Unsolved Issues with MMM-json-feed module.
@thedoorsfanatic
I appreciate it. -
@Aurelio what does your data look like? do you need to use any of the config parameters to get to the right data elements?
i did this{ module: 'MMM-json-feed', position: 'middle', config: { urls: [ "https://corona.lmao.ninja/all" ] } }
and the data appeared in the center of the page as expected
@sdetweil Interesting, I just copied your code and added to my config file and still nothing displays. Maybe the module as a problem in my setup.
thank you for trying for me…
@Aurelio just for testing, rename your config.js out of the way,
then copy the sample
cp config.js sample config.jsthen add my config info to the end
then try it…
@sdetweil also, the module ALWAYS displays a header
and the classes are “dimmed small”
(so , hard to read) -
Thank you Sam, I did what you recommended and still nothing. I ever loaded the SD-card from a fresh img and only loaded MagicMirror, same result. I do appreciate your taking your time to answer my question.
@Aurelio if u put this in a browser, does it return data?
mine returns this
{"cases":285706,"deaths":11876,"recovered":93584,"updated":1584796664654}
I have restarted MM a couple times today and the display comes up each time
