    How can i pass query / parameters from URL to module
    Scheduled Pinned Locked Moved Solved Development
    12 Posts 3 Posters 4.4k Views 3 Watching
      sdetweil @AxLed
      @AxLed sorry. not quite sure what you mean…
      u want to pass the info from where (how is the user presenting this info) to where
      • A
        AxLed Module Developer
        User is presenting / entering datas by URL in his browser and module should be able to handle the datas.
        AxLED
          sdetweil @AxLed
          @AxLed and did u setup an express path that invokes your node module function?
          the url parms should be there
          • A
            No i didnt set any path so far, but express path seems to be the right search word and helps.
            If i understood the documentation right, express path has to be located in node_helper.js.
            But i still dont know how to move forward with this information.
            Are there some modules which are using express path, where i can try to figure out how it works?
            Greetings
            AxLED
            I
              sdetweil @AxLed
              @AxLed MMM-ImagesPhotos uses it…
              the Module wants to use request, so issues a request to a local server (express path)
              which invokes the routine to get the list of photos//
              (instead of doing the sendSocketNotification to the node_module…)
              the express routine is like a cgi pgm invocation…
              from
              https://expressjs.com/en/guide/routing.html
              Route parameters
              the path can autoparse the url
              Route path: /users/:userId/books/:bookId
              Request URL: http://localhost:3000/users/34/books/8989
              req.params: { “userId”: “34”, “bookId”: “8989” }
              but the result, net, is the parms are in the req (uest) parameter object when the routine is called
              • A
                Thanks for the response, it think now i have enough to read and i will try to get in up and running.
                I will give feedback within the next day.
                AxLED
                  sdetweil @AxLed
                  @AxLed cooll… standing by!
                    @AxLed so, it should be as simple as
                    const express = require('express')
                    // setup server path handler, for http get request
                    this.expressApp.get("/MMM-Navigate",(req,res) =>{this.someFunction(req,res)});
                    // handler dump request object
                    someFunction: function(request,response){
                         console.log("request data="+JSON.stringify(request))
                        response.send("Hello from MMM-Navigate");
                      A Former User
                      Here is another example of express;
                      const bodyParser = require('body-parser')
                      // in your member function of node_helper.js, usually it will be `.start()`
                      this.expressApp.use(bodyParser.json())
                      this.expressApp.use(bodyParser.urlencoded({extended: true}))
                      var process = (req, res) => {
                        var subpath = req.params.subpath
                        if (CHECK_SOME_CONDITION) {
                          var requestObj = {
                            path: subpath,
                            query: req.query,
                            post: req.body,
                            method: req.method,
                          this.sendSocketNotification("REQUEST_COMING", requestObj)
                          res.status(200).send({status: 200})
                        } else {
                          res.status(400).send({status: 400})
                      this.expressApp.get("/YOUR_PATH/:subpath", process)
                      this.expressApp.post("/YOUR_PATH/:subpath", process) // when you need POST method.
                      • A
                        @Sean
                        Thanks for your quick response, you are faster than my programming timeslots in my “mancave” are. Today i had some time and got it working.
                        I will test my module changes (for MMM-Navigate) on my mirror for some days, maybe i find some errors and can fix them before i upload it to quick to github in a poor “quality”.
                        My intension was to get rid of MMM-Remote-Control in my installation, as i found errors (while a new install of my MM) and as it seems that MMM-Remote-Control is not maintainanced anymore.
                        I added following features to MMM-Navigate:
                        • Raspberry operations: any Shellcommands, i use it for
                          • restart of MM (pm2 restart mm)
                          • restart of Raspberry (sudo shutdown -h now)
                          • reboot of Raspberry (sudo reboot)
                        • controlling MM by URL Calls (if you dont have a rotary encoder connected or while programming)
                        stay healthy
                        Regards
                        AxLED
                        • A
                          testing completed, today i uploaded new release to github.
                          MMM-Navigate - V1.3 released
                          Regards
                          AxLED
