11T17_47_10_283Z-debug.logafter restart raspberry i see the mirror
@Miked180 before restart pi, do with keyboard on pi…
alt-spacebar, n
see if MM window will minimize
also, setup ssh on pi, and ssh from windows to pi to examine…
xset q setterm -blank 0 -powerdown 0
from here https://wiki.archlinux.org/index.php/Display_Power_Management_Signaling
in ssh terminal session, may have to do export DISPLAY=:0
thanks for your help,
der is no file in /etc/X11/xorg.conf.d
ist better to make a new setup ??
in ssh terminal session, may have to do export DISPLAY=:0 ?
@Miked180 said in no /etc/kbd/config Folder/File:
where does that happen?
tis is in your link . or on the flase position in the page ?
Sorry i dont know about this .
Im learning since short time but im not so good as you :-=
UPDATE : i geht : setterm: terminal xterm-256color does not support --blank
if i use your command
@Miked180 sorry, no idea… i thought that was one of the best sites for this kind of info
i make now a new setpu, its better and cleaner, thansk very much for your big support
