    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
      sdetweil @goncalovsc
      @goncalovsc could u edit your post to put the 1st 3 backtics on a separate line (I can’t change it)
      • G
        goncalovsc @sdetweil
        @sdetweil Changed the API, still shows “Incorrect APPID”
          @goncalovsc sorry, I do not know about the api itself…
          on my system with your prior config, the weatherforecast module displayed
            @sdetweil both displayed now
            G 1 Reply Last reply
            • G
              @sdetweil My config file says config.js.sample
              Is that suppose or?
                @goncalovsc no…
                config.js
                there should be two files in the folder… config.js.sample (original as shipped )
                config.js (copied from sample at install time), used from then on as live config
                • G
                  @sdetweil It only came with this one at install. Should I copy this one and rename it to config.js?
                    @goncalovsc how did u do install?
                    it should not run without config.js
                    • G
                      @sdetweil I installed with the command you gave on the beggining of this thread
                        @goncalovsc my script will copy the sample
                        please do
                        cd ~/MagicMirror/config
                        ls -laF
                        show results
                        • G
                          @sdetweil said in MM on Ubuntu:
                          Here you have - https://gyazo.com/18000e7546ea27b9c3682acd33c1d27a
                            @goncalovsc config.js is present… which file did u edit?
                            • G
                              @sdetweil now its present because i copied it from config.js.sample and renamed it
                                @goncalovsc show me
                                ~/install.log
                                • G
                                  ~/install.log
                                  ahhh permission denied, hou should i do it?
                                    @goncalovsc why? you did not do sudo on install command, right?
                                    do
                                    ls ~/i* -laF
                                    • G
                                      goncalovsc
                                      ls ~/i* -laF
                                      That worked - https://gyazo.com/bf7c215253185fb005cd67994706e79e
                                        @goncalovsc ok, when I mean show me the log, I mean the contents of the file
                                        cat ~/install.log
                                        If u can printscreen, you should be able to copy/paste the text
                                        • G
                                          cat ~/install.log
                                          install starting  - sáb abr  4 12:57:46 WEST 2020
                                          installing on x86_64 processor system
                                          the os is Distributor ID: Ubuntu Description: Ubuntu 18.04.4 LTS Release: 18.04 Codename: bionic
                                          Updating packages ...
                                          Atingido:1 http://pt.archive.ubuntu.com/ubuntu bionic InRelease Obter:2 http://pt.archive.ubuntu.com/ubuntu bionic-updates InRelease [88,7 kB] Obter:3 http://security.ubuntu.com/ubuntu bionic-security InRelease [88,7 kB] Obter:4 http://pt.archive.ubuntu.com/ubuntu bionic-backports InRelease [74,6 kB] Obter:5 http://pt.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [307 kB] Obter:6 http://pt.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [73,8 kB] Obter:7 http://pt.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [140 kB] Obter:8 http://pt.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [1012 kB] Obter:9 http://pt.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1061 kB] Obter:10 http://pt.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [273 kB] Obter:11 http://pt.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [215 kB] Obter:12 http://pt.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [489 kB] Obter:13 http://security.ubuntu.com/ubuntu bionic-security/main i386 Packages [454 kB] Obter:14 http://pt.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2468 B] Obter:15 http://pt.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7980 B] Obter:16 http://security.ubuntu.com/ubuntu bionic-security/main amd64 Packages [677 kB] Obter:17 http://security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [38,5 kB] Obter:18 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [17,6 kB] Obter:19 http://security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [41,5 kB] Obter:20 http://security.ubuntu.com/ubuntu bionic-security/universe i386 Packages [617 kB] Obter:21 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 Packages [653 kB] Obter:22 http://security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [42,1 kB] Obter:23 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16,4 kB] Obter:24 http://security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [111 kB] Obter:25 http://security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2464 B] Obtidos 6506 kB em 3s (2287 kB/s) A ler as listas de pacotes...
                                          apt-get update  completed ok
                                          apt-get upgrade  started
                                          apt upgrade result =rc=0 A ler as listas de pacotes...
                                          A construir árvore de dependências...
                                          A ler a informação de estado...
                                          A calcular a actualização...
                                          Os seguintes pacotes foram instalados automaticamente e já não são necessários:
                                            efibootmgr libfwup1 libwayland-egl1-mesa
                                          Utilize 'sudo apt autoremove' para os remover.
