    MM on Ubuntu
    90 Posts 4 Posters 59.9k Views 4 Watching
      sdetweil @goncalovsc
      @goncalovsc i am confused…
      u said you edited the files, but nothing changed on restart…
      so, I want to see what you edited in the files…
      • G Offline
        goncalovsc @sdetweil
        @sdetweil Its on the printscreen, weather location changed etc etc
        But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
          @goncalovsc again, can u show me the config.js file please… I don’t care about the output, you said it didn’t have any effect.
          • G Offline
            @sdetweil ```
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            language: "pt",
            timeFormat: 24,
            units: "metric",
            		     // false, default for all  NON-armv6l devices
            		module: "alert",
            		module: "updatenotification",
            		position: "top_bar"
            		module: "clock",
            		position: "top_left"
            		header: "Feriados",
            					symbol: "calendar-check",
            					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
            		module: "compliments",
            		position: "lower_third"
            		module: "currentweather",
            			locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            			appid: "18493e6342f2df4ac6ca7ed72fd3d79b"
            		module: "weatherforecast",
            		header: "Weather Forecast",
            		module: "newsfeed",
            		position: "bottom_bar",
            			feeds: [
            					title: "Últimas Noticias",
            					url: "https://www.cmjornal.pt/rss"
            			showSourceTitle: true,
            			showPublishDate: true,
            			broadcastNewsFeeds: true,
            			broadcastNewsUpdates: true
              @goncalovsc ok, open the developers window, ctrl-shift-i on the keyboard, select the console tab,
              enter ‘weath’ in the filter field (no quotes)
              and u will see
              weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2737824&units=metric&lang=en&APPID=18493e6… 401 (Unauthorized)
              weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
              so, u need to change your openweather api key
                @goncalovsc could u edit your post to put the 1st 3 backtics on a separate line (I can’t change it)
                • G Offline
                  @sdetweil Changed the API, still shows “Incorrect APPID”
                    @goncalovsc sorry, I do not know about the api itself…
                    on my system with your prior config, the weatherforecast module displayed
                      @sdetweil both displayed now
                      • G Offline
                        @sdetweil My config file says config.js.sample
                        Is that suppose or?
                          @goncalovsc no…
                          config.js
                          there should be two files in the folder… config.js.sample (original as shipped )
                          config.js (copied from sample at install time), used from then on as live config
                          • G Offline
                            @sdetweil It only came with this one at install. Should I copy this one and rename it to config.js?
                              @goncalovsc how did u do install?
                              it should not run without config.js
                              • G Offline
                                @sdetweil I installed with the command you gave on the beggining of this thread
                                  @goncalovsc my script will copy the sample
                                  please do
                                  cd ~/MagicMirror/config
                                  ls -laF
                                  show results
                                  • G Offline
                                    @sdetweil said in MM on Ubuntu:
                                    Here you have - https://gyazo.com/18000e7546ea27b9c3682acd33c1d27a
                                      @goncalovsc config.js is present… which file did u edit?
                                      • G Offline
                                        @sdetweil now its present because i copied it from config.js.sample and renamed it
                                          @goncalovsc show me
                                          ~/install.log
                                          • G Offline
                                            ~/install.log
                                            ahhh permission denied, hou should i do it?
                                            • 1 / 5
