    MM on Ubuntu
    90 Posts 4 Posters 48.2k Views 4 Watching
    • G Offline
      goncalovsc @Mykle1
      @Mykle1 how do I install without snap store? I tried to follow an old tutorial from you here in a old post but i had a lot of errors
        sdetweil @goncalovsc
        @goncalovsc use the install script from here
        • G Offline
          goncalovsc @sdetweil
          @sdetweil thanks, it worked fine!
          But, I edited the compliments and the config file and nothing changed, what should I do?
          I already restarted the pc
            @goncalovsc said in MM on Ubuntu:
            please show your changes… thx
            (u should not edit the compliments.js file, right, only the config.js
            • G Offline
              @sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
              nothing changed
                @goncalovsc i am confused…
                u said you edited the files, but nothing changed on restart…
                so, I want to see what you edited in the files…
                • G Offline
                  @sdetweil Its on the printscreen, weather location changed etc etc
                  But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
                    @goncalovsc again, can u show me the config.js file please… I don’t care about the output, you said it didn’t have any effect.
                    • G Offline
                      @sdetweil ```
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      language: "pt",
                      timeFormat: 24,
                      units: "metric",
                      		     // false, default for all  NON-armv6l devices
                      		module: "alert",
                      		module: "updatenotification",
                      		position: "top_bar"
                      		module: "clock",
                      		position: "top_left"
                      		header: "Feriados",
                      					symbol: "calendar-check",
                      					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                      		module: "compliments",
                      		position: "lower_third"
                      		module: "currentweather",
                      			locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                      			appid: "18493e6342f2df4ac6ca7ed72fd3d79b"
                      		module: "weatherforecast",
                      		header: "Weather Forecast",
                      		module: "newsfeed",
                      		position: "bottom_bar",
                      			feeds: [
                      					title: "Últimas Noticias",
                      					url: "https://www.cmjornal.pt/rss"
                      			showSourceTitle: true,
                      			showPublishDate: true,
                      			broadcastNewsFeeds: true,
                      			broadcastNewsUpdates: true
                        @goncalovsc ok, open the developers window, ctrl-shift-i on the keyboard, select the console tab,
                        enter ‘weath’ in the filter field (no quotes)
                        and u will see
                        weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2737824&units=metric&lang=en&APPID=18493e6… 401 (Unauthorized)
                        weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                        so, u need to change your openweather api key
                        • 1 / 9
