    Help for a Novice....
    22 Posts 3 Posters 8.6k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @j.ason
      @j-ason
      Looking at the documentation, I see the config sample entry does not have a comma after the last bracket. The config entry should look like this:
      	module: "MMM-Bose-Soundtouch",
      	position: "top_right",   // see mirror setting for options
      		updateInterval: 5, // every 5 seconds
      		apiBase: '192.168.xxx.xxx',
      Notice the comma after the last curly bracket?
      Of course, @sdetweil has probably brought that to your attention already. :-)
        sdetweil @Mykle1
        @Mykle1 the comma only matters IF this is the not the last module config entry…
        but blackscreen shouldn’t be because of this, you’d get a “create a config file” error
          True, but it IS the most common mistake for beginners, or I am much mistaken. :-)
            j.ason @Mykle1
            @Mykle1 - thanks for replying :-)
            I do have a comma on my file like what you attached within this chat
            J
            Mykle1M S 2 Replies Last reply Reply Quote 0
              @j-ason
              Very well. Then I suggest you follow the suggestions that @sdetweil has posted above. I’m sure he will get you sorted, if he hasn’t already.
                sdetweil @j.ason
                @j-ason ok. good…
                then u still have a black screen when starting MM…right>
                so, let start from the terminal window
                pm2 stop 0
                npm start
                wait for it to come up…
                if working from PI screen do
                alt-spacebar, n to minimize the MM screen
                no errors reported?
                then to get the MM screen displayed again
                on MM do
                alt (hold down)
                press tab key
                a list of windows will appear
                tab to the MagicMirror screen view,
                release alt key
                open developers window
                press ctrl-shift-i
                select the tab labeled console
                enter ‘bose’ (no quotes) in the filter field
                are there any errors (usually red text), may have to scroll up
                  j.ason
                  Hi Sam,
                  I do have the MM working and no black screen :-)
                  I have weather, clock and calendar working and it boots up fine too…
                  Just wanted to figure out about this Bose module - partly because I have a Bose setup in my house and secondly the more of this I read and try to understand the more I hopefully will :crossed_fingers_light_skin_tone:
                    sdetweil @j.ason
                    @j-ason ok, developers window may still help
                    use developers window instructions above
                      j.ason @sdetweil
                      BTW I have sent you an email with the screenshot
                      J
                        sdetweil @j.ason
                        @j-ason ok, got screenshot, but doesn’t show any error… so, see instructions above
                        in your original post you said
                        I have entered the above lines into my config.js yet when I reboot my Pi I get nothing - not even the header?
                        that is what we call black screen “I get nothing”
                        u don’t have to reboot each time, just use
                        pm2 restart 0
                        if using pm2 to start at boot
                          j.ason @sdetweil
                          @sdetweil Apologies,
                          What I meant was I get nothing in relation to the Bose Module - no header no text and no music showing etc…
                          Having gone into Developers window I see no red errors relating to Bose. I did filter and let only warnings and errors show too.
                            sdetweil @j.ason
                            @j-ason but u see messages related to bose module, in developers window, correct?
                              j.ason @sdetweil
                              @sdetweil I do see Bose listed and no errors - screenshot sent to you to show you…
                                j.ason @sdetweil
                                @sdetweil :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone:
                                No sure what happened however I removed the code and then re entered it back into the config file and it works :-)
                                Thanks again for your time helping me - much appreciated indeed
                                Have a great day
                                #StaySafe
                                #StayHome
                                #StayPositive
                                Regards J
                                  sdetweil @j.ason
                                  @j-ason well, there WAS an error… email sent back