                                          Serão actualizados os seguintes pacotes:
                                            firefox firefox-locale-en firefox-locale-pt xserver-common xserver-xephyr
                                            xwayland
                                          6 pacotes actualizados, 0 pacotes novos instalados, 0 a remover e 0 não actualizados.
                                          É necessário obter 53,5 MB/55,4 MB de arquivos.
                                          Após esta operação, serão utilizados 9216 B adicionais de espaço em disco.
                                          Obter:1 http://security.ubuntu.com/ubuntu bionic-security/main amd64 firefox amd64 74.0.1+build1-0ubuntu0.18.04.1 [51,9 MB]
                                          Obter:2 http://security.ubuntu.com/ubuntu bionic-security/main amd64 firefox-locale-en amd64 74.0.1+build1-0ubuntu0.18.04.1 [726 kB]
                                          Obter:3 http://security.ubuntu.com/ubuntu bionic-security/main amd64 firefox-locale-pt amd64 74.0.1+build1-0ubuntu0.18.04.1 [925 kB]
                                          Obtidos 53,5 MB em 5s (11,8 MB/s)
                                          (A ler a base de dados ... 166374 ficheiros e directórios actualmente instalados.)
                                          A preparar para desempacotar .../0-firefox_74.0.1+build1-0ubuntu0.18.04.1_amd64.deb ...
                                          A descompactar firefox (74.0.1+build1-0ubuntu0.18.04.1) sobre (74.0+build3-0ubuntu0.18.04.1) ...
                                          A preparar para desempacotar .../1-firefox-locale-en_74.0.1+build1-0ubuntu0.18.04.1_amd64.deb ...
                                          A descompactar firefox-locale-en (74.0.1+build1-0ubuntu0.18.04.1) sobre (74.0+build3-0ubuntu0.18.04.1) ...
                                          A preparar para desempacotar .../2-firefox-locale-pt_74.0.1+build1-0ubuntu0.18.04.1_amd64.deb ...
                                          A descompactar firefox-locale-pt (74.0.1+build1-0ubuntu0.18.04.1) sobre (74.0+build3-0ubuntu0.18.04.1) ...
                                          A preparar para desempacotar .../3-xserver-common_2%3a1.19.6-1ubuntu4.4_all.deb ...
                                          A descompactar xserver-common (2:1.19.6-1ubuntu4.4) sobre (2:1.19.6-1ubuntu4.3) ...
                                          A preparar para desempacotar .../4-xserver-xephyr_2%3a1.19.6-1ubuntu4.4_amd64.deb ...
                                          A descompactar xserver-xephyr (2:1.19.6-1ubuntu4.4) sobre (2:1.19.6-1ubuntu4.3) ...
                                          A preparar para desempacotar .../5-xwayland_2%3a1.19.6-1ubuntu4.4_amd64.deb ...
                                          A descompactar xwayland (2:1.19.6-1ubuntu4.4) sobre (2:1.19.6-1ubuntu4.3) ...
                                          A instalar xserver-common (2:1.19.6-1ubuntu4.4) ...
                                          A instalar firefox-locale-en (74.0.1+build1-0ubuntu0.18.04.1) ...
                                          A instalar xserver-xephyr (2:1.19.6-1ubuntu4.4) ...
                                          A instalar firefox-locale-pt (74.0.1+build1-0ubuntu0.18.04.1) ...
                                          A instalar firefox (74.0.1+build1-0ubuntu0.18.04.1) ...
                                          Please restart all running instances of firefox, or you will experience problems.
                                          A instalar xwayland (2:1.19.6-1ubuntu4.4) ...
                                          A processar 'triggers' para hicolor-icon-theme (0.17-2) ...
                                          A processar 'triggers' para mime-support (3.60ubuntu1) ...
                                          A processar 'triggers' para desktop-file-utils (0.23-1ubuntu3.18.04.2) ...
                                          A processar 'triggers' para man-db (2.8.3-2ubuntu0.1) ...
                                          A processar 'triggers' para gnome-menus (3.13.3-11ubuntu1.1) ...
                                          Installing helper tools ...
                                          build-essential is already the newest version (12.4ubuntu1).
                                          build-essential está definido para ser instalado manualmente.
                                          unzip is already the newest version (6.0-21ubuntu1).
