    Issues with MMM-json-feed module.
    11 Posts 3 Posters 4.3k Views 3 Watching
      Aurelio
      I am new to this so I apologize if this is a dumb question.
      I installed a module called MMM-json-feed… my intention is to display the Json file I get from this website (https://corona.lmao.ninja/all) on the bottom-left of of the screen but all I am getting is a series of vertical dots.
                          module: 'MMM-JsonTable',
                          position: 'bottom_left',
                          header: 'Tracking Corona ',
                                  url: 'https://corona.lmao.ninja/all', // Required
      any help would be greatly appreciated.
      thedoorsfanaticT 1 Reply Last reply Reply Quote 0
      • thedoorsfanaticT Offline
        thedoorsfanatic @Aurelio
        @Aurelio
        I went through the read me and it says url DEPRECATED, Please use urls instead:
        urls: [
                'http://your.server.json.here/abc1.json',
                'http://your.server.json.here/abc2.json',
        Maybe that is the problem?
        My Smart Mirror YouTube playlist: https://www.youtube.com/playlist?list=PL9Iv_4Mvy6o2tnvdhNBstVWNefgUP9ELp
          Aurelio @thedoorsfanatic
          @thedoorsfanatic
          tank you for the recommendation but still no luck…maybe the module doesn’t work for what I am trying to do
                              module: "MMM-JsonTable",
                              title: "Corona virus",
                              header: "Tracking Corona",
                                      urls: [
                                              "https://corona.lmao.ninja/all", // Required
          thedoorsfanaticT S 2 Replies Last reply Reply Quote 0
            @Aurelio
            Sorry it did not work, I am not an expert, it was just a hint
            Have you tried this one?
            https://github.com/timdows/MMM-JsonTable
              @thedoorsfanatic
              I appreciate it.
                sdetweil @Aurelio
                @Aurelio what does your data look like? do you need to use any of the config parameters to get to the right data elements?
                i did this
                    module: 'MMM-json-feed',
                    position: 'middle',
                      urls: [
                and the data appeared in the center of the page as expected
                  Aurelio @sdetweil
                  @sdetweil Interesting, I just copied your code and added to my config file and still nothing displays. Maybe the module as a problem in my setup.
                  thank you for trying for me…
                    sdetweil @Aurelio
                    @Aurelio just for testing, rename your config.js out of the way,
                    then copy the sample
                    cp config.js sample config.js
                    then add my config info to the end
                    then try it…
                      @sdetweil also, the module ALWAYS displays a header
                      and the classes are “dimmed small”
                      (so , hard to read)
                        Aurelio
                        Thank you Sam, I did what you recommended and still nothing. I ever loaded the SD-card from a fresh img and only loaded MagicMirror, same result. I do appreciate your taking your time to answer my question.
                          sdetweil @Aurelio
                          @Aurelio if u put this in a browser, does it return data?
                          mine returns this
                          {"cases":285706,"deaths":11876,"recovered":93584,"updated":1584796664654}
                          I have restarted MM a couple times today and the display comes up each time
