Newsfeed with own RSS2 resp. XML
8 Posts 2 Posters 1.3k Views 2 Watching
  • T Offline
    thgmirror
    Hi colleagues,
    I’m trying to use in the Newsfeed-module an own feed on the RPI. So no external link to for example Tagesschau but to a file in the MagicMirror-folder.
    I tried this:
    url: “http://192.168.2.117:8080/home/pi/MagicMirror/podcasts.rss2”
    but without success. I only see “Lade …”
    Currently I have in podcasts.rss2 a copy of the Tagesschau-feed.
    Anyone an idea?
    Thank you for any help
    and Greetings from Bonn
    Thomas
    S 1 Reply Last reply Mar 25, 2020, 7:02 PM Reply Quote 0
      sdetweil @thgmirror
      @thgmirror said in Newsfeed with own RSS2 resp. XML:
      the server at http://192.168.2.117:8080
      uses the MagicMirror folder as the root
      so
      “http://192.168.2.117:8080/podcasts.rss2”
      • T Offline
        thgmirror
        @sdetweil said in Newsfeed with own RSS2 resp. XML:
        Hm, no success…any other idea?
        S 2 Replies Last reply Mar 25, 2020, 7:14 PM Reply Quote 0
          sdetweil @thgmirror
          @thgmirror the MM should says starting a fetcher for
          like this from my system
          Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
          this will show in the terminal window where npm start was done, or in the logs if pm2
          pm2 logs --lines=100
          (or more than 100)
            sdetweil @thgmirror
            @thgmirror also, is your config set to address:“0.0.0.0” or “localhost”
            if localhost, then u must use localhost or 127.0.0.1
            “http://localhost:8080/podcasts.rss2”
            • T Offline
              thgmirror
              http://localhost:8080/os
              Also localhost has no affect…and the solution yoi mentioned before I’ll try later;-)
              Thomas
              S 1 Reply Last reply Mar 25, 2020, 7:31 PM Reply Quote 0
                sdetweil @thgmirror
                @thgmirror sorry, the root is /MagicMirror, but the available paths under are modules etc
                so, this works
                http://localhost:8080/modules/podcasts.rss2
                and the file is located in MagicMirror/modules
                • T Offline
                  thgmirror
                  Yeah Yeah Yeah - Success!!!
                  I moved the file to the modules-folder and now it works!!!
                  I plan to use the Newsfeed-ticker to display a protocoll of my podcast-downloader…I have some special requirements;-)
                  Thank you, Sam
