    MM on Ubuntu
    90 Posts 4 Posters 50.1k Views 4 Watching
    • G Offline
      goncalovsc @Mykle1
      @Mykle1 but files from snap store are all “only read”. How can I change that? I tried every methods and nothing
        Mykle1 Project Sponsor Module Developer @goncalovsc
        @goncalovsc
        I’ve never heard of the “snap store”. I suspect you are using software other than MagicMirror
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @Mykle1
          @Mykle1 seems its a new library (never heard of it before either)
          https://snapcraft.io/store
          • G Offline
            goncalovsc @Mykle1
            @Mykle1 how do I install without snap store? I tried to follow an old tutorial from you here in a old post but i had a lot of errors
              sdetweil @goncalovsc
              @goncalovsc use the install script from here
              • G Offline
                goncalovsc @sdetweil
                @sdetweil thanks, it worked fine!
                But, I edited the compliments and the config file and nothing changed, what should I do?
                I already restarted the pc
                  @goncalovsc said in MM on Ubuntu:
                  please show your changes… thx
                  (u should not edit the compliments.js file, right, only the config.js
                  • G Offline
                    @sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
                    nothing changed
                      @goncalovsc i am confused…
                      u said you edited the files, but nothing changed on restart…
                      so, I want to see what you edited in the files…
                      • G Offline
                        @sdetweil Its on the printscreen, weather location changed etc etc
                        But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
                        • 1 / 9
