    Install problems
    17 Posts 2 Posters 3.8k Views 2 Watching
      sdetweil @Pielo
      @Pielo please run the install script from here
      Have to delete MagicMirror folder first
        Pielo
        @Pielo said in Install problems:
        . I have try the automatic installer and the manuell installer. The errors are the same. Can someone tell me, what I doing wrong?
        thanks for your answer. I have install Raspbian a new. At next, i install all updates and at last the MagicMirro. But this is the same errors. What can i do now?
        pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
        $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
        $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
        $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
        $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
        $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
        $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
        \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                \______/
        install log being saved to /home/pi/install.log
        Updating packages ...
        Installing helper tools ...
        Node.js is not installed.
        Installing Node.js ...
        Warning: apt-key output should not be parsed (stdout is not a terminal)
        Paketlisten werden gelesen... Fertig
        Abhängigkeitsbaum wird aufgebaut.
        Statusinformationen werden eingelesen.... Fertig
        Die folgenden NEUEN Pakete werden installiert:
          nodejs
        0 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 14,6 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 77,3 MB Plattenplatz zusätzlich benutzt.
        Holen:1 https://deb.nodesource.com/node_10.x buster/main armhf nodejs armhf 10.19.0-1nodesource1 [14,6 MB]
        Es wurden 14,6 MB in 13 s geholt (1.119 kB/s).
        Vormals nicht ausgewähltes Paket nodejs wird gewählt.
        (Lese Datenbank ... 93551 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../nodejs_10.19.0-1nodesource1_armhf.deb ...
        Entpacken von nodejs (10.19.0-1nodesource1) ...
        nodejs (10.19.0-1nodesource1) wird eingerichtet ...
        Trigger für man-db (2.8.5-2) werden verarbeitet ...
        node version is
        Node.js installation Done! version=v10.19.0
        Minimum npm version: V6.0.0
        Installed npm version: V6.13.4
        No npm upgrade necessary.
        Cloning MagicMirror ...
        Klone nach 'MagicMirror' ...
        remote: Enumerating objects: 331, done.
        remote: Counting objects: 100% (331/331), done.
        remote: Compressing objects: 100% (295/295), done.
        remote: Total 331 (delta 42), reused 194 (delta 23), pack-reused 0
        Empfange Objekte: 100% (331/331), 676.44 KiB | 1.12 MiB/s, Fertig.
        Löse Unterschiede auf: 100% (42/42), Fertig.
        Cloning MagicMirror Done!
        bash: Zeile 296: [: !-e: Einstelliger (unärer) Operator erwartet.
        Installing dependencies ...
        npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
        npm WARN deprecated @types/vfile-message@2.0.0: This is a stub types definition. vfile-message provides its own type definitions, so you do not need this installed.
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: inherits@2.0.4 (node_modules/inherits):
        npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/inherits' -> '/home/pi/MagicMirror/node_modules/.inherits.DELETE'
        npm ERR! code ENOENT
        npm ERR! syscall rename
        npm ERR! path /home/pi/MagicMirror/node_modules/minimist
        npm ERR! dest /home/pi/MagicMirror/node_modules/.minimist.DELETE
        npm ERR! errno -2
        npm ERR! enoent ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/minimist' -> '/home/pi/MagicMirror/node_modules/.minimist.DELETE'
        npm ERR! enoent This is related to npm not being able to find a file.
        npm ERR! enoent
        npm ERR!     /home/pi/.npm/_logs/2020-03-13T13_59_34_858Z-debug.log
        Unable to install dependencies!
        pi@raspberrypi:~ $
          sdetweil @Pielo
          thanks for the great info…
          can u remove the MagicMirror folder and try the install script again…
          seems npm gets confused by the old package-lock.json file
          I m testing it too now
            Pielo
            :weary_face:
            Its the same errors. Do you have an other idea please?
