    MMM-RTSPStream config.html refused to connect
    5 Posts 3 Posters 1.4k Views 2 Watching
      stampeder
      I’m just installing MMM-RTSPStream for the first time. I installed it as root (sudo su -). Got it all installed as per the instructions in the repository and now ready to use config.html. When I point my browser to it: html://10.10.10.59:8080/MMM-RTSPStream/config.html my browser returns:
      This site can’t be reached10.10.10.59 refused to connect.
      Try:
      Checking the connection
      Checking the proxy and the firewall
      ERR_CONNECTION_REFUSED
      The Pi that MagicMirror is running on is local to my network so this is not a firewall issue. I think something in the configuration needs to have some file changed from root to a user access ability but I don’t know enough to know which file. Your help will be greatly appreciated. Glenn.
        sdetweil @stampeder
        @stampeder in config.js
        address:"0.0.0.0",
        ipWhitelist:[],
          stampeder
          Sam:
          IT WORKS!! You are my new hero…
          Your gradually (learning me) how to use this… ( I live in East Texas, what can I say).
          I really appreciate the help. Now I can move forward on my security cameras.
          Thanks again.
          Glenn.
            stampeder
            Got the config page working and the stream frame showing on MagicMirror but no streaming video. I’m using a Foscam camera which encodes the stream as ffmpeg.
            I have six of these running in Zoneminder and the TCP video stream is called with this command:
            10.10.XX.XX:8081/videostream.asf?user=USERID&pwd=USERPWD
            I get the module to outline a frame but the contents just show a grey background.
            Here is my config for the module:
            module: “MMM-RTSPStream”,
            position: “top_right”,
            header: “Box Stalls”,
            autoStart: true,
            rotateStreams: false,
            rotateStreamTimeout: 10,
            moduleWidth: 354,
            moduleHeight: 240,
            localPlayer: ‘ffmpeg’,
            remotePlayer: ‘ffmpeg’,
            showSnapWhenPaused: true,
            remoteSnaps: true,
            shutdownDelay: 12,
            stream1: {
            url: ‘10.10.XX.XXX:8081/videostream.asf?user=USERID&pwd=USERPWD’,
            frameRate: ‘undefined’,
            hdUrl: ‘10.10.XX.XXX:8081/videostream.asf?user=USERID&pwd=USERPWD’,
            snapshotType: ‘url’,
            width: 354,
            height: 240,
            ffmpegPort: 9999,
            I hope someone can point out what I am doing wrong. I think I am close to having this working.
            Thanks.
            Glenn.
              ShadowMG Project Sponsor @stampeder
              @stampeder is it an rtsp-stream? Did you try to reach the stream with the full URL using “rtsp://10.10…”? Did you try with omxplayer or VNC?
              Greets, Shadow
