    MM on Pi Zero fails after being off for a few days
    27 Posts 2 Posters 10.5k Views 2 Watching
    • K
      kellogg76
      Everything was stopped.
      $ pm2 status
      │ id │ name               │ mode     │ ↺    │ status   │ cpu      │ memory   │
      │ 0  │ mmstart            │ fork     │ 1780 │ stopped  │ 0%       │ 0b       │
        sdetweil @kellogg76
        @kellogg76 pm2 info 0
        K 1 Reply Last reply
        • K
          kellogg76 @sdetweil
          Describing process with id 0 - name mmstart
          │ status            │ stopped                              │
          │ name              │ mmstart                              │
          │ version           │ N/A                                  │
          │ restarts          │ 1780                                 │
          │ uptime            │ 0                                    │
          │ script path       │ /home/pi/mmstart.sh                  │
          │ script args       │ N/A                                  │
          │ error log path    │ /home/pi/.pm2/logs/mmstart-error.log │
          │ out log path      │ /home/pi/.pm2/logs/mmstart-out.log   │
          │ pid path          │ /home/pi/.pm2/pids/mmstart-0.pid     │
          │ interpreter       │ bash                                 │
          │ interpreter args  │ N/A                                  │
          │ script id         │ 0                                    │
          │ exec cwd          │ /home/pi                             │
          │ exec mode         │ fork_mode                            │
          │ node.js version   │ N/A                                  │
          │ node env          │ N/A                                  │
          │ watch & reload    │ ✘                                    │
          │ unstable restarts │ 0                                    │
          │ created at        │ 2020-03-28T19:51:14.338Z             │
          Divergent env variables from local env
          │ SSH_CONNECTION │ 192.168.1.148 54823 192.168.1.166 22 │
          │ XDG_SESSION_ID │ c2                                   │
          │ SSH_CLIENT     │ 192.168.1.148 54823 22               │
          │ SSH_TTY        │ /dev/pts/1                           │
          Add your own code metrics: http://bit.ly/code-metrics
          Use `pm2 logs mmstart [--lines 1000]` to display logs
          Use `pm2 env 0` to display environment variables
          Use `pm2 monit` to monitor CPU and Memory usage mmstart
            sdetweil @kellogg76
            @kellogg76 said in MM on Pi Zero fails after being off for a few days:
            /home/pi/mmstart.sh
            can u show that file
            • K
              kellogg76 @sdetweil
              #!/bin/bash
              node serveronly &
              sleep 30
              xinit /home/pi/chromium_start.sh
                sdetweil @kellogg76
                and that one?
                • K
                  kellogg76 @sdetweil
                  #!/bin/sh
                  unclutter &
                  xset -dpms # disable DPMS (Energy Star) features.
                  xset s off # disable screen saver
                  xset s noblank # don’t blank the video device
                  matchbox-window-manager &
                  chromium-browser -–incognito --start-fullscreen -–kiosk http://localhost:8080/
                    sdetweil @kellogg76
                    @kellogg76 weird…
                    and if you do pm2 start 0 it works ok?
                    • K
                      kellogg76 @sdetweil
                      @sdetweil it works in as much as I can see the magic mirror on another computer when I point to the correct IP, but the pi itself does not display anything at all, it sits at a terminal prompt or if I reboot and let it try to start on its own it’ll switch from prompt to black screen with mouse pointer as if it’s trying to start, then it loops back to a prompt and cycles between the two states.
                        weird… seems like chrome is having trouble.
                        if you type
                        chromium-browser  --app=https://cnn.com
                        does it come up?
                        in 2.10, i created a similar script for
                        pi0w(armv6l) as electron doesn’t exist anymore
                        try this script
                        curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/run-start.sh >~/MagicMirror/run-start.sh
                        chmod +x ~/MagicMirror/run-start.sh
                        then
                        ./run-start.sh
                        • K
                          kellogg76 @sdetweil
                          @sdetweil said in MM on Pi Zero fails after being off for a few days:
                          ./run-start.sh
                          When I run
                          I get command not found, so I tried
                          chromium  --app=https://cnn.com
                          and I get Illegal Instruction.
                          i tried your script, and I get the text on screen about no helper found etc, then it gets stuck when trying to fetch the calendar data. I can access it from another computer but the pi is still blank on screen
                          Edit: It does seem to go through the calendar step but just very slowly, still progressing to each successive calendar now. I’ll leave it running and see if it eventually successfully starts.
                            sdetweil @kellogg76
                            @kellogg76 no… its stuck with the chromium-browser not loading…
                            I think u need to reinstall the chromium browser…
                            this means there was an update , or there is an sd card problem…
                            • K
                              kellogg76 @sdetweil
                              @sdetweil looks like the quickest fix is to re-install again. It’s a pain as I probably have to do this about once or twice a year. It can be working great then either the power will unexpectedly go out or I’ll shut it down for some reason and then it takes a full wipe and re-install to get it working again.
                              S 2 Replies Last reply
                                sdetweil @kellogg76
                                @kellogg76 use my install script
                                see here
                                rename existing MM folder out of the way
                                run the install script… it does everything…
                                (well, not install chromium browser)
                                sudo apt-get install chromium-browser
                                  sdetweil @kellogg76
                                  @kellogg76 i have a system that is like that… power messes up everything…
                                  I have moved to boot from sd card, RUN from ssd…
                                  https://jamesachambers.com/raspberry-pi-4-usb-boot-config-guide-for-ssd-flash-drives/
                                  see starting here
                                  USB Boot Instructions
                                  • K
                                    kellogg76 @sdetweil
                                    @sdetweil I renamed the old MM directory and ran your script
                                    bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)"
                                    Everything went successfully, I can see the display from other computers but the pi just sits at a terminal prompt, is there something I need to do to start things off?
                                    $ pm2 list
                                    │ id │ name                    │ version │ mode    │ pid      │ uptime │ ↺    │ status   │ cpu      │ mem      │ user     │ watching │
                                    │ 1  │ MagicMirror             │ 2.10.1  │ fork    │ 568      │ 2m     │ 1    │ online   │ 0%       │ 2.5mb    │ pi       │ enabled  │
                                      sdetweil @kellogg76
                                      @kellogg76 did u install chromium-browser
                                      the run-start.sh script depends on it
                                      • K
                                        kellogg76 @sdetweil
                                        @sdetweil Yes, and then rebooted for good measure. Could it be anything to do with me running Raspbian Lite and not Desktop?
                                          sdetweil @kellogg76
                                          @kellogg76 you MUST run desktop for chromium to work…
                                          from the shell, do
                                          pgrep Xorg
                                          it should return a number
                                          • K
                                            kellogg76 @sdetweil
                                            @sdetweil It seemed to work well without it in the past, has something changed?
                                            I always found the Desktop version really laggy on the Zero so try to avoid it when not necessary.