                                    \______/
            Minimum Node version: v10.1.0
            Installed Node version: v10.19.0
            No Node.js upgrade necessary.
            Empfange Objekte: 100% (331/331), 676.44 KiB | 1015.00 KiB/s, Fertig.
            npm WARN deprecated rrule-alt@2.2.8: Please use rrule instead
            npm WARN deprecated left-pad@1.3.0: use String.prototype.padStart()
            npm WARN deprecated webdriverio@4.14.4: outdated version, please use @next
            npm WARN deprecated core-js@2.6.11: core-js@<3 is no longer maintained and not recommended for usage due to the number of issues. Please, upgrade your dependencies to the actual version of core-js@3.
            npm ERR! path /home/pi/MagicMirror/node_modules/after
            npm ERR! dest /home/pi/MagicMirror/node_modules/.after.DELETE
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/after' -> '/home/pi/MagicMirror/node_modules/.after.DELETE'
            npm ERR! enoent
            npm ERR!     /home/pi/.npm/_logs/2020-03-13T16_17_07_011Z-debug.log
                                    \______/
            Empfange Objekte: 100% (331/331), 676.44 KiB | 1.56 MiB/s, Fertig.
            npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @types/node@10.17.17 (node_modules/@types/node):
            npm WARN enoent SKIPPING OPTIONAL DEPENDENCY: ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/@types/node' -> '/home/pi/MagicMirror/node_modules/@types/.node.DELETE'
            npm ERR! path /home/pi/MagicMirror/node_modules/ansi-styles
            npm ERR! dest /home/pi/MagicMirror/node_modules/.ansi-styles.DELETE
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/ansi-styles' -> '/home/pi/MagicMirror/node_modules/.ansi-styles.DELETE'
            npm ERR! enoent
            npm ERR!     /home/pi/.npm/_logs/2020-03-13T16_19_14_063Z-debug.log
            pi@raspberrypi:~ $
              sdetweil @Pielo
              @Pielo sadly the only time we have seen weird behavior like this, the SD card is failing…
                Pielo
                Thank you for your help. I buy a new card and try it.
                  sdetweil @Pielo
                  @Pielo when u get a chance, please let us know… I installed twice and both worked ok… one to sd card, one to disk drive (on laptop)
                    Pielo @sdetweil
                    soo i have tested on a ohter SD card, but its a similar error. (See in the terminal box.) The next attempt is, i load the Raspbian-image again form the Raspberry.org website and test it on a ohter Raspberry. I will report, if i try this.
                    Terminal Box
                                            \______/
                      nodejs
                    Es wurden 14,6 MB in 6 s geholt (2.478 kB/s).
                    node version is
                    Empfange Objekte: 100% (331/331), 676.44 KiB | 1.71 MiB/s, Fertig.
                    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                    npm WARN deprecated mkdirp@0.5.3: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
                    npm ERR! path /home/pi/MagicMirror/node_modules/async-limiter
                    npm ERR! dest /home/pi/MagicMirror/node_modules/.async-limiter.DELETE
                    npm ERR! errno -2
                    npm ERR! enoent ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/async-limiter' -> '/home/pi/MagicMirror/node_modules/.async-limiter.DELETE'
                    npm ERR! enoent
                    npm ERR!     /home/pi/.npm/_logs/2020-03-18T07_36_56_451Z-debug.log
                                            \______/
                    npm ERR! path /home/pi/MagicMirror/node_modules/error-ex
                    npm ERR! dest /home/pi/MagicMirror/node_modules/.error-ex.DELETE
                    npm ERR! errno -2
                    npm ERR! enoent ENOENT: no such file or directory, rename '/home/pi/MagicMirror/node_modules/error-ex' -> '/home/pi/MagicMirror/node_modules/.error-ex.DELETE'
                    npm ERR! enoent
                    npm ERR!     /home/pi/.npm/_logs/2020-03-18T11_26_50_304Z-debug.log
                    pi@raspberrypi:~ $
                      sdetweil @Pielo
                      @Pielo thanks for the update. We have not seen this before.
