    Modules don't update
    5 Posts 2 Posters 1.2k Views 2 Watching
      mattx38
      I see that certain modules as News feeds and domoticz do not update datas.
      My temperature probes stay not updated, while it changes in domoticz.
      How can I fix this issue ?
        sdetweil @mattx38
        @mattx38 each module should have some sort of configuration for update cycle time.
        newsfeed has reloadInterval (default 5 minutes), that does NOT mean that the feed itself has changes…
          mattx38 @sdetweil
          @sdetweil I know, but for example, the domoticz module has an update interval of 5000ms, then when I see that the temperature of my outside probe has changed 15 minutes ago and the one I see on the MMM is still the old one, there is a problem.
          If I restart the MMM by the SSH command “pm2 restart mm”, then all datas are up to date…
            sdetweil @mattx38
            @mattx38 no idea… 5000ms is a VERY FAST… probably could be 15000 (15 seconds)
              mattx38
              Ok, I’ll try to increase the delay.
              Thank you
