Help for a Novice....
22 Posts 3 Posters 5.8k Views 3 Watching
    j.ason
    Re: MMM-Bose-Soundtouch
    Hi there,
    As I like others are at home I thought I would give this MMM a go and first task was to see if I could sort out the Bose Module.
    I have never repeat never done anything like this before so please be patient :-)
    I have entered the above lines into my config.js yet when I reboot my Pi I get nothing - not even the header?
    I went into Terminal and went to the modules part and then ran the GitHub clone within the ~/MagicMirror/modules location ( hope that is correct)?
    Any ideas why I see nothing at all folks?
    S 1 Reply Last reply Mar 27, 2020, 6:29 PM Reply Quote 0
      sdetweil @j.ason
      @j-ason so, if you go back to the original config.js (copy the sample to config.js, save your current one first)
      does mirror come back up?
      J 1 Reply Last reply Mar 27, 2020, 7:06 PM Reply Quote 0
        j.ason
        Hi Sam,
        The mirror works with the modules I have - calendar, calendar and time :-)
        Its just the Bose one I get seem to get to work that is frustrating me tbh :-(
        I fi could figure out how to add a screenshot I would :thinking_face:
        S 1 Reply Last reply Mar 27, 2020, 7:06 PM Reply Quote 0
          j.ason @sdetweil
          @sdetweil Thanks for replying so quickly too :clapping_hands:
            sdetweil @j.ason
            @j-ason the forum posting pics is broken (still)… so u have to post them somewhere else
            black screen usually means some config or setup problem…
            open the developers window (ctrl-shift-i on the keyboard), and select the console tab,. and scroll up to see any errors (usually red text)
            u did not edit any module file, right, only the config.js…
            does the module have a package.json file, and if so, did u run npm install in the module folder?
            J 1 Reply Last reply Mar 27, 2020, 7:10 PM Reply Quote 0
              j.ason @sdetweil
              @sdetweil Can I send you the screenshot? (email , WhatsApp ?)
              As I said I am way out of my depth tbh - only started this the other day and hoping it will make sense as I go along :crossed_fingers_light_skin_tone:
              All I have done is load Raspberry Jessie version, MM2 install with default calendar, time, weather - edit… Have managed to work around getting my Google calendar to work and change location to UK for calendar and weather settings…
              S M 2 Replies Last reply Mar 27, 2020, 7:36 PM Reply Quote 0
                sdetweil @j.ason
                @j-ason sure, send to same userid as here, at gmail.
                  Mykle1 Project Sponsor Module Developer @j.ason
                  @j-ason
                  Looking at the documentation, I see the config sample entry does not have a comma after the last bracket. The config entry should look like this:
                  	module: "MMM-Bose-Soundtouch",
                  	position: "top_right",   // see mirror setting for options
                  		updateInterval: 5, // every 5 seconds
                  		apiBase: '192.168.xxx.xxx',
                  Notice the comma after the last curly bracket?
                  Of course, @sdetweil has probably brought that to your attention already. :-)
                  S 1 Reply Last reply Mar 27, 2020, 10:15 PM Reply Quote 0
                    sdetweil @Mykle1
                    @Mykle1 the comma only matters IF this is the not the last module config entry…
                    but blackscreen shouldn’t be because of this, you’d get a “create a config file” error
                    M 1 Reply Last reply Mar 27, 2020, 11:18 PM Reply Quote 1
                      True, but it IS the most common mistake for beginners, or I am much mistaken. :-)
                      J 1 Reply Last reply Mar 28, 2020, 12:25 PM Reply Quote 0
                      1 / 3