                      The install says it is using the very latest node version, 10.19.
                      But each time u run the install it is a different file causing the problem, which is odd.
                      I’ll do some more research and let you know
                        Pielo @sdetweil
                        Thank you very much. I’m starting to despair. :loudly_crying_face:
                        I take the balenaEtcher for witing the SDcard. What program are using you?
                          sdetweil @Pielo
                          @Pielo same etcher
                            Pielo
                            :man_dancing_light_skin_tone: :man_dancing_light_skin_tone: :woman_dancing_light_skin_tone: :woman_dancing_light_skin_tone:
                            It works…
                            • I have downloaded a new image from this webpage (https://www.heise.de/download/product/raspbian-91329) it’s a .img-file.
                            • I have write the SD-card with the win32diskimager
                            • I don’t make updates on the first start configuration on raspbian
                            Thank you for your good help
                              sdetweil @Pielo
                              @Pielo great news!! thank you for the feedback
                                sdetweil @Pielo
                                @Pielo can I see your new ~/install.log?
                                u are installing on stretch vs buster…
                                  Pielo @sdetweil
                                  @sdetweil said in Install problems:
                                  Sorry for my late replay…
                                  install starting  - Fr Mär 20 16:02:47 CET 2020
                                  installing on armv7l processor system
                                  the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                                  Holen:1 http://archive.raspberrypi.org/debian buster InRelease [25,1 kB] Holen:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15,0 kB] Holen:3 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages [13,0 MB] Holen:4 http://archive.raspberrypi.org/debian buster/main armhf Packages [279 kB] Es wurden 13,3 MB in 17 s geholt (775 kB/s). Paketlisten werden gelesen...
                                  apt-get update  completed ok
                                  apt-get upgrade  started
                                  apt upgrade result =rc=0 Paketlisten werden gelesen...
                                  Abhängigkeitsbaum wird aufgebaut....
                                  Paketaktualisierung (Upgrade) wird berechnet...
                                  Die folgenden Pakete sind zurückgehalten worden:
                                    binutils binutils-arm-linux-gnueabihf binutils-common libbinutils
                                  Die folgenden Pakete werden aktualisiert (Upgrade):
                                    curl firmware-atheros firmware-brcm80211 firmware-libertas
                                    firmware-misc-nonfree firmware-realtek gldriver-test libcurl3-gnutls
                                    libcurl4 libjavascriptcoregtk-4.0-18 libpam-systemd libpq5 libsystemd0
                                    libudev1 libwebkit2gtk-4.0-37 lxinput lxplug-cputemp lxplug-network
                                    lxplug-ptbatt pcmanfm pipanel piwiz python-pil python3-pil
                                    python3-pil.imagetk raspberrypi-ui-mods raspi-config rc-gui
                                    realvnc-vnc-server realvnc-vnc-viewer rp-prefapps rpi-eeprom
                                    rpi-eeprom-images systemd systemd-sysv udev
                                  36 aktualisiert, 0 neu installiert, 0 zu entfernen und 4 nicht aktualisiert.
                                  Es müssen 45,5 MB an Archiven heruntergeladen werden.
                                  Nach dieser Operation werden 1.581 kB Plattenplatz zusätzlich benutzt.