                                          unzip está definido para ser instalado manualmente.
                                          curl is already the newest version (7.58.0-2ubuntu3.8).
                                          wget is already the newest version (1.19.4-1ubuntu2.2).
                                          wget está definido para ser instalado manualmente.
                                          The following additional packages will be installed:
                                            git-man liberror-perl
                                          Pacotes sugeridos:
                                            git-daemon-run | git-daemon-sysvinit git-doc git-el git-email git-gui gitk
                                            gitweb git-cvs git-mediawiki git-svn
                                          Serão instalados os seguintes NOVOS pacotes:
                                            git git-man liberror-perl
                                          0 pacotes actualizados, 3 pacotes novos instalados, 0 a remover e 0 não actualizados.
                                          É necessário obter 4738 kB de arquivos.
                                          Após esta operação, serão utilizados 33,9 MB adicionais de espaço em disco.
                                          Obter:1 http://pt.archive.ubuntu.com/ubuntu bionic/main amd64 liberror-perl all 0.17025-1 [22,8 kB]
                                          Obter:2 http://pt.archive.ubuntu.com/ubuntu bionic-updates/main amd64 git-man all 1:2.17.1-1ubuntu0.5 [803 kB]
                                          Obter:3 http://pt.archive.ubuntu.com/ubuntu bionic-updates/main amd64 git amd64 1:2.17.1-1ubuntu0.5 [3912 kB]
                                          Obtidos 4738 kB em 1s (7320 kB/s)
                                          A seleccionar pacote anteriormente não seleccionado liberror-perl.
                                          A preparar para desempacotar .../liberror-perl_0.17025-1_all.deb ...
                                          A descompactar liberror-perl (0.17025-1) ...
                                          A seleccionar pacote anteriormente não seleccionado git-man.
                                          A preparar para desempacotar .../git-man_1%3a2.17.1-1ubuntu0.5_all.deb ...
                                          A descompactar git-man (1:2.17.1-1ubuntu0.5) ...
                                          A seleccionar pacote anteriormente não seleccionado git.
                                          A preparar para desempacotar .../git_1%3a2.17.1-1ubuntu0.5_amd64.deb ...
                                          A descompactar git (1:2.17.1-1ubuntu0.5) ...
                                          A instalar git-man (1:2.17.1-1ubuntu0.5) ...
                                          A instalar liberror-perl (0.17025-1) ...
                                          A instalar git (1:2.17.1-1ubuntu0.5) ...
                                          Minimum Node version: v10.1.0
                                          Installed Node version: v8.10.0
                                          Node should be upgraded.
                                          Installing Node.js ...
                                          Node release info = ## Installing the NodeSource Node.js 10.x repo... ## Populating apt-get cache... + apt-get update Atingido:1 http://pt.archive.ubuntu.com/ubuntu bionic InRelease Atingido:2 http://pt.archive.ubuntu.com/ubuntu bionic-updates InRelease Atingido:3 http://pt.archive.ubuntu.com/ubuntu bionic-backports InRelease Atingido:4 http://security.ubuntu.com/ubuntu bionic-security InRelease A ler as listas de pacotes... ## Confirming "bionic" is supported... + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_10.x/dists/bionic/Release' ## Adding the NodeSource signing key to your keyring... + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | apt-key add - OK ## Creating apt sources list file for the NodeSource Node.js 10.x repo... + echo 'deb https://deb.nodesource.com/node_10.x bionic main' > /etc/apt/sources.list.d/nodesource.list + echo 'deb-src https://deb.nodesource.com/node_10.x bionic main' >> /etc/apt/sources.list.d/nodesource.list ## Running `apt-get update` for you... + apt-get update Atingido:1 http://pt.archive.ubuntu.com/ubuntu bionic InRelease Atingido:2 http://pt.archive.ubuntu.com/ubuntu bionic-updates InRelease Atingido:3 http://pt.archive.ubuntu.com/ubuntu bionic-backports InRelease Atingido:4 http://security.ubuntu.com/ubuntu bionic-security InRelease Obter:5 https://deb.nodesource.com/node_10.x bionic InRelease [4584 B] Obter:6 https://deb.nodesource.com/node_10.x bionic/main amd64 Packages [765 B] Obtidos 5349 B em 1s (5158 B/s) A ler as listas de pacotes... ## Run `sudo apt-get install -y nodejs` to install Node.js 10.x and npm ## You may also need development tools to build native addons: sudo apt-get install gcc g++ make ## To install the Yarn package manager, run: curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | sudo apt-key add - echo "deb https://dl.yarnpkg.com/debian/ stable main" | sudo tee /etc/apt/sources.list.d/yarn.list sudo apt-get update && sudo apt-get install yarn
                                          v10.19.0
                                          Node.js installation Done! version=v10.19.0
                                          Minimum npm version: V6.0.0
                                          Installed npm version: V6.13.4
                                          No npm upgrade necessary.
