Issues with MMM-json-feed module.
I am new to this so I apologize if this is a dumb question.
I installed a module called MMM-json-feed… my intention is to display the Json file I get from this website (https://corona.lmao.ninja/all) on the bottom-left of of the screen but all I am getting is a series of vertical dots.
{ module: 'MMM-JsonTable', position: 'bottom_left', header: 'Tracking Corona ', config: { url: 'https://corona.lmao.ninja/all', // Required } }any help would be greatly appreciated.
@Aurelio
I went through the read me and it says url DEPRECATED, Please use urls instead:urls: [ 'http://your.server.json.here/abc1.json', 'http://your.server.json.here/abc2.json', ]Maybe that is the problem?
tank you for the recommendation but still no luck…maybe the module doesn’t work for what I am trying to do
{ module: "MMM-JsonTable", title: "Corona virus", position: "top_left", header: "Tracking Corona", config: { urls: [ "https://corona.lmao.ninja/all", // Required "https://corona.lmao.ninja/all", ] } }, -
@Aurelio
Sorry it did not work, I am not an expert, it was just a hint
Have you tried this one?
https://github.com/timdows/MMM-JsonTable -
@thedoorsfanatic
I appreciate it. -
@Aurelio what does your data look like? do you need to use any of the config parameters to get to the right data elements?
i did this{ module: 'MMM-json-feed', position: 'middle', config: { urls: [ "https://corona.lmao.ninja/all" ] } }and the data appeared in the center of the page as expected
@sdetweil Interesting, I just copied your code and added to my config file and still nothing displays. Maybe the module as a problem in my setup.
thank you for trying for me…
@Aurelio just for testing, rename your config.js out of the way,
then copy the sample
cp config.js sample config.jsthen add my config info to the end
then try it…
@sdetweil also, the module ALWAYS displays a header
and the classes are “dimmed small”
(so , hard to read) -
Thank you Sam, I did what you recommended and still nothing. I ever loaded the SD-card from a fresh img and only loaded MagicMirror, same result. I do appreciate your taking your time to answer my question.
@Aurelio if u put this in a browser, does it return data?
https://corona.lmao.ninja/allmine returns this
{"cases":285706,"deaths":11876,"recovered":93584,"updated":1584796664654}I have restarted MM a couple times today and the display comes up each time
