    Help for a Novice....
    22 Posts 3 Posters 8.2k Views 3 Watching
      j.ason
      Hi Sam,
      The mirror works with the modules I have - calendar, calendar and time :-)
      Its just the Bose one I get seem to get to work that is frustrating me tbh :-(
      I fi could figure out how to add a screenshot I would :thinking_face:
        j.ason @sdetweil
        @sdetweil Thanks for replying so quickly too :clapping_hands:
          sdetweil @j.ason
          @j-ason the forum posting pics is broken (still)… so u have to post them somewhere else
          black screen usually means some config or setup problem…
          open the developers window (ctrl-shift-i on the keyboard), and select the console tab,. and scroll up to see any errors (usually red text)
          u did not edit any module file, right, only the config.js…
          does the module have a package.json file, and if so, did u run npm install in the module folder?
            j.ason @sdetweil
            @sdetweil Can I send you the screenshot? (email , WhatsApp ?)
            As I said I am way out of my depth tbh - only started this the other day and hoping it will make sense as I go along :crossed_fingers_light_skin_tone:
            All I have done is load Raspberry Jessie version, MM2 install with default calendar, time, weather - edit… Have managed to work around getting my Google calendar to work and change location to UK for calendar and weather settings…
            S Mykle1M 2 Replies Last reply Reply Quote 0
              sdetweil @j.ason
              @j-ason sure, send to same userid as here, at gmail.
                Mykle1 Project Sponsor Module Developer @j.ason
                @j-ason
                Looking at the documentation, I see the config sample entry does not have a comma after the last bracket. The config entry should look like this:
                	module: "MMM-Bose-Soundtouch",
                	position: "top_right",   // see mirror setting for options
                		updateInterval: 5, // every 5 seconds
                		apiBase: '192.168.xxx.xxx',
                Notice the comma after the last curly bracket?
                Of course, @sdetweil has probably brought that to your attention already. :-)
                  sdetweil @Mykle1
                  @Mykle1 the comma only matters IF this is the not the last module config entry…
                  but blackscreen shouldn’t be because of this, you’d get a “create a config file” error
                    True, but it IS the most common mistake for beginners, or I am much mistaken. :-)
                      j.ason @Mykle1
                      @Mykle1 - thanks for replying :-)
                      I do have a comma on my file like what you attached within this chat
                      J
                      Mykle1M S 2 Replies Last reply Reply Quote 0
                        @j-ason
                        Very well. Then I suggest you follow the suggestions that @sdetweil has posted above. I’m sure he will get you sorted, if he hasn’t already.
                          sdetweil @j.ason
                          @j-ason ok. good…
                          then u still have a black screen when starting MM…right>
                          so, let start from the terminal window
                          pm2 stop 0
                          npm start
                          wait for it to come up…
                          if working from PI screen do
                          alt-spacebar, n to minimize the MM screen
                          no errors reported?
                          then to get the MM screen displayed again
                          on MM do
                          alt (hold down)
                          press tab key
                          a list of windows will appear
                          tab to the MagicMirror screen view,
                          release alt key
                          open developers window
                          press ctrl-shift-i
                          select the tab labeled console
                          enter ‘bose’ (no quotes) in the filter field
                          are there any errors (usually red text), may have to scroll up
                            j.ason
                            Hi Sam,
                            I do have the MM working and no black screen :-)
                            I have weather, clock and calendar working and it boots up fine too…
                            Just wanted to figure out about this Bose module - partly because I have a Bose setup in my house and secondly the more of this I read and try to understand the more I hopefully will :crossed_fingers_light_skin_tone:
                              sdetweil @j.ason
                              @j-ason ok, developers window may still help
                              use developers window instructions above
                                j.ason @sdetweil
                                BTW I have sent you an email with the screenshot
                                J
                                  sdetweil @j.ason
                                  @j-ason ok, got screenshot, but doesn’t show any error… so, see instructions above
                                  in your original post you said
                                  I have entered the above lines into my config.js yet when I reboot my Pi I get nothing - not even the header?
                                  that is what we call black screen “I get nothing”
                                  u don’t have to reboot each time, just use
                                  pm2 restart 0
                                  if using pm2 to start at boot
                                    j.ason @sdetweil
                                    @sdetweil Apologies,
                                    What I meant was I get nothing in relation to the Bose Module - no header no text and no music showing etc…
                                    Having gone into Developers window I see no red errors relating to Bose. I did filter and let only warnings and errors show too.
                                      sdetweil @j.ason
                                      @j-ason but u see messages related to bose module, in developers window, correct?
                                        j.ason @sdetweil
                                        @sdetweil I do see Bose listed and no errors - screenshot sent to you to show you…
                                          j.ason @sdetweil
                                          @sdetweil :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone: :clapping_hands_light_skin_tone:
                                          No sure what happened however I removed the code and then re entered it back into the config file and it works :-)
                                          Thanks again for your time helping me - much appreciated indeed
                                          Have a great day
                                          #StaySafe
                                          #StayHome
                                          #StayPositive
                                          Regards J
                                            sdetweil @j.ason
                                            @j-ason well, there WAS an error… email sent back
