    How can i pass query / parameters from URL to module
    Scheduled Pinned Locked Moved Solved Development
    12 Posts 3 Posters 4.0k Views 3 Watching
      AxLed Module Developer
      Dear Developers,
      i want to redesign one of my modules. Therefore i need a hint how i can make the following possible.
      I want to pass a query / parameters from a module URL, f.e.
      http://IPofMM:8080/MMM-Navigate/index?value1=xxx&value2=yy
      to my module.
      What do i need?
      1. a page in my module folder index.js(?)
      2. code do read the values of querystring and do something with it.
      Maybe somebody can give me a tip how to do that or in which module it was already realized (except MMM-Remote-Control).
      Regards
      AxLED
        sdetweil @AxLed
        @AxLed sorry. not quite sure what you mean…
        u want to pass the info from where (how is the user presenting this info) to where
          User is presenting / entering datas by URL in his browser and module should be able to handle the datas.
          AxLED
            sdetweil @AxLed
            @AxLed and did u setup an express path that invokes your node module function?
            the url parms should be there
              No i didnt set any path so far, but express path seems to be the right search word and helps.
              If i understood the documentation right, express path has to be located in node_helper.js.
              But i still dont know how to move forward with this information.
              Are there some modules which are using express path, where i can try to figure out how it works?
              Greetings
              AxLED
              I
                sdetweil @AxLed
                @AxLed MMM-ImagesPhotos uses it…
                the Module wants to use request, so issues a request to a local server (express path)
                which invokes the routine to get the list of photos//
                (instead of doing the sendSocketNotification to the node_module…)
                the express routine is like a cgi pgm invocation…
                from
                https://expressjs.com/en/guide/routing.html
                Route parameters
                the path can autoparse the url
                Route path: /users/:userId/books/:bookId
                Request URL: http://localhost:3000/users/34/books/8989
                req.params: { “userId”: “34”, “bookId”: “8989” }
                but the result, net, is the parms are in the req (uest) parameter object when the routine is called
                  Thanks for the response, it think now i have enough to read and i will try to get in up and running.
                  I will give feedback within the next day.
                  AxLED
                    sdetweil @AxLed
                    @AxLed cooll… standing by!
                      @AxLed so, it should be as simple as
                      const express = require('express')
                      // setup server path handler, for http get request
                      this.expressApp.get("/MMM-Navigate",(req,res) =>{this.someFunction(req,res)});
                      // handler dump request object
                      someFunction: function(request,response){
                           console.log("request data="+JSON.stringify(request))
                          response.send("Hello from MMM-Navigate");
                        A Former User
                        Here is another example of express;
                        const bodyParser = require('body-parser')
                        // in your member function of node_helper.js, usually it will be `.start()`
                        this.expressApp.use(bodyParser.json())
                        this.expressApp.use(bodyParser.urlencoded({extended: true}))
                        var process = (req, res) => {
                          var subpath = req.params.subpath
                          if (CHECK_SOME_CONDITION) {
                            var requestObj = {
                              path: subpath,
                              query: req.query,
                              post: req.body,
                              method: req.method,
                            this.sendSocketNotification("REQUEST_COMING", requestObj)
                            res.status(200).send({status: 200})
                          } else {
                            res.status(400).send({status: 400})
                        this.expressApp.get("/YOUR_PATH/:subpath", process)
                        this.expressApp.post("/YOUR_PATH/:subpath", process) // when you need POST method.
                          @Sean
                          Thanks for your quick response, you are faster than my programming timeslots in my “mancave” are. Today i had some time and got it working.
                          I will test my module changes (for MMM-Navigate) on my mirror for some days, maybe i find some errors and can fix them before i upload it to quick to github in a poor “quality”.
                          My intension was to get rid of MMM-Remote-Control in my installation, as i found errors (while a new install of my MM) and as it seems that MMM-Remote-Control is not maintainanced anymore.
                          I added following features to MMM-Navigate:
                          • Raspberry operations: any Shellcommands, i use it for
                            • restart of MM (pm2 restart mm)
                            • restart of Raspberry (sudo shutdown -h now)
                            • reboot of Raspberry (sudo reboot)
                          • controlling MM by URL Calls (if you dont have a rotary encoder connected or while programming)
                          stay healthy
                          Regards
                          AxLED
                            testing completed, today i uploaded new release to github.
                            MMM-Navigate - V1.3 released
                            Regards
                            AxLED