                                  Holen:1 http://archive.raspberrypi.org/debian buster/main armhf firmware-atheros all 1:20190114-1+rpt5 [3.887 kB]
                                  Holen:4 http://mirror.netcologne.de/raspbian/raspbian buster/main armhf libsystemd0 armhf 241-7~deb10u3+rpi1 [305 kB]
                                  Holen:6 http://archive.raspberrypi.org/debian buster/main armhf firmware-brcm80211 all 1:20190114-1+rpt5 [4.360 kB]
                                  Holen:5 http://mirror.de.leaseweb.net/raspbian/raspbian buster/main armhf systemd armhf 241-7~deb10u3+rpi1 [3.251 kB]
                                  Holen:10 http://archive.raspberrypi.org/debian buster/main armhf firmware-libertas all 1:20190114-1+rpt5 [3.423 kB]
                                  Holen:13 http://archive.raspberrypi.org/debian buster/main armhf firmware-misc-nonfree all 1:20190114-1+rpt5 [3.071 kB]
                                  Holen:15 http://archive.raspberrypi.org/debian buster/main armhf firmware-realtek all 1:20190114-1+rpt5 [495 kB]
                                  Holen:16 http://archive.raspberrypi.org/debian buster/main armhf gldriver-test all 0.6 [3.580 B]
                                  Holen:17 http://archive.raspberrypi.org/debian buster/main armhf lxinput armhf 0.3.5-1+rpi7 [60,8 kB]
                                  Holen:18 http://archive.raspberrypi.org/debian buster/main armhf lxplug-cputemp armhf 0.3 [8.396 B]
                                  Holen:19 http://archive.raspberrypi.org/debian buster/main armhf raspi-config all 20200226 [25,3 kB]
                                  Holen:20 http://archive.raspberrypi.org/debian buster/main armhf rc-gui armhf 1.38 [45,4 kB]
                                  Holen:22 http://archive.raspberrypi.org/debian buster/main armhf lxplug-network armhf 0.19 [32,0 kB]
                                  Holen:23 http://archive.raspberrypi.org/debian buster/main armhf lxplug-ptbatt armhf 0.9 [13,2 kB]
                                  Holen:24 http://archive.raspberrypi.org/debian buster/main armhf pcmanfm armhf 1.3.1-1+rpt19 [282 kB]
                                  Holen:25 http://archive.raspberrypi.org/debian buster/main armhf pipanel armhf 1:1.4 [22,3 kB]
                                  Holen:26 http://archive.raspberrypi.org/debian buster/main armhf piwiz armhf 0.11 [42,5 kB]
                                  Holen:27 http://archive.raspberrypi.org/debian buster/main armhf realvnc-vnc-server armhf 6.7.1.42348 [7.071 kB]
                                  Holen:21 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf libjavascriptcoregtk-4.0-18 armhf 2.26.4-1~deb10u2+rpi1 [2.258 kB]
                                  Holen:32 http://archive.raspberrypi.org/debian buster/main armhf realvnc-vnc-viewer armhf 6.20.113.42303 [2.510 kB]
                                  Holen:3 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpam-systemd armhf 241-7~deb10u3+rpi1 [193 kB]
                                  Holen:7 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf udev armhf 241-7~deb10u3+rpi1 [1.252 kB]
                                  Holen:33 http://archive.raspberrypi.org/debian buster/main armhf rp-prefapps armhf 0.18 [187 kB]
                                  Holen:34 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom-images all 5.1-1 [360 kB]
                                  Holen:35 http://archive.raspberrypi.org/debian buster/main armhf rpi-eeprom all 5.1-1 [17,5 kB]
                                  Holen:36 http://archive.raspberrypi.org/debian buster/main armhf raspberrypi-ui-mods all 1.20200218 [322 kB]
                                  Holen:30 http://mirror1.hs-esslingen.de/pub/Mirrors/archive.raspbian.org/raspbian buster/main armhf python3-pil.imagetk armhf 5.4.1-2+deb10u1 [65,0 kB]
                                  Holen:8 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libudev1 armhf 241-7~deb10u3+rpi1 [143 kB]
                                  Holen:11 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl4 armhf 7.64.0-4+deb10u1 [294 kB]
                                  Holen:12 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libcurl3-gnutls armhf 7.64.0-4+deb10u1 [292 kB]
                                  Holen:14 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libwebkit2gtk-4.0-37 armhf 2.26.4-1~deb10u2+rpi1 [9.933 kB]
                                  Holen:2 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf systemd-sysv armhf 241-7~deb10u3+rpi1 [99,9 kB]
                                  Holen:28 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf libpq5 armhf 11.7-0+deb10u1 [151 kB]
                                  Holen:29 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python-pil armhf 5.4.1-2+deb10u1 [364 kB]
                                  Holen:31 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian buster/main armhf python3-pil armhf 5.4.1-2+deb10u1 [364 kB]
                                  Holen:9 http://ftp.gwdg.de/pub/linux/debian/raspbian/raspbian buster/main armhf curl armhf 7.64.0-4+deb10u1 [254 kB]
                                  apt-listchanges: Changelogs werden gelesen...
