    MM on Ubuntu
    90 Posts 4 Posters 64.6k Views 4 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @goncalovsc
      @goncalovsc
      I’ve never heard of the “snap store”. I suspect you are using software other than MagicMirror
      S G 2 Replies Last reply
        sdetweil @Mykle1
        @Mykle1 seems its a new library (never heard of it before either)
        https://snapcraft.io/store
        • G
          goncalovsc @Mykle1
          @Mykle1 how do I install without snap store? I tried to follow an old tutorial from you here in a old post but i had a lot of errors
            sdetweil @goncalovsc
            @goncalovsc use the install script from here
            G 1 Reply Last reply
            • G
              goncalovsc @sdetweil
              @sdetweil thanks, it worked fine!
              But, I edited the compliments and the config file and nothing changed, what should I do?
              I already restarted the pc
                @goncalovsc said in MM on Ubuntu:
                please show your changes… thx
                (u should not edit the compliments.js file, right, only the config.js
                • G
                  @sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
                  nothing changed
                    @goncalovsc i am confused…
                    u said you edited the files, but nothing changed on restart…
                    so, I want to see what you edited in the files…
                    • G
                      @sdetweil Its on the printscreen, weather location changed etc etc
                      But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
                        @goncalovsc again, can u show me the config.js file please… I don’t care about the output, you said it didn’t have any effect.
                        • G
                          @sdetweil ```
                          /* Magic Mirror Config Sample
                           * MIT Licensed.
                          var config = {
                          	port: 8080,
                          language: "pt",
                          timeFormat: 24,
                          units: "metric",
                          		     // false, default for all  NON-armv6l devices
                          		module: "alert",
                          		module: "updatenotification",
                          		position: "top_bar"
                          		module: "clock",
                          		position: "top_left"
                          		header: "Feriados",
                          					symbol: "calendar-check",
                          					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                          		module: "compliments",
                          		position: "lower_third"
                          		module: "currentweather",
                          			locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          			appid: "18493e6342f2df4ac6ca7ed72fd3d79b"
                          		module: "weatherforecast",
                          		header: "Weather Forecast",
                          		module: "newsfeed",
                          		position: "bottom_bar",
                          			feeds: [
                          					title: "Últimas Noticias",
                          					url: "https://www.cmjornal.pt/rss"
                          			showSourceTitle: true,
                          			showPublishDate: true,
                          			broadcastNewsFeeds: true,
                          			broadcastNewsUpdates: true
                          S 2 Replies Last reply
                            @goncalovsc ok, open the developers window, ctrl-shift-i on the keyboard, select the console tab,
                            enter ‘weath’ in the filter field (no quotes)
                            and u will see
                            weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2737824&units=metric&lang=en&APPID=18493e6… 401 (Unauthorized)
                            weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                            so, u need to change your openweather api key
                              @goncalovsc could u edit your post to put the 1st 3 backtics on a separate line (I can’t change it)
                              • G
                                @sdetweil Changed the API, still shows “Incorrect APPID”
                                  @goncalovsc sorry, I do not know about the api itself…
                                  on my system with your prior config, the weatherforecast module displayed
                                    @sdetweil both displayed now
                                    • G
                                      @sdetweil My config file says config.js.sample
                                      Is that suppose or?
                                        @goncalovsc no…
                                        config.js
                                        there should be two files in the folder… config.js.sample (original as shipped )
                                        config.js (copied from sample at install time), used from then on as live config
                                        • G
                                          @sdetweil It only came with this one at install. Should I copy this one and rename it to config.js?
                                            @goncalovsc how did u do install?
                                            it should not run without config.js
                                            • 1 / 5
