    How can i pass query / parameters from URL to module
    Scheduled Pinned Locked Moved Solved Development
    12 Posts 3 Posters 4.4k Views 3 Watching
      AxLed Module Developer
      User is presenting / entering datas by URL in his browser and module should be able to handle the datas.
      AxLED
        sdetweil @AxLed
        @AxLed and did u setup an express path that invokes your node module function?
        the url parms should be there
          No i didnt set any path so far, but express path seems to be the right search word and helps.
          If i understood the documentation right, express path has to be located in node_helper.js.
          But i still dont know how to move forward with this information.
          Are there some modules which are using express path, where i can try to figure out how it works?
          Greetings
          AxLED
          I
            sdetweil @AxLed
            @AxLed MMM-ImagesPhotos uses it…
            the Module wants to use request, so issues a request to a local server (express path)
            which invokes the routine to get the list of photos//
            (instead of doing the sendSocketNotification to the node_module…)
            the express routine is like a cgi pgm invocation…
            from
            https://expressjs.com/en/guide/routing.html
            Route parameters
            the path can autoparse the url
            Route path: /users/:userId/books/:bookId
            Request URL: http://localhost:3000/users/34/books/8989
            req.params: { “userId”: “34”, “bookId”: “8989” }
            but the result, net, is the parms are in the req (uest) parameter object when the routine is called
              Thanks for the response, it think now i have enough to read and i will try to get in up and running.
              I will give feedback within the next day.
              AxLED
                sdetweil @AxLed
                @AxLed cooll… standing by!
                  @AxLed so, it should be as simple as
                  const express = require('express')
                  // setup server path handler, for http get request
                  this.expressApp.get("/MMM-Navigate",(req,res) =>{this.someFunction(req,res)});
                  // handler dump request object
                  someFunction: function(request,response){
                       console.log("request data="+JSON.stringify(request))
                      response.send("Hello from MMM-Navigate");
                    A Former User
                    Here is another example of express;
                    const bodyParser = require('body-parser')
                    // in your member function of node_helper.js, usually it will be `.start()`
                    this.expressApp.use(bodyParser.json())
                    this.expressApp.use(bodyParser.urlencoded({extended: true}))
                    var process = (req, res) => {
                      var subpath = req.params.subpath
                      if (CHECK_SOME_CONDITION) {
                        var requestObj = {
                          path: subpath,
                          query: req.query,
                          post: req.body,
                          method: req.method,
                        this.sendSocketNotification("REQUEST_COMING", requestObj)
                        res.status(200).send({status: 200})
                      } else {
                        res.status(400).send({status: 400})
                    this.expressApp.get("/YOUR_PATH/:subpath", process)
                    this.expressApp.post("/YOUR_PATH/:subpath", process) // when you need POST method.
                      @Sean
                      Thanks for your quick response, you are faster than my programming timeslots in my “mancave” are. Today i had some time and got it working.
                      I will test my module changes (for MMM-Navigate) on my mirror for some days, maybe i find some errors and can fix them before i upload it to quick to github in a poor “quality”.
                      My intension was to get rid of MMM-Remote-Control in my installation, as i found errors (while a new install of my MM) and as it seems that MMM-Remote-Control is not maintainanced anymore.
                      I added following features to MMM-Navigate:
                      • Raspberry operations: any Shellcommands, i use it for
                        • restart of MM (pm2 restart mm)
                        • restart of Raspberry (sudo shutdown -h now)
                        • reboot of Raspberry (sudo reboot)
                      • controlling MM by URL Calls (if you dont have a rotary encoder connected or while programming)
                      stay healthy
                      Regards
                      AxLED
                        testing completed, today i uploaded new release to github.
                        MMM-Navigate - V1.3 released
                        Regards
                        AxLED