                                  Es wurden 45,5 MB in 11 s geholt (4.099 kB/s).
                                  (Lese Datenbank ...
                                  (Lese Datenbank ... 5%
                                  (Lese Datenbank ... 10%
                                  (Lese Datenbank ... 15%
                                  (Lese Datenbank ... 20%
                                  (Lese Datenbank ... 25%
                                  (Lese Datenbank ... 30%
                                  (Lese Datenbank ... 35%
                                  (Lese Datenbank ... 40%
                                  (Lese Datenbank ... 45%
                                  (Lese Datenbank ... 50%
                                  (Lese Datenbank ... 55%
                                  (Lese Datenbank ... 60%
                                  (Lese Datenbank ... 65%
                                  (Lese Datenbank ... 70%
                                  (Lese Datenbank ... 75%
                                  (Lese Datenbank ... 80%
                                  (Lese Datenbank ... 85%
                                  (Lese Datenbank ... 90%
                                  (Lese Datenbank ... 95%
                                  (Lese Datenbank ... 100%
                                  (Lese Datenbank ... 153919 Dateien und Verzeichnisse sind derzeit installiert.)
                                  Vorbereitung zum Entpacken von .../systemd-sysv_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von systemd-sysv (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  Vorbereitung zum Entpacken von .../libpam-systemd_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von libpam-systemd:armhf (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  Vorbereitung zum Entpacken von .../libsystemd0_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von libsystemd0:armhf (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  libsystemd0:armhf (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  (Lese Datenbank ...
                                  Vorbereitung zum Entpacken von .../systemd_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von systemd (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  Vorbereitung zum Entpacken von .../udev_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von udev (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  Vorbereitung zum Entpacken von .../libudev1_241-7~deb10u3+rpi1_armhf.deb ...
                                  Entpacken von libudev1:armhf (241-7~deb10u3+rpi1) über (241-7~deb10u2+rpi1) ...
                                  libudev1:armhf (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  (Lese Datenbank ...
                                  Vorbereitung zum Entpacken von .../00-curl_7.64.0-4+deb10u1_armhf.deb ...
                                  Entpacken von curl (7.64.0-4+deb10u1) über (7.64.0-4) ...
                                  Vorbereitung zum Entpacken von .../01-libcurl4_7.64.0-4+deb10u1_armhf.deb ...
                                  Entpacken von libcurl4:armhf (7.64.0-4+deb10u1) über (7.64.0-4) ...
                                  Vorbereitung zum Entpacken von .../02-firmware-atheros_1%3a20190114-1+rpt5_all.deb ...
                                  Entpacken von firmware-atheros (1:20190114-1+rpt5) über (1:20190114-1+rpt4) ...
                                  Vorbereitung zum Entpacken von .../03-firmware-brcm80211_1%3a20190114-1+rpt5_all.deb ...
                                  Entpacken von firmware-brcm80211 (1:20190114-1+rpt5) über (1:20190114-1+rpt4) ...
                                  Vorbereitung zum Entpacken von .../04-firmware-libertas_1%3a20190114-1+rpt5_all.deb ...
                                  Entpacken von firmware-libertas (1:20190114-1+rpt5) über (1:20190114-1+rpt4) ...
                                  Vorbereitung zum Entpacken von .../05-firmware-misc-nonfree_1%3a20190114-1+rpt5_all.deb ...
                                  Entpacken von firmware-misc-nonfree (1:20190114-1+rpt5) über (1:20190114-1+rpt4) ...
                                  Vorbereitung zum Entpacken von .../06-firmware-realtek_1%3a20190114-1+rpt5_all.deb ...
                                  Entpacken von firmware-realtek (1:20190114-1+rpt5) über (1:20190114-1+rpt4) ...
                                  Vorbereitung zum Entpacken von .../07-gldriver-test_0.6_all.deb ...
                                  Entpacken von gldriver-test (0.6) über (0.4) ...
                                  Vorbereitung zum Entpacken von .../08-libcurl3-gnutls_7.64.0-4+deb10u1_armhf.deb ...
                                  Entpacken von libcurl3-gnutls:armhf (7.64.0-4+deb10u1) über (7.64.0-4) ...
                                  Vorbereitung zum Entpacken von .../09-libwebkit2gtk-4.0-37_2.26.4-1~deb10u2+rpi1_armhf.deb ...
                                  Entpacken von libwebkit2gtk-4.0-37:armhf (2.26.4-1~deb10u2+rpi1) über (2.26.3-1~deb10u1+rpi1) ...
                                  Vorbereitung zum Entpacken von .../10-libjavascriptcoregtk-4.0-18_2.26.4-1~deb10u2+rpi1_armhf.deb ...
                                  Entpacken von libjavascriptcoregtk-4.0-18:armhf (2.26.4-1~deb10u2+rpi1) über (2.26.3-1~deb10u1+rpi1) ...
                                  Vorbereitung zum Entpacken von .../11-libpq5_11.7-0+deb10u1_armhf.deb ...
                                  Entpacken von libpq5:armhf (11.7-0+deb10u1) über (11.6-0+deb10u1) ...
                                  Vorbereitung zum Entpacken von .../12-lxinput_0.3.5-1+rpi7_armhf.deb ...
                                  Entpacken von lxinput (0.3.5-1+rpi7) über (0.3.5-1+rpi6) ...
                                  Vorbereitung zum Entpacken von .../13-lxplug-cputemp_0.3_armhf.deb ...
                                  Entpacken von lxplug-cputemp (0.3) über (0.1) ...
                                  Vorbereitung zum Entpacken von .../14-raspi-config_20200226_all.deb ...
                                  Entpacken von raspi-config (20200226) über (20200207) ...
                                  Vorbereitung zum Entpacken von .../15-rc-gui_1.38_armhf.deb ...
                                  Entpacken von rc-gui (1.38) über (1.36) ...
                                  Vorbereitung zum Entpacken von .../16-lxplug-network_0.19_armhf.deb ...
                                  Entpacken von lxplug-network (0.19) über (0.18) ...
                                  Vorbereitung zum Entpacken von .../17-lxplug-ptbatt_0.9_armhf.deb ...
                                  Entpacken von lxplug-ptbatt (0.9) über (0.8) ...
                                  Vorbereitung zum Entpacken von .../18-pcmanfm_1.3.1-1+rpt19_armhf.deb ...
                                  Entpacken von pcmanfm (1.3.1-1+rpt19) über (1.3.1-1+rpt18) ...
                                  Vorbereitung zum Entpacken von .../19-pipanel_1%3a1.4_armhf.deb ...
                                  Entpacken von pipanel (1:1.4) über (1:1.3) ...
                                  Vorbereitung zum Entpacken von .../20-piwiz_0.11_armhf.deb ...
                                  Entpacken von piwiz (0.11) über (0.9) ...
                                  Vorbereitung zum Entpacken von .../21-python-pil_5.4.1-2+deb10u1_armhf.deb ...
                                  Entpacken von python-pil:armhf (5.4.1-2+deb10u1) über (5.4.1-2) ...
