    Issues with MMM-json-feed module.
    11 Posts 3 Posters 3.7k Views 3 Watching
    • thedoorsfanaticT Offline
      thedoorsfanatic @Aurelio
      @Aurelio
      I went through the read me and it says url DEPRECATED, Please use urls instead:
      urls: [
              'http://your.server.json.here/abc1.json',
              'http://your.server.json.here/abc2.json',
      Maybe that is the problem?
      My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
        Aurelio @thedoorsfanatic
        @thedoorsfanatic
        tank you for the recommendation but still no luck…maybe the module doesn’t work for what I am trying to do
                            module: "MMM-JsonTable",
                            title: "Corona virus",
                            header: "Tracking Corona",
                                    urls: [
                                            "https://corona.lmao.ninja/all", // Required
        thedoorsfanaticT S 2 Replies Last reply Reply Quote 0
          @Aurelio
          Sorry it did not work, I am not an expert, it was just a hint
          Have you tried this one?
          https://github.com/timdows/MMM-JsonTable
            @thedoorsfanatic
            I appreciate it.
              sdetweil @Aurelio
              @Aurelio what does your data look like? do you need to use any of the config parameters to get to the right data elements?
              i did this
                  module: 'MMM-json-feed',
                  position: 'middle',
                    urls: [
              and the data appeared in the center of the page as expected
                Aurelio @sdetweil
                @sdetweil Interesting, I just copied your code and added to my config file and still nothing displays. Maybe the module as a problem in my setup.
                thank you for trying for me…
                  sdetweil @Aurelio
                  @Aurelio just for testing, rename your config.js out of the way,
                  then copy the sample
                  cp config.js sample config.js
                  then add my config info to the end
                  then try it…
                    @sdetweil also, the module ALWAYS displays a header
                    and the classes are “dimmed small”
                    (so , hard to read)
                      Aurelio
                      Thank you Sam, I did what you recommended and still nothing. I ever loaded the SD-card from a fresh img and only loaded MagicMirror, same result. I do appreciate your taking your time to answer my question.
                        sdetweil @Aurelio
                        @Aurelio if u put this in a browser, does it return data?
                        mine returns this
                        {"cases":285706,"deaths":11876,"recovered":93584,"updated":1584796664654}
                        I have restarted MM a couple times today and the display comes up each time
