    MM on Ubuntu
    90 Posts 4 Posters 61.7k Views 4 Watching
      sdetweil @goncalovsc
      @goncalovsc said in MM on Ubuntu:
      I edited the compliments and the config file
      please show your changes… thx
      (u should not edit the compliments.js file, right, only the config.js
      • G
        goncalovsc @sdetweil
        @sdetweil https://gyazo.com/0d971f9417655c6753c26a538fa702ff
        nothing changed
          @goncalovsc i am confused…
          u said you edited the files, but nothing changed on restart…
          so, I want to see what you edited in the files…
          • G
            @sdetweil Its on the printscreen, weather location changed etc etc
            But as you can see, all unchanged https://gyazo.com/bdf479ec8837ed27c9727b0ac8d5877a
              @goncalovsc again, can u show me the config.js file please… I don’t care about the output, you said it didn’t have any effect.
              • G
                @sdetweil ```
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                language: "pt",
                timeFormat: 24,
                units: "metric",
                		     // false, default for all  NON-armv6l devices
                		module: "alert",
                		module: "updatenotification",
                		position: "top_bar"
                		module: "clock",
                		position: "top_left"
                		header: "Feriados",
                					symbol: "calendar-check",
                					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"					}
                		module: "compliments",
                		position: "lower_third"
                		module: "currentweather",
                			locationID: "2737824", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                			appid: "18493e6342f2df4ac6ca7ed72fd3d79b"
                		module: "weatherforecast",
                		header: "Weather Forecast",
                		module: "newsfeed",
                		position: "bottom_bar",
                			feeds: [
                					title: "Últimas Noticias",
                					url: "https://www.cmjornal.pt/rss"
                			showSourceTitle: true,
                			showPublishDate: true,
                			broadcastNewsFeeds: true,
                			broadcastNewsUpdates: true
                  @goncalovsc ok, open the developers window, ctrl-shift-i on the keyboard, select the console tab,
                  enter ‘weath’ in the filter field (no quotes)
                  and u will see
                  weatherforecast.js:279 GET https://api.openweathermap.org/data/2.5/forecast/daily?id=2737824&units=metric&lang=en&APPID=18493e6… 401 (Unauthorized)
                  weatherforecast.js:266 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
                  so, u need to change your openweather api key
                    @goncalovsc could u edit your post to put the 1st 3 backtics on a separate line (I can’t change it)
                    • G
                      @sdetweil Changed the API, still shows “Incorrect APPID”
                        @goncalovsc sorry, I do not know about the api itself…
                        on my system with your prior config, the weatherforecast module displayed
                          @sdetweil both displayed now
                          • G
                            @sdetweil My config file says config.js.sample
                            Is that suppose or?
                              @goncalovsc no…
                              config.js
                              there should be two files in the folder… config.js.sample (original as shipped )
                              config.js (copied from sample at install time), used from then on as live config
                              • G
                                @sdetweil It only came with this one at install. Should I copy this one and rename it to config.js?
                                  @goncalovsc how did u do install?
                                  it should not run without config.js
                                  • G
                                    @sdetweil I installed with the command you gave on the beggining of this thread
                                      @goncalovsc my script will copy the sample
                                      please do
                                      cd ~/MagicMirror/config
                                      ls -laF
                                      show results
                                      • G
                                        @sdetweil said in MM on Ubuntu:
                                        Here you have - https://gyazo.com/18000e7546ea27b9c3682acd33c1d27a
                                          @goncalovsc config.js is present… which file did u edit?
                                          • G
                                            @sdetweil now its present because i copied it from config.js.sample and renamed it
                                            • 1 / 5