                                          Cloning MagicMirror ...
                                          Cloning MagicMirror Done!
                                          Installing dependencies ...
                                          Dependencies installation Done!
                                          setting up initial config.js
                                          Check plymouth installation ...
                                          Splashscreen: Checking themes directory.
                                          Splashscreen: Create theme directory if not exists.
                                          install and setup pm2
                                          pm2 not installed, installing
                                          pm2 install result npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.) /usr/bin/pm2 -> /usr/lib/node_modules/pm2/bin/pm2 /usr/bin/pm2-dev -> /usr/lib/node_modules/pm2/bin/pm2-dev /usr/bin/pm2-docker -> /usr/lib/node_modules/pm2/bin/pm2-docker /usr/bin/pm2-runtime -> /usr/lib/node_modules/pm2/bin/pm2-runtime npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/pm2/node_modules/chokidar/node_modules/fsevents): npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"}) + pm2@4.2.3 added 207 packages from 202 contributors in 17.948s
                                          get the pm2 platform specific startup command
                                          startup command = sudo env PATH=$PATH:/usr/bin:/bin /usr/lib/node_modules/pm2/bin/pm2 startup systemd -u goncalo --hp /home/goncalo
                                          [PM2] Init System found: systemd
                                          Platform systemd
                                          Template
                                          [Unit]
                                          Description=PM2 process manager
                                          Documentation=https://pm2.keymetrics.io/
                                          After=network.target
                                          [Service]
                                          Type=forking
                                          User=goncalo
                                          LimitNOFILE=infinity
                                          LimitNPROC=infinity
                                          LimitCORE=infinity
                                          Environment=PATH=$PATH:/usr/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                                          Environment=PM2_HOME=/home/goncalo/.pm2
                                          PIDFile=/home/goncalo/.pm2/pm2.pid
                                          Restart=on-failure
                                          ExecStart=/usr/lib/node_modules/pm2/bin/pm2 resurrect
                                          ExecReload=/usr/lib/node_modules/pm2/bin/pm2 reload all
                                          ExecStop=/usr/lib/node_modules/pm2/bin/pm2 kill
                                          [Install]
                                          WantedBy=multi-user.target
                                          Target path
                                          /etc/systemd/system/pm2-goncalo.service
                                          Command list
                                          [ 'systemctl enable pm2-goncalo' ]
                                          [PM2] Writing init configuration in /etc/systemd/system/pm2-goncalo.service
                                          [PM2] Making script booting at startup...
                                          [PM2] [-] Executing: systemctl enable pm2-goncalo...
                                          [PM2] [v] Command successfully executed.
                                          [PM2] Freeze a process list on reboot via:
                                          $ pm2 save
                                          [PM2] Remove init script via:
                                          $ pm2 unstartup systemd
                                          pm2 startup command done
                                          configure the pm2 config file for MagicMirror
                                          the user is not pi
                                          change mm.sh
                                          save copy of mm.sh
                                          change relative home path to hard coded path
                                          change pm2_MagicMirror.json
                                          now using this config file pm2_MagicMirror_new.json
                                          start MagicMirror via pm2 now
                                          save MagicMirror pm2 config now
                                          disable screensaver via gsettings was true and uint32 300
                                          gsettings screen saver already disabled
                                          We're ready! Run pm2 start MagicMirror from the ~/MagicMirror directory to start your MagicMirror.
                                          install completed - sáb abr  4 14:27:42 WEST 2020
                                            @goncalovsc said in MM on Ubuntu:
                                            from my script
                                            # Use sample config for start MagicMirror
                                            echo setting up initial config.js | tee -a $logfile      // < --- this is the message
                                            cp config/config.js.sample config/config.js
                                            • 2 / 5
