Solved MM on Ubuntu
@goncalovsc how did u do install?
it should not run without config.js
@sdetweil I installed with the command you gave on the beggining of this thread
@sdetweil said in MM on Ubuntu:
cd ~/MagicMirror/config
Here you have - https://gyazo.com/18000e7546ea27b9c3682acd33c1d27a
@goncalovsc config.js is present… which file did u edit?
@sdetweil now its present because i copied it from config.js.sample and renamed it
@goncalovsc show me
~/install.log -
@goncalovsc why? you did not do sudo on install command, right?
dols ~/i* -laF
ls ~/i* -laF
That worked - https://gyazo.com/bf7c215253185fb005cd67994706e79e