                                  Vorbereitung zum Entpacken von .../22-python3-pil.imagetk_5.4.1-2+deb10u1_armhf.deb ...
                                  Entpacken von python3-pil.imagetk:armhf (5.4.1-2+deb10u1) über (5.4.1-2) ...
                                  Vorbereitung zum Entpacken von .../23-python3-pil_5.4.1-2+deb10u1_armhf.deb ...
                                  Entpacken von python3-pil:armhf (5.4.1-2+deb10u1) über (5.4.1-2) ...
                                  Vorbereitung zum Entpacken von .../24-realvnc-vnc-server_6.7.1.42348_armhf.deb ...
                                  Entpacken von realvnc-vnc-server (6.7.1.42348) über (6.6.0.41949) ...
                                     yy
                                  Vorbereitung zum Entpacken von .../25-realvnc-vnc-viewer_6.20.113.42303_armhf.deb ...
                                  Entpacken von realvnc-vnc-viewer (6.20.113.42303) über (6.19.923.41938) ...
                                  Vorbereitung zum Entpacken von .../26-rp-prefapps_0.18_armhf.deb ...
                                  Entpacken von rp-prefapps (0.18) über (0.17) ...
                                  Vorbereitung zum Entpacken von .../27-rpi-eeprom-images_5.1-1_all.deb ...
                                  Entpacken von rpi-eeprom-images (5.1-1) über (4.0-1) ...
                                  Vorbereitung zum Entpacken von .../28-rpi-eeprom_5.1-1_all.deb ...
                                  Entpacken von rpi-eeprom (5.1-1) über (4.0-1) ...
                                  Vorbereitung zum Entpacken von .../29-raspberrypi-ui-mods_1.20200218_all.deb ...
                                  Entpacken von raspberrypi-ui-mods (1.20200218) über (1.20200127) ...
                                  rp-prefapps (0.18) wird eingerichtet ...
                                  gldriver-test (0.6) wird eingerichtet ...
                                  pcmanfm (1.3.1-1+rpt19) wird eingerichtet ...
                                  lxplug-ptbatt (0.9) wird eingerichtet ...
                                  firmware-atheros (1:20190114-1+rpt5) wird eingerichtet ...
                                  firmware-misc-nonfree (1:20190114-1+rpt5) wird eingerichtet ...
                                  update-initramfs: deferring update (trigger activated)
                                  libpq5:armhf (11.7-0+deb10u1) wird eingerichtet ...
                                  libjavascriptcoregtk-4.0-18:armhf (2.26.4-1~deb10u2+rpi1) wird eingerichtet ...
                                  libcurl3-gnutls:armhf (7.64.0-4+deb10u1) wird eingerichtet ...
                                  systemd (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  python-pil:armhf (5.4.1-2+deb10u1) wird eingerichtet ...
                                  lxinput (0.3.5-1+rpi7) wird eingerichtet ...
                                  raspberrypi-ui-mods (1.20200218) wird eingerichtet ...
                                  The desktop has been updated.
                                  To apply the updates, please reboot your Pi, and then select one of the options on the Defaults page in Appearance Settings.
                                  python3-pil:armhf (5.4.1-2+deb10u1) wird eingerichtet ...
                                  realvnc-vnc-viewer (6.20.113.42303) wird eingerichtet ...
                                  firmware-brcm80211 (1:20190114-1+rpt5) wird eingerichtet ...
                                  python3-pil.imagetk:armhf (5.4.1-2+deb10u1) wird eingerichtet ...
                                  firmware-realtek (1:20190114-1+rpt5) wird eingerichtet ...
                                  pipanel (1:1.4) wird eingerichtet ...
                                  udev (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  libwebkit2gtk-4.0-37:armhf (2.26.4-1~deb10u2+rpi1) wird eingerichtet ...
                                  firmware-libertas (1:20190114-1+rpt5) wird eingerichtet ...
