    MM on Ubuntu
    90 Posts 4 Posters 59.9k Views 4 Watching
    • G Offline
      goncalovsc
      So, I have an old laptop that I will use to a smart mirror.
      I installed MM via Snap Store
      How can edit that config files now to be personalized to my country?
        Mykle1 Project Sponsor Module Developer @goncalovsc
        @goncalovsc
        Start by changing the language at the beginning of the config.
        Mine: language: "en",
        Find a newsfeed that is relevant to you for the newsfeed module.
        Use the search feature of the forum to see if your questions have already been answered
        When you do ask a question, be as specific as you can.
        • G Offline
          goncalovsc @Mykle1
          @Mykle1 but files from snap store are all “only read”. How can I change that? I tried every methods and nothing
            @goncalovsc
            I’ve never heard of the “snap store”. I suspect you are using software other than MagicMirror
            S G 2 Replies Last reply Reply Quote 0
              sdetweil @Mykle1
              @Mykle1 seems its a new library (never heard of it before either)
              https://snapcraft.io/store
              • G Offline
                goncalovsc @Mykle1
                @Mykle1 how do I install without snap store? I tried to follow an old tutorial from you here in a old post but i had a lot of errors
                  sdetweil @goncalovsc
                  @goncalovsc use the install script from here
                  • G Offline
                    goncalovsc @sdetweil
                    @sdetweil thanks, it worked fine!
                    But, I edited the compliments and the config file and nothing changed, what should I do?
                    I already restarted the pc
                      @goncalovsc said in MM on Ubuntu:
                      please show your changes… thx
                      (u should not edit the compliments.js file, right, only the config.js
                      • G Offline
                        @sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
                        nothing changed
                          @goncalovsc i am confused…
                          u said you edited the files, but nothing changed on restart…
                          so, I want to see what you edited in the files…
                          • G Offline
                            @sdetweil Its on the printscreen, weather location changed etc etc
                            But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
                              @goncalovsc again, can u show me the config.js file please… I don’t care about the output, you said it didn’t have any effect.
                              • G Offline
                                @sdetweil ```
                                /* Magic Mirror Config Sample
                                 * MIT Licensed.
                                var config = {
                                	port: 8080,
                                language: "pt",
                                timeFormat: 24,
                                units: "metric",
                                		     // false, default for all  NON-armv6l devices
                                		module: "alert",
                                		module: "updatenotification",
                                		position: "top_bar"
                                		module: "clock",
                                		position: "top_left"
                                		header: "Feriados",
                                					symbol: "calendar-check",
                                					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                                		module: "compliments",
                                		position: "lower_third"
                                		module: "currentweather",
                                			locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                			appid: "18493e6342f2df4ac6ca7ed72fd3d79b"
                                		module: "weatherforecast",
                                		header: "Weather Forecast",
                                		module: "newsfeed",
                                		position: "bottom_bar",
                                			feeds: [
                                					title: "Últimas Noticias",
                                					url: "https://www.cmjornal.pt/rss"
                                			showSourceTitle: true,
                                			showPublishDate: true,
                                			broadcastNewsFeeds: true,
                                			broadcastNewsUpdates: true
                                  @goncalovsc ok, open the developers window, ctrl-shift-i on the keyboard, select the console tab,
                                  enter ‘weath’ in the filter field (no quotes)
                                  and u will see
                                  weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2737824&units=metric&lang=en&APPID=18493e6… 401 (Unauthorized)
                                  weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                                  so, u need to change your openweather api key
                                    @goncalovsc could u edit your post to put the 1st 3 backtics on a separate line (I can’t change it)
                                    • G Offline
                                      @sdetweil Changed the API, still shows “Incorrect APPID”
                                        @goncalovsc sorry, I do not know about the api itself…
                                        on my system with your prior config, the weatherforecast module displayed
                                          @sdetweil both displayed now
                                          • G Offline
                                            @sdetweil My config file says config.js.sample
                                            Is that suppose or?
                                            • 1 / 5
