Solved covid bell curve line graph tracker
@sdetweil This really is great. If you can easily add a individual states (US) I would like to see how my state is doing compared to the national numbers. Its obviously not realistic to display 50 states at once but one or two would be nice. If its a whole big thing don’t worry about it
@humdinger44 the data source I have doesn’t have areas inside countries, so I cannot add that
refresh is broken(I guessed new data would be available at 2am, wasn’t until 7am! oops)… testing fix now
update for refresh when no data available, keep trying!
another fix for refresh (starting after midnight , but no data available yet left a blank display)…
also fixed to add two more charts
new cases and new deaths by day
new cases for the US ‘may’ show effect of distancing… need more days
(or maybe not, one day drop)todays data, 2020-03-26, is still not yet posted…(as of 8:40 am central time us)
2020-03-26 data has arrived, 08:56 us central time, (and update worked!) -
@sdetweil kind of a simple question, but i cannot for the life of me figure out how to change the color of the dates, and the countries names to white?? I looked everywhere and tried my custom css file to no avail…
@almostgithub >change the color of the dates, and the countries names to white??
sorry, don’t understand… they are white already (not bright white)
I currently don’t provide access to those settings…
this is all controlled by the charting library I am using…
I would have to add settings to enable access -
@almostgithub Ok I’ve added some.
git pull in the module folder,
here are the things u can set… will get to the doc in the morning
legendTextColor:'white', chartTitleColor: 'white', chart_title: '', xAxisLabel:"by date", xAxisLabelColor:'white', xAxisTickLabelColor:'white', yAxisLabel:"Count", yAxisLabelColor:'white', yAxisTickLabelColor:'white',
@sdetweil oh wow! Thanks so much, thats awesome!! They are grey on my mirror and makes it hard to read the legend and dates.
edit: after a git pull and npm install, it seems to be stuck on MyCovid19 Loading data for chart “cumulative_deaths”
edit: Saw this in the issues tab, will ask there
new update, data source changed … after git pull, need to run npm install again to update the library used to read the data (csv instead of xlsx)
@sdetweil can you drop an example of the config for two graphs displayed at once?
Edit: nevermind, I was overthinking it.