                                  libcurl4:armhf (7.64.0-4+deb10u1) wird eingerichtet ...
                                  rpi-eeprom-images (5.1-1) wird eingerichtet ...
                                  lxplug-cputemp (0.3) wird eingerichtet ...
                                  curl (7.64.0-4+deb10u1) wird eingerichtet ...
                                  realvnc-vnc-server (6.7.1.42348) wird eingerichtet ...
                                  Updating /etc/pam.d/vncserver
                                  Updating /etc/pam.conf... done
                                  Looking for font path... /usr/share/fonts/X11/100dpi/:unscaled,/usr/share/fonts/X11/100dpi,built-ins (from xset).
                                  Original config file "/etc/vnc/config.old" preserved
                                  Privater Schlüssel wird generiert... fertig
                                  Installed systemd unit for VNC Server in Service Mode daemon
                                  Start or stop the service with:
                                    systemctl (start|stop) vncserver-x11-serviced.service
                                  Mark or unmark the service to be started at boot time with:
                                    systemctl (enable|disable) vncserver-x11-serviced.service
                                  Installed systemd unit for VNC Server in Virtual Mode daemon
                                    systemctl (start|stop) vncserver-virtuald.service
                                    systemctl (enable|disable) vncserver-virtuald.service
                                  raspi-config (20200226) wird eingerichtet ...
                                  rc-gui (1.38) wird eingerichtet ...
                                  systemd-sysv (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  piwiz (0.11) wird eingerichtet ...
                                  lxplug-network (0.19) wird eingerichtet ...
                                  libpam-systemd:armhf (241-7~deb10u3+rpi1) wird eingerichtet ...
                                  rpi-eeprom (5.1-1) wird eingerichtet ...
                                  Trigger für mime-support (3.62) werden verarbeitet ...
                                  Trigger für hicolor-icon-theme (0.17-2) werden verarbeitet ...
                                  Trigger für gnome-menus (3.31.4-3) werden verarbeitet ...
                                  Trigger für libc-bin (2.28-10+rpi1) werden verarbeitet ...
                                  Trigger für dbus (1.12.16-1) werden verarbeitet ...
                                  Trigger für shared-mime-info (1.10-1) werden verarbeitet ...
                                  Trigger für desktop-file-utils (0.23-4) werden verarbeitet ...
                                  Trigger für initramfs-tools (0.133+deb10u1) werden verarbeitet ...
                                  build-essential ist schon die neueste Version (12.6).
                                  curl ist schon die neueste Version (7.64.0-4+deb10u1).
                                  git ist schon die neueste Version (1:2.20.1-2+deb10u1).
                                  unzip ist schon die neueste Version (6.0-23+deb10u1).
                                  wget ist schon die neueste Version (1.20.1-1.1).
                                  wget wurde als manuell installiert festgelegt.
                                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 4 nicht aktualisiert.
                                  Installed Node version: v10.15.2
                                  Installed npm version: V5.8.0
                                  npm should be upgraded.
                                  Installing npm ...
                                  npm ist schon die neueste Version (5.8.0+ds6-4).
                                  npm wurde als manuell installiert festgelegt.
                                  upgrading npm to latest
                                  /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
                                  /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
                                  + npm@6.14.3
                                  added 435 packages from 869 contributors in 87.571s
                                  npm installation Done! version=V6.14.3
                                  Dependencies installation Done!
                                  setting up initial config.js
                                  Check plymouth installation ...
                                  Splashscreen: Checking themes directory.
                                  Splashscreen: Create theme directory if not exists.
                                  Splashscreen: Changed theme to MagicMirror successfully.
                                  We're ready! Run DISPLAY=:0 npm start from the ~/MagicMirror directory to start your MagicMirror.
                                  install completed - Fr Mär 20 16:41:45 CET 2020
                                  I hope this is the correctly log-File.
                                    sdetweil @Pielo
                                    @Pielo thank you…
