    Help for a Novice....
    22 Posts 3 Posters 7.2k Views 3 Watching
      sdetweil @j.ason
      @j-ason sure, send to same userid as here, at gmail.
        Mykle1 Project Sponsor Module Developer @j.ason
        @j-ason
        Looking at the documentation, I see the config sample entry does not have a comma after the last bracket. The config entry should look like this:
        	module: "MMM-Bose-Soundtouch",
        	position: "top_right",   // see mirror setting for options
        		updateInterval: 5, // every 5 seconds
        		apiBase: '192.168.xxx.xxx',
        Notice the comma after the last curly bracket?
        Of course, @sdetweil has probably brought that to your attention already. :-)
          sdetweil @Mykle1
          @Mykle1 the comma only matters IF this is the not the last module config entry…
          but blackscreen shouldn’t be because of this, you’d get a “create a config file” error
            True, but it IS the most common mistake for beginners, or I am much mistaken. :-)
              j.ason @Mykle1
              @Mykle1 - thanks for replying :-)
              I do have a comma on my file like what you attached within this chat
              J
              Mykle1M S 2 Replies Last reply Reply Quote 0
                @j-ason
                Very well. Then I suggest you follow the suggestions that @sdetweil has posted above. I’m sure he will get you sorted, if he hasn’t already.
                  sdetweil @j.ason
                  @j-ason ok. good…
                  then u still have a black screen when starting MM…right>
                  so, let start from the terminal window
                  pm2 stop 0
                  npm start
                  wait for it to come up…
                  if working from PI screen do
                  alt-spacebar, n to minimize the MM screen
                  no errors reported?
                  then to get the MM screen displayed again
                  on MM do
                  alt (hold down)
                  press tab key
                  a list of windows will appear
                  tab to the MagicMirror screen view,
                  release alt key
                  open developers window
                  press ctrl-shift-i
                  select the tab labeled console
                  enter ‘bose’ (no quotes) in the filter field
                  are there any errors (usually red text), may have to scroll up
                    j.ason
                    Hi Sam,
                    I do have the MM working and no black screen :-)
                    I have weather, clock and calendar working and it boots up fine too…
                    Just wanted to figure out about this Bose module - partly because I have a Bose setup in my house and secondly the more of this I read and try to understand the more I hopefully will :crossed_fingers_light_skin_tone:
                      sdetweil @j.ason
                      @j-ason ok, developers window may still help
                      use developers window instructions above
                        j.ason @sdetweil
                        BTW I have sent you an email with the screenshot
                        J
                          sdetweil @j.ason
                          @j-ason ok, got screenshot, but doesn’t show any error… so, see instructions above
                          in your original post you said
                          I have entered the above lines into my config.js yet when I reboot my Pi I get nothing - not even the header?
                          that is what we call black screen “I get nothing”
                          u don’t have to reboot each time, just use
                          pm2 restart 0
                          if using pm2 to start at boot
                            j.ason @sdetweil
                            @sdetweil Apologies,
                            What I meant was I get nothing in relation to the Bose Module - no header no text and no music showing etc…
                            Having gone into Developers window I see no red errors relating to Bose. I did filter and let only warnings and errors show too.
                              sdetweil @j.ason
                              @j-ason but u see messages related to bose module, in developers window, correct?
                                j.ason @sdetweil
                                @sdetweil I do see Bose listed and no errors - screenshot sent to you to show you…
                                  j.ason @sdetweil
                                  @sdetweil :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone:
                                  No sure what happened however I removed the code and then re entered it back into the config file and it works :-)
                                  Thanks again for your time helping me - much appreciated indeed
                                  Have a great day
                                  #StaySafe
                                  #StayHome
                                  #StayPositive
                                  Regards J
                                    sdetweil @j.ason
                                    @j-ason well, there WAS an error… email sent back
