    Use the voice to select the page but...wich module??
    8 Posts 5 Posters 969 Views 5 Watching
    • FoziF Offline
      Fozi Project Sponsor @Egnos
      @Egnos I went the easy route with installing MMM-AlexaControl MMM-AlexaControl and mounting an Echo Dot behind the mirror. The major challange for me was to find a reasonable mic for speech recognition. So I gave it up and took what was already available. For changing the pages I have MMM-Pages installed.
      • E Offline
        Egnos
        Thanks guys for the advises!
        Now I try to study how they work.
        I have two questions:
        • Which microphone did you use (I tried to use a micro microphone but with bad results …).
          I also have a PS3 Eye but I can’t understand how to make it work. Can you help me?
        • I didn’t understand how to inform another module that has to change the page or do anything else…
          For example, the link below:
          Notification
          Where should I add these notifications? In config.js?
          Can you give me an example?
        Thanks for your patience.
        • StoffbeuteluweS Offline
          Stoffbeuteluwe Project Sponsor @Egnos
          @Egnos MMM-AlexaControl works fine …:thumbs_up_medium-light_skin_tone:
          • E Offline
            Egnos
            Is it necessary to have an Amazon “Echo Dot” using the “MMM” module?
            Thanks.
              sdetweil @Egnos
              @Egnos u need a real echo device… the voice control comes from adding a fake device to the list of devices,
              and then the actions are sent to the module to execute
              the fake device is a wemo electric plug… which only has on or off
              but the module adds multiple ‘plugs’ and gives you control of what happens…
              adds a pm2 device, so you can start/stop mirror using pm2
              adds a restart device, so you can restart (on) the system
              etc…
              you can add additional devices and assign custom scripts as actions
              • E Offline
                Egnos @sdetweil
                Thanks @sdetweil, now i understand how it works.
