After need take another config.js
12 Posts 2 Posters 4.3k Views 2 Watching
    pi-user
    In which file is it defined that the config.js file is the main configuration file? Can you define different config.js files? How for example configXYZ.js? So take another config.js as needed?
    Many thanks for the help
    S 1 Reply Last reply Mar 28, 2020, 7:58 PM Reply Quote 0
      sdetweil @pi-user
      @pi-user set env variable
      export config=???
      ??? Is new filename, full path if not in config folder
        pi-user
        @sdetweil said in After need take another config.js:
        export config
        Where can I put export config? So, that means that I can take another configuration file if necessary?
        S 1 Reply Last reply Mar 28, 2020, 8:10 PM Reply Quote 0
          sdetweil @pi-user
          @pi-user in the terminal window or script. If pm2 then in installers/mm.sh
            pi-user
            mm.sh
            I discovered that the file name is defined in the check_config.js file!
            /opt/magic_mirror/tests/configs/check_config.js
            function getConfigFile() {
            // FIXME: This function should be in core. Do you want refactor me ;) ?, be good!
            rootPath = path.resolve(__dirname + “/…/…/”);
            var configFileName = path.resolve(rootPath + “/config/config.js”);
            if (process.env.MM_CONFIG_FILE) {
            configFileName = path.resolve(process.env.MM_CONFIG_FILE);
            return configFileName;
            S 1 Reply Last reply Mar 28, 2020, 8:40 PM Reply Quote 0
              sdetweil @pi-user
              @pi-user in electron.js is says process.env.config
              P 2 Replies Last reply Mar 30, 2020, 6:25 AM Reply Quote 0
                pi-user @sdetweil
                Thank you
                  pi-user @sdetweil
                  I looked at it. But how can I edit this file so that another config file is read? Such as: configXYZ.js and not the standard name config.js
                  Thank you
                  S 1 Reply Last reply Mar 30, 2020, 11:49 AM Reply Quote 0
                    sdetweil @pi-user
                    @pi-user just copy the default config.sample.js to anyname.js
                    then edit that name and do
                    export config=anyname.js
                    npm start
                    if using pm2, then edit the installers/mm.sh file which what pm2 starts
                    and add the export= line
                    P 1 Reply Last reply Mar 30, 2020, 12:49 PM Reply Quote 0
                      pi-user @sdetweil
                      Thank you:thumbs_up_light_skin_tone:
